[Geoserver-users] Enable Marlin on Windows
I come from a Windows background and I am trying to enable Marlin to work
with GeoServer on a Windows server.
I am running Tomcat 8.0.9 with the Geoserver WAR deployment.
I created a Marlin subdirectory in the Java directory, downloaded the
Marlin 0.7.1 jar files and copied them to C:\Program Files\Java\Marlin\
I then opened the Tomcat control panel and on the "Startup" tab added
    java -Xbootclasspath/a:C:\Program
Files\Java\Marlin\marlin-0.7.1-Unsafe.jar
to the arguments, above "start", and on the "Java" tab added
    -Dsun.java2d.renderer=org.marlin.pisces.PiscesRenderingEngine
to the end of the Java Options
Restarted Tomcat and checked the log file
    C:\Program Files\Apache Software Foundation\Tomcat
8.0\logs\tomcat8-stderr.2015-11-24.log
Can't find any reference to Marlin in this log.
Where am I going wrong?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Enable-Marlin-on-Windows-tp5238214.html
Not 100% sure but I suspect your problem is a space in the path, try wrapping in quotes or moving it to a different path. Does windows still support the old 8.3 versions of paths?
-----Original Message-----
Sent: 24 November 2015 08:32
Subject: [Geoserver-users] Enable Marlin on Windows
I come from a Windows background and I am trying to enable Marlin to work with GeoServer on a Windows server.
I created a Marlin subdirectory in the Java directory, downloaded the Marlin 0.7.1 jar files and copied them to C:\Program Files\Java\Marlin\ I then opened the Tomcat control panel and on the "Startup" tab added
    C:\Program Files\Apache Software Foundation\Tomcat 8.0\logs\tomcat8-stderr.2015-11-24.log
Go from Idea to Many App Stores Faster with Intel(R) XDK Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741551&iu=/4140
Geoserver-users mailing list
I tried both double and single quotes around the path and then moved the
Marlin directory to the root to eliminate the space in the name.
Still no luck.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Enable-Marlin-on-Windows-tp5238214p5238244.html
Got this working:
https://groups.google.com/forum/?hl=en#!topic/marlin-renderer/PNUcQ0qZfXw
View this message in context: http://osgeo-org.1560.x6.nabble.com/Enable-Marlin-on-Windows-tp5238214p5238558.html
