[Geoserver-users] EHdr / 1.0 problem - geoserver crash
Sorry, but i've no sample data jet
my system:
uname:Linux 2.6.28-15-generic #52-Ubuntu SMP Wed Sep 9 10:49:34 UTC 2009 i686
libc:glibc 2.9 NPTL 2.9
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2009096k(111200k free), swap 5911880k(5892604k free)
vm_info: Java HotSpot(TM) Server VM(14.2-b01) for linux-x86 JRE (1.6.0_16-b01), built on Jul 31 200906:03:51 by "java_re" with gcc 3.2.1-7a (J2SE release)
On Thu, 15 Oct 2009 08:00 PM, Simone Giannecchini wrote:
Ciao Kai,
do you have sample data to share?
Which platform are you working on?
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Thu, Oct 15, 2009 at 3:11 PM, Kai Culemann <kai.culemann@anonymised.com> wrote:
> Hi,
> i'm using the GeoServer 1.7.7
> and i use the EHdr / 1.0- plugin to get a coverage from bsq-files (
> http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?id=2685&pid=2677&topicname=BIL,_BIP,_and_BSQ_raster_files
> adding this coverage works fine, but when i wanna show the coverage in
> OpenLayers, GeoServer crash down with this message:
> 702614 [btpool0-7] INFO /geoserver - Initializing Spring FrameworkServlet
> 'dispatcher'
> # A fatal error has been detected by the Java Runtime Environment:
> # SIGSEGV (0xb) at pc=0xb7e6a896, pid=12886, tid=2423258000
> # JRE version: 6.0_16-b01
> # Java VM: Java HotSpot(TM) Server VM (14.2-b01 mixed mode linux-x86 )
> # Problematic frame:
> # C [libc.so.6+0x79896] memcpy+0x46
> # An error report file with more information is saved as:
> /home/kai/entwicklung/svn_bluecall_software/focus_solar/geoserver/hs_err_pid12886.log
> # If you would like to submit a bug report, please visit:
> # http://java.sun.com/webapps/bugreport/crash.jsp
> # The crash happened outside the Java Virtual Machine in native code.
> # See problematic frame for where to report the bug.
> Aborted
> the hs_err_pid12886.log contains http://pastebin.com/m498e2153
> could anyone tell me, what my problem is or give me an advice or a solution
> to fix it?
> thx :slight_smile:
> Come build with us! The BlackBerry(R) Developer Conference in SF, CA
> is the only developer event you need to attend this year. Jumpstart your
> developing skills, take BlackBerry mobile applications to market and stay
> ahead of the curve. Join us from November 9 - 12, 2009. Register now!
> http://p.sf.net/sfu/devconference
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Any news on the sample data?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Fri, Oct 16, 2009 at 2:10 PM, Kai Culemann <kai.culemann@anonymised.com> wrote:
my system:
i686
free)
vm_info: Java HotSpot(TM) Server VM (14.2-b01) for linux-x86 JRE
(1.6.0_16-b01), built on Jul 31 2009 06:03:51 by "java_re" with gcc 3.2.1-7a
(J2SE release)
Ciao Kai,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
'dispatcher'
Aborted
solution
to fix it?
thx :slight_smile:
