[Geoserver-users] ECW, NITF, JP2
I installed all the GDAL extensions, set the environment variables (win7,
GDAL_DATA, PATH) and the Image/IO dlls (in with the GDAL binaries and on the
path).
I see the new options for creating these stores (Except for ECW).
But when I try to add the NITF or JP2 I get this error:
Could not list layers for this store, an error occurred retrieving them:
Incorrect input type!
http://osgeo-org.1560.n6.nabble.com/file/n4532007/CropperCapture[1].jpg
The JP2 is the most reasonable size, but it is 44MB.
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4532007.html
A few questions to better understand your problem:
  • which geoserver are you using?
  • which GDAL native libs did you download?
  • can you run a gdalinfo on your data and report back the output?
  • can you provide us the stack trace of the exception reported by geoserver?
Please, let me know.
Best Regards,
Daniele
path).
http://osgeo-org.1560.n6.nabble.com/file/n4532007/CropperCapture%5B1%5D.jpg
Virtualization & Cloud Management Using Capacity Planning
Cloud computing makes use of virtualization - but cloud computing
also focuses on allowing computing to be delivered as a service.
http://www.accelacomm.com/jaw/sfnl/114/51521223/
Geoserver-users mailing list
Ing. Daniele Romagnoli
Software Engineer
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://it.linkedin.com/in/danieleromagnoli
Hi Yechezkal,
please, make sure to keep the mailing list in the loop so, in case I can’t quickly provide you some help, maybe some other GeoServer user/developer can do that.
I have another question:
Are you running it into a tomcat > 6.0.2x?
In that case, you can see if this link may help you:
http://geo-solutions.blogspot.com/2010/05/fix-geotools-and-geoserver-not-able-to.html
If it doesn’t solve your issue, please let us know.
That said, if you want to serve the JP2 image which doesn’t internally have the georeferencing information, you should also probably consider to put a world file and a prj beside that jp2.
If you are not familiar with these concepts, just let us know.
Best Regards,
Daniele
On Wed, Feb 29, 2012 at 6:06 PM, Gutfreund, Yechezkal <ygutfreund@anonymised.com> wrote:
Hello Daniele,
See answers in order:
  1. Geoserver version 2.1.3
  2. GDAL native libs: gdal1.4.5b-windows32-dlls, geoserver-2.1.3-gdal-plugin
G:\Worlds\BlueMarble Images>gdalinfo blue-world.ecw
ERROR 4: `blue-world.ecw’ not recognised as a supported file format.
GDALOpen failed - 4
2012-02-29 11:00:13,933 INFO [org.geoserver] - Loaded feature type ‘tasmania_cities’, enabled
2012-02-29 11:00:13,934 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
2012-02-29 11:00:13,941 INFO [org.geoserver] - Loaded layer ‘tasmania_cities’
2012-02-29 11:00:13,949 INFO [org.geoserver] - Loaded feature type ‘tasmania_roads’, enabled
2012-02-29 11:00:13,949 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
2012-02-29 11:00:13,956 INFO [org.geoserver] - Loaded layer ‘tasmania_roads’
2012-02-29 11:00:13,964 INFO [org.geoserver] - Loaded feature type ‘tasmania_state_boundaries’, enabled
2012-02-29 11:00:13,965 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
2012-02-29 11:00:13,981 INFO [org.geoserver] - Loaded layer ‘tasmania_state_boundaries’
2012-02-29 11:00:13,990 INFO [org.geoserver] - Loaded feature type ‘tasmania_water_bodies’, enabled
2012-02-29 11:00:13,990 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
2012-02-29 11:00:13,997 INFO [org.geoserver] - Loaded layer ‘tasmania_water_bodies’
2012-02-29 11:00:14,010 INFO [org.geoserver] - Loaded layer group ‘BlueMarbleCountries’
2012-02-29 11:00:14,017 INFO [org.geoserver] - Loaded layer group ‘spearfish’
2012-02-29 11:00:14,037 INFO [org.geoserver] - Loaded layer group ‘tasmania’
2012-02-29 11:00:14,044 INFO [org.geoserver] - Loaded layer group ‘tiger-ny’
2012-02-29 11:00:14,198 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
2012-02-29 11:00:14,239 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2012-02-29 11:00:14,344 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2012-02-29 11:00:14,356 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2012-02-29 11:00:14,409 INFO [storage.DefaultStorageFinder] - **************************************************************************************************************************
2012-02-29 11:00:14,410 INFO [storage.DefaultStorageFinder] - *** Found System environment variable TEMP set to C:\Users\ysg4206\AppData\Local\Temp, using it as the default prefix. ***
2012-02-29 11:00:14,410 INFO [storage.DefaultStorageFinder] - **************************************************************************************************************************
2012-02-29 11:00:14,896 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
2012-02-29 11:00:14,934 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘C:\Users\ysg4206\AppData\Local\Temp\geowebcache’
2012-02-29 11:00:14,943 INFO [config.XMLConfiguration] - Found configuration file in C:\Users\ysg4206\AppData\Local\Temp\geowebcache
2012-02-29 11:00:15,000 INFO [config.XMLConfiguration] - Configuration file validated fine.
