Hi
I have tried to deploy the DXF plugin for Geoserver 2.13.1 installed as a windows service but after moving the jar files to the lib folder and restarting the service I am encountering the following error:
HTTP ERROR: 503
Problem accessing /geoserver/. Reason:
Service Unavailable
After removing the files and restarting the service my Geoserver install works again, so I am not sure if there are any known problems with this plugin for the version I am trying to use?
Thanks, Chris
Hi Chris,
maybe there is some library conflict with newer versions. I will check. Can you open a JIRA issue in the meantime?
Thanks
Mauro
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
