Hello,
is there a possibility to enable Verbose Logging (VERBOSE_LOGGING) manually or is this logging profile enabled by default? The documentation is a little bit unclear.
How can I get the verbose logging and logging in debug level respectivly?
Best regards,
Toni
Hi Toni,
by default DEFAULT_LOGGING should be enabled.
It seems to me that in 2.4.x you may set it from web interface GLOBAL SETTING section as usual.
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2013/10/31 Toni Müller <tonimueller.unihalle@anonymised.com>
Hello,
Best regards,
Toni
Android is increasing in popularity, but the open development platform that
developers love is also attractive to malware creators. Download this white
paper to learn more about secure code signing practices that can help keep
Android apps secure.
http://pubads.g.doubleclick.net/gampad/clk?id=65839951&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Toni,
In the GeoServer admin page, if you go to the “Global” settings, you’ll see a bunch of settings for logging.
For debug level you’ll want “GEOTOOLS_DEVELOPER_LOGGING”.
There’s a checkbox for verbose logging (don’t actually know what it does!) and you can log to the console (Log to StdOut) too.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 31 October 2013 11:55, Toni Müller <tonimueller.unihalle@anonymised.com> wrote:
Hello,
Best regards,
Toni
On Thu, Oct 31, 2013 at 1:16 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi Toni,
In the GeoServer admin page, if you go to the "Global" settings, you'll
For debug level you'll want "GEOTOOLS_DEVELOPER_LOGGING".
There's a checkbox for verbose logging (don't actually know what it does!)
It's verbose exception reporting, that is, return a full stack trace in the
OGC ServiceException reports, instead of just
a summary of the messages in them
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I was going to update the docs to reflect that, but it seems to already be in there.
Note to self: Read the docs!
Toni: See this page - http://docs.geoserver.org/stable/en/user/webadmin/server/globalsettings.html
Thanks Andrea!
Jonathan
On 31 October 2013 12:56, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Oct 31, 2013 at 1:16 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Toni,
It’s verbose exception reporting, that is, return a full stack trace in the OGC ServiceException reports, instead of just
Ing. Andrea Aime
@geowolf
Technical Lead