2012-02-29 11:00:15,032 INFO [config.XMLConfiguration] - Initializing GridSets from C:\Users\ysg4206\AppData\Local\Temp\geowebcache
2012-02-29 11:00:15,032 INFO [config.XMLConfiguration] - Initializing layers from C:\Users\ysg4206\AppData\Local\Temp\geowebcache
2012-02-29 11:00:15,033 INFO [layer.TileLayerDispatcher] - Configuration C:\Users\ysg4206\AppData\Local\Temp\geowebcache contained no layers.
2012-02-29 11:00:15,110 INFO [storage.EntityStoreBuilder] - Neither disk quota page store’ cache memory percent nor cache size was provided. Defaulting to 25% Heap Size
2012-02-29 11:00:16,284 INFO [storage.BDBQuotaStore] - Berkeley DB JE Disk Quota page store configured at C:\Users\ysg4206\AppData\Local\Temp\geowebcache\diskquota_page_store
2012-02-29 11:00:16,286 INFO [storage.BDBQuotaStore] - Quota Store initialized. Global quota: 0.0 B
2012-02-29 11:00:16,290 INFO [diskquota.ConfigLoader] - Quota config is: C:\Users\ysg4206\AppData\Local\Temp\geowebcache\geowebcache-diskquota.xml
2012-02-29 11:00:16,310 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2012-02-29 11:00:16,310 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2012-02-29 11:00:16,310 INFO [diskquota.DiskQuotaMonitor] - 25 layers attached to global quota 500.0 MB
2012-02-29 11:00:16,326 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2012-02-29 11:00:16,426 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2012-02-29 11:00:16,429 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2012-02-29 11:00:16,435 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2012-02-29 11:00:16,557 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 9 paths
2012-02-29 11:00:16,597 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2012-02-29 11:00:16,597 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2012-02-29 11:00:16,639 INFO [org.geoserver] - GeoServer configuration lock is enabled
2012-02-29 11:07:24,356 INFO [geoserver.web] - Getting list of coverages for saved store file:data/blue-world.ntf
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: Incorrect input type!
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:115)
at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:225)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:509)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:502)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:200)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:91)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:107)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:104)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:71)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:114)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:754)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1539)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:343)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:217)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:279)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:330)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:174)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:828)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:725)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1019)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.lang.IllegalArgumentException: Incorrect input type!
at javax.imageio.ImageReader.setInput(ImageReader.java:307)
at it.geosolutions.imageio.gdalframework.GDALImageReader.setInput(GDALImageReader.java:841)
at javax.imageio.ImageReader.setInput(ImageReader.java:380)
at org.geotools.coverageio.BaseGridCoverage2DReader.(BaseGridCoverage2DReader.java:171)
at org.geotools.coverageio.gdal.BaseGDALGridCoverage2DReader.(BaseGDALGridCoverage2DReader.java:83)
at org.geotools.coverageio.gdal.nitf.NITFReader.(NITFReader.java:65)
at org.geotools.coverageio.gdal.nitf.NITFFormat.getReader(NITFFormat.java:93)
at org.geotools.coverageio.gdal.nitf.NITFFormat.getReader(NITFFormat.java:44)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:988)
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:808)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:82)
… 113 more
2012-02-29 11:11:50,435 INFO [geoserver.web] - Getting list of coverages for saved store file:data/blue-world.jp2
at org.geotools.coverageio.gdal.jp2mrsid.JP2MrSIDReader.(JP2MrSIDReader.java:67)
at org.geotools.coverageio.gdal.jp2mrsid.JP2MrSIDFormat.getReader(JP2MrSIDFormat.java:93)
at org.geotools.coverageio.gdal.jp2mrsid.JP2MrSIDFormat.getReader(JP2MrSIDFormat.java:44)
… 113 more
2012-02-29 11:13:12,897 INFO [geoserver.web] - Getting list of coverages for saved store file:data/blue-world.jp2
… 113 more
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Wednesday, February 29, 2012 11:39 AM
To: Gutfreund, Yechezkal
Subject: Re: [Geoserver-users] ECW, NITF, JP2
2.1.3
Best Regards,
Daniele
path).
