Hi
Can I use a ECW file with geoserver to publish the image?
Any limitation that we need to be aware of?
Thanks
Robert
Durban, SA
Hi
Thanks
Robert
Durban, SA
No not allowed without buying a license from ERDAS, see:
http://n2.nabble.com/ECW-license-changed-td3460720.html
Best regards,
Bart
Hi
Thanks
Robert
Durban, SA
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev_______________________________________________
Geoserver-users mailing list
Yes, you can use ECW files with geoserver.
As far as I know, there are no technical limitations but performance could be an issue when you’re using a lot of small ECWs.
There are some license restrictions. You can check the geoserver docs for more info on that.
Sjoerd
On Wed, Apr 7, 2010 at 10:47 AM, Robert Ford <tf.rockfish@anonymised.com> wrote:
Hi
Thanks
Robert
Durban, SA
Longer answer:
Yes, you can use GeoServer to serve ECW imagery via the GDAL
integration extension. As it has already been pointed out, you need to
have a valid ECW license from ERDAS but this is not related to
GeoServer, it is due to the fact that we are talking about a
proprietary format for which the decoder is not available for free for
server side deployments.
regards,
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
Best regards,
BartHi
Thanks
Robert
Durban, SA
https://lists.sourceforge.net/lists/listinfo/geoserver-users------------------------------------------------------------------------------
Thanks all.
Good and bad, good we can serve : bad we need to get a license (I suppose it will cost a heap).
I have to figure out how we can get away from this issue., well thats my headache now.
On Wed, Apr 7, 2010 at 5:09 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Longer answer:
server side deployments.regards,
Simone.Ing. Simone Giannecchini
Via Carignoni 51
55041 Camaiore (LU)
Italyphone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928http://www.geo-solutions.it
Best regards,
BartHi
Thanks
Robert
Durban, SA
Robert,
unless you want to buy a license of ECW, I see various options:
- convert to a mosaic/pyramid of tiff
- convert to bigtiff (there is still some work needed before
supporting bigtiff with overviews in geoserver/geotools)
- check other wavelet based format costs, mainly I think JPEG 2000.
Ciao,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Thu, Apr 8, 2010 at 9:18 AM, Robert Ford <tf.rockfish@anonymised.com> wrote:
Thanks all.
will cost a heap).
my headache now.Cheers
<simone.giannecchini@anonymised.com> wrote:Longer answer:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
http://twitter.com/simogeo-------------------------------------------------------
> Best regards,
> Bart
>> Hi
>> Thanks
>> Robert
>> Durban, SA
>> Geoserver-users@lists.sourceforge.net
