The Distance element has an attribute of "units", which is of anyURI, for this.
<Distance units="your unit goes here">5</Distance>
However, as I understand it, units are ignored.
-----Original Message-----
Sent: October 21, 2010 11:12 AM
Subject: [Geoserver-users] DWithin Units
http://localhost:8081/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=topp:states&filter=<Filter><DWithin><PropertyName>the\_geom</PropertyName><Point><coordinates>28\.784925,\-80\.785889</coordinates></Point><Distance>5</Distance></DWithin></Filter>&propertyName=STATE\_NAME
I am using the DWithin as above. Just had couple of questions:
1) As I went through some forum posts it seems like it uses the units that
is used in the shapefiles. Is that correct?
2) Can I change the units to be anything I want, like meters, etc? If so how
do I request it?
View this message in context: http://old.nabble.com/DWithin-Units-tp30020477p30020477.html
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
Geoserver-users mailing list
That's correct.
http://jira.codehaus.org/browse/GEOS-937
Andreas.
do I request it?
Andreas Hocevar
OpenGeo - http://opengeo.org/