Software Engineer
Software Engineer
Hello Daniele,
ERROR 4: `blue-world.ecw' not recognised as a supported file format.
GDALOpen failed - 4
http://osgeo-org.1560.n6.nabble.com/file/n4539805/one.jpg
http://osgeo-org.1560.n6.nabble.com/file/n4539805/two.jpg
'tasmania_cities', enabled
'taz_shapes'
'tasmania_cities'
'tasmania_roads', enabled
'taz_shapes'
2012-02-29 11:00:13,956 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
'tasmania_state_boundaries', enabled
'taz_shapes'
'tasmania_water_bodies', enabled
'taz_shapes'
'BlueMarbleCountries'
'spearfish'
2012-02-29 11:00:14,037 INFO [org.geoserver] - Loaded layer group 'tasmania'
2012-02-29 11:00:14,044 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
2012-02-29 11:00:14,198 INFO [org.geoserver] - Loaded service 'wcs', enabled
2012-02-29 11:00:14,239 INFO [org.geoserver] - Loaded service 'wfs', enabled
2012-02-29 11:00:14,344 INFO [org.geoserver] - Loaded service 'wms', enabled
version 120
geowebcache.xml in 'C:\Users\ysg4206\AppData\Local\Temp\geowebcache'
validated fine.
quota page store' cache memory percent nor cache size was provided.
poller in a background job...
with 9 paths
non-tiling clients.
is enabled
                at
                at
                at
                at
org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.<init>(GeoServerTablePanel.java:502)
                at
org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:200)
                at
org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:91)
                at
org.geoserver.web.data.layer.NewLayerPage$1.<init>(NewLayerPage.java:107)
                at
org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:104)
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
org.geotools.coverageio.BaseGridCoverage2DReader.<init>(BaseGridCoverage2DReader.java:171)
                at
org.geotools.coverageio.gdal.BaseGDALGridCoverage2DReader.<init>(BaseGDALGridCoverage2DReader.java:83)
                at
org.geotools.coverageio.gdal.nitf.NITFReader.<init>(NITFReader.java:65)
                at
                at
                at
                at
                at
                ... 113 more
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
org.geotools.coverageio.gdal.jp2mrsid.JP2MrSIDReader.<init>(JP2MrSIDReader.java:67)
                at
                at
                at
                at
                at
                ... 113 more
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                ... 113 more
'taz_shapes'
'tasmania_cities'
'taz_shapes'
'taz_shapes'
'taz_shapes'
'spearfish'
version 120
validated fine.
with 9 paths
non-tiling clients.
is enabled
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                ... 113 more
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                ... 113 more
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                at
                ... 113 more
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4539805.html
Danielle asked me a few more questions, which I am posting here, and my
If it doesn't solve your issue, please let us know.
That said, if you want to serve the JP2 image which doesn't internally have
I am running: GlassFish Server 3.1.1 not tomcat or apache, and Glassfish is
fine for the work we do (and has a fine http server also).
I have georeferencing data in both TFW and WKT format files <file>.tfw) ,
but I don't see how to provide it when I add a coverage STORE.
TFW
0.004166666667
0.000000000000
0.000000000000
-0.004166666667
-179.997916666667
WKT
GEOGCS["WGS 84",DATUM["wgs_1984",SPHEROID["WGS
1984",6378137,298.257223563],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]
89.997916666667
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4539820.html
Sending again my reply to the list, after reducing the mail size (removing quoted stack trace).
