Is there a way to configure dxf files in geoserver?
Johan Chaves SaborĂo wrote:
Nope, at the moment it is not possible.
There is a new DXF reader back in Geotools that could be used
on trunk (the current development series, that is, not the
stable one) but so far no one has turned it into a
GeoServer plugin.
GeoServer plugin.
Are you referring to the module existing in
http://svn.codehaus.org/geoserver/trunk/src/community/dxf?
Is this the same module that was talked about in topic
http://old.nabble.com/Dxf-module-extension-to28432374.html#a28433461?
In this topic is said that a DXF datastore could be configured. Or only the
outputFormat DXF is working?
In Geotools trunk I can't see anything about DXF.
Cumps,
Pedro
View this message in context: http://old.nabble.com/DXF-Files-tp28784946p28805486.html
GeoServer plugin.Are you referring to the module existing in
Nope, that is generating DXF out of GeoServer, not allowing
to read one
They are two different things. the output format is used by someone,
but the datastore has never been tried so I have no idea if
it will work or not. It should, but I'm just guessing
https://svn.osgeo.org/geotools/trunk/modules/unsupported/dxf
My bad...I was browsing old repo (http://svn.geotools.org).
I'll try it out!
Thanks!
Pedro
View this message in context: http://old.nabble.com/DXF-Files-tp28784946p28805726.html
My bad...I was browsing old repo (http://svn.geotools.org). I'll try it out!
Cool, I'm looking forward to your findings. Btw, mind, that
module will work only with GeoServer trunk