---------- Forwarded message ----------
From: Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Date: Tue, Mar 6, 2012 at 11:49 AM
To: “Gutfreund, Yechezkal” <ygutfreund@anonymised.com>, geoserver-users@lists.sourceforge.net
On Fri, Mar 2, 2012 at 4:46 PM, Gutfreund, Yechezkal <ygutfreund@anonymised.com> wrote:
Hi Danielle.
I follow the mailing group in nabble, so I was not getting updates about your questions, so I did not know how to reply. I have posted my replies there now.
I also posted this reply to your questions:
Danielle asked me a few more questions, which I am posting here, and my replies:
I am running: GlassFish Server 3.1.1 not tomcat or apache, and Glassfish is fine for the work we do (and has a fine http server also).
I have no experience with GlassFish. Hoping someone else in the list have more experience with it and can come back with some more feedbacks.
I have georeferencing data in both TFW and WKT format files .tfw) , but I don’t see how to provide it when I add a coverage STORE.
Supposing your file is blue-world.jp2, you can copy your .tfw as a blue-world.j2w and your wkt file as blue-world.prj (or copy the definition provided at
http://spatialreference.org/ref/epsg/4326/ogcwkt/ into the blue-world.prj).
Then, put these 2 files beside your jp2 file.
That said, when configuring the jp2 store, in case there is not georeferencing embedded within the file, the reader will look for auxiliary information on world file and projection file.
TFW
0.004166666667
0.000000000000
0.000000000000
-0.004166666667
-179.997916666667
WKT
GEOGCS[“WGS 84”,DATUM[“wgs_1984”,SPHEROID[“WGS 1984”,6378137,298.257223563],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0],UNIT[“degree”,0.0174532925199433],AUTHORITY[“EPSG”,“4326”]]
89.997916666667
I have noticed that this TFW reports a different bounding box with respect to the one reported by gdalinfo on your NITF.
Make sure that the georeferencing you will use is compliant with the data. Is your data split into some quadrants?
Daniele
Software Engineer
Thank you Danielle.
I am not convinced the error has anything to do with glassfish, since I get
this problem when trying to create the store (which is using the file://
protocol). I placed the .wkt and .tfw files in the same directory as the JP2
and then tried to create the store. See the screen capture below. One very
odd thing I notice about ECW JP2 and NITF support is that, unlike geoTIFF, I
cannot browse to the directory. I have no idea why that might be happening.
http://osgeo-org.1560.n6.nabble.com/file/n4551489/CropperCapture[1].jpg
http://osgeo-org.1560.n6.nabble.com/file/n4551489/CropperCapture[2].jpg
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4551489.html
On Tue, Mar 6, 2012 at 4:07 PM, DrYSG <ygutfreund@anonymised.com4696…> wrote:
Thank you Danielle.
protocol).
In the past days I have asked to you if you are using tomcat > 6.0.2x since with those tomcats we have encountered the same issue you have when loading GDAL extension.
at javax.imageio.ImageReader.setInput(ImageReader.java:290) at it.geosolutions.imageio.gdalframework.GDALImageReader.setInput(GDALImageReader.java:838)
See http://geo-solutions.blogspot.com/2010/05/fix-geotools-and-geoserver-not-able-to.html.
Not sure how Glassfish works in such a context.
Please, make sure to call them
.prj instead of .wkt
and
.j2w instead of .ftw
Daniele
http://osgeo-org.1560.n6.nabble.com/file/n4551489/CropperCapture%5B1%5D.jpg
http://osgeo-org.1560.n6.nabble.com/file/n4551489/CropperCapture%5B2%5D.jpg
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
Software Engineer
I tried the renames:
and
And I also tried what it said in the blog (but that broke my geoserver, so I
had to move the .jars back to the WEB-INF folder).
Still getting the same error.
2012-03-06 11:44:29,815 INFO [geoserver.web] - Getting list of coverages for
  at
  at
  at
  at
  at
  at
  at
  at org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:104)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 113 more
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4551803.html
Hi Yechezkal,
what do you means with “that broke my geoserver”?
Did you try both the suggestions reported by the glassfish users?
[Redraven](http://www.blogger.com/profile/08556134270893947695) said...
I have tried solution #2 on glassfish.
Anonymous said...
in Glassfish put the jars directly into folder: \glassfish3\glassfish\domains\domain1\lib\
As I said before, I have no experience with glassfish.
If none of the suggested approaches works for you, you can consider trying a geoserver trunk nightly build (which by the way uses imageio-ext-1.1.x series based on GDAL 1.7.3) which forces a plugins scan during the geoserver initialization.
Please, let us know.
Daniele
and
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 113 more
Software Engineer
Thanks Danielle,
The first solution in
is not relevant for Glassfish.
When I tried the second:
/You can move all the JAI and ImageIO jars from GeoServer WEB-INF/lib
directory to Tomcat's shared/lib folder in order to share them between all
the web context in tomcat. This will not leave any memory leak around but in
case you have other applications deployed inside the same Tomcat instance
which contains JAI or ImageIO libraries, you need to remove them as well or
you might get class-loading conflicts./
And then I restarted the Glassfish application service, the entire GeoServer
application was dead, I could not go to the the site:
http://localhost:8080/geoserver/web/ however, other applications hosted by
Glassfish worked.
I was about to make a plea to you to bundle this support (GDAL, ImageIO,
etc.) and support more data types out of the box. I can only see this as a
selling point for how many formats you support, and the configuration and
version issues are a real bear. (I can't believe anyone wants to run WMS on
a tiny box that does not have the disk footprint to handle a GDAL install).
Are you telling me that the nightly builds at:
http://gridlock.opengeo.org/geoserver/2.1.x/ have all the GDAL and ImageIO
stuff built in? specifically, if I replace my WAR file with:
geoserver-2.1.x-latest-war.zip
then I should be able to go and not have to do any path configurations, GDAL
installs, adding Jars for Image IO, etc. as listed on this page:
http://docs.geoserver.org/stable/en/user/data/gdal.html
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4579306.html
please. read below…
On Wed, Mar 14, 2012 at 7:30 PM, DrYSG <ygutfreund@anonymised.com> wrote:
Thanks Danielle,
directory to Tomcat’s shared/lib folder in order to share them between all
Glassfish worked.
version issues are a real bear. (I can’t believe anyone wants to run WMS on
Nope.I was saying a different thing:
  • the error you shown us seems due to some mechanism which deregisters the ImageIO plugins on glassfish (Similarly to what happen with Tomcat > 6.0.2x: then you see “incorrect input type” on the logged exceptions)
  • some weeks ago, Justin has added a line of code to the Geoserver Initialization stuff which forces a scan for the available ImageIO plugins. This solved the issues with Tomcat and probably it could also solve the glassfish issues. It’s a simple change which didn’t changed anything about the GDAL/ImageIO extensions/libraries deployment, therefore you still need to have the native libs and extensions properly installed and configured as before.
    Please, let us know if trying with the latest 2.1.x solves your issue.
Daniele
Software Engineer
Well, very good news.
I grabbed the latest stable build on Monday, and replaced the WAR file. Then
I re-installed the GDAL extension and also the ImageIO files into the GDAL
binaries, and restarted.
    Version 2.1-SNAPSHOT
    Subversion Revision 16838
    Build Date 19-Mar-2012 05:02
    GeoTools Version 2.7-SNAPSHOT (rev 38634)
I can now add to the store (and view in openlayers) both NITF and ECW files.
(the JP2 Kakadu) file is still not working, but that is not a real barrier
for me and I think you said it was missing info (see below).
My only request is that I really like the file browser option that is
available for adding a GeoTiff store, and seems to be missing for ECW and
NITF.
G:\Worlds\BlueMarble Images>gdalinfo.exe blue-world.jp2
Driver: JP2KAK/JPEG-2000 (based on Kakadu)
Files: blue-world.jp2
Size is 21600, 10800
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0,10800.0)
Upper Right (21600.0, 0.0)
Lower Right (21600.0,10800.0)
Center (10800.0, 5400.0)
Band 1 Block=2048x128 Type=Byte, ColorInterp=Red
  Overviews: 10800x5400, 5400x2700, 2700x1350, 1350x675, 675x338
  Image Structure Metadata:
    COMPRESSION=JP2000
Band 2 Block=2048x128 Type=Byte, ColorInterp=Green
    COMPRESSION=JP2000
Band 3 Block=2048x128 Type=Byte, ColorInterp=Blue
    COMPRESSION=JP2000
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-NITF-JP2-tp4532007p4637058.html
