[Geoserver-users] EPSG:900913 vs EPSG:3857
Hi list,
Does GeoServer treat in the same way these two SRS's?
I'm asking this because I'm working on a GeoNode project, which as you know has GeoServer in the back-end, and I'm having some strange issues (deforming labels) with some data that it's in EPSG:3857. GeoExplorer then publishes them as 900913. In theory they're the same but in practice it seem they're not.
Any hints?
Thanks in advance.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda@anonymised.com | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
Hi David,
I can confirm the two are identical, the “reprojection console” in GeoServer is giving me back
the identity transform going from one to the other.
Deformed labels sounds strange… are you using GWC with “full wms” enabled, to serve wms
requests out of cached tiles?
One possible reason for label deformation could be that your requests are not matching up the
cached tiles exactly.
Care to share an example of how the deformed labels look?
On Fri, Feb 12, 2016 at 11:42 AM, David Alda Fernandez de Lezea <dalda@anonymised.com> wrote:
Hi list,
Does GeoServer treat in the same way these two SRS’s?
I’m asking this because I’m working on a GeoNode project, which as you know has GeoServer in the back-end, and I’m having some strange issues (deforming labels) with some data that it’s in EPSG:3857. GeoExplorer then publishes them as 900913. In theory they’re the same but in practice it seem they’re not.
Any hints?
Thanks in advance.
Agur bero bat,
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
To be honest I don't know what the hell is going on but it's driving me crazy...
According to what I've searched on the web and in GeoServer's SRS database there're minor differences but seem to be crucial
This the WKT representation of GeoServer's ESPG:900913
PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
And this is the one in spatial reference (http://spatialreference.org/ref/sr-org/6627/html/ )
PROJCS["Google Mercator",
    GEOGCS["WGS 84",
            SPHEROID["WGS 84",6378137.0,298.257223563,
        PRIMEM["Greenwich",0.0,
        UNIT["degree",0.017453292519943295],
        AXIS["Geodetic latitude",NORTH],
        AXIS["Geodetic longitude",EAST],
    PARAMETER["semi_minor",6378137.0],
    PARAMETER["latitude_of_origin",0.0],
    PARAMETER["central_meridian",0.0],
    PARAMETER["scale_factor",1.0],
    PARAMETER["false_easting",0.0],
    PARAMETER["false_northing",0.0],
    UNIT["m",1.0],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
As you can see in the AXIS part there're two differences.
Well, I've created in the epsg.properties a new entry called 9999 with the data taken from the web spatialreference , set the declared SRS to my custom CRS, set FORCED TO DECLARED and it works!
I don't understand anything...
Thanks.
Agur bero bat,
dalda@...6818... | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
De: andrea.aime@...84... [mailto:andrea.aime@…84…] En nombre de Andrea Aime
Enviado el: viernes, 12 de febrero de 2016 12:14
Para: David Alda Fernandez de Lezea
CC: GeoServer Users
Asunto: Re: [Geoserver-users] EPSG:900913 vs EPSG:3857
Hi David,
I can confirm the two are identical, the "reprojection console" in GeoServer is giving me back
Deformed labels sounds strange... are you using GWC with "full wms" enabled, to serve wms
On Fri, Feb 12, 2016 at 11:42 AM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Hi list,
Any hints?
Thanks in advance.
Agur bero bat,
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Fri, Feb 12, 2016 at 1:07 PM, David Alda Fernandez de Lezea <
crazy...
How about you reply to my questions, instead of showing the WKTs? :slight_smile:
I have made a few, and need an answer to all of them to help.
Ing. Andrea Aime
@geowolf
Technical Lead
Yes, sorry Andrea, I'm testing and testing and I just completely missed your questions.
No, I disabled GWC on those layers to avoid problems.
Yes no problem. I attach them.
Thank you very much.
Agur bero bat,
Enviado el: viernes, 12 de febrero de 2016 13:59
CC: GeoServer Users
On Fri, Feb 12, 2016 at 1:07 PM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Hi David,
something is not adding up… you cannot get two different label representations
due to projection changes, as the geometries get reprojected before painting the
labels, so the label might move, but cannot change the way it looks, the
font, size and so on is the same.
Not sure what’s going on there, could be some caching effect client side?
What if you clean the cache, or use a different browser that never got those tiles?
It would be also good to see the WMS requests, and if you can, the HTTP response
headers.
Also, can you check you’re making requests directly to GeoServer, and not though
some proxy that GeoNode might have setup? (sorry, pretty ignorant about GeoNode).
Speaking of which, which version of GeoServer is that? I believe stable GeoNode
releases are still shipping with a very old (and unsupported) GeoServer version.
On Fri, Feb 12, 2016 at 2:07 PM, David Alda Fernandez de Lezea <dalda@anonymised.com> wrote:
Yes, sorry Andrea, I’m testing and testing and I just completely missed your questions.
Agur bero bat,
De: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] En nombre de Andrea Aime
CC: GeoServer Users
On Fri, Feb 12, 2016 at 1:07 PM, David Alda Fernandez de Lezea dalda@anonymised.com wrote:
To be honest I don’t know what the hell is going on but it’s driving me crazy…
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Thanks for your response. I'll try to harvest all the information you ask me for as soon as possible.
Related with this I'd like to ask about something in GeoServer. When you add WMS cascaded DataStore and add layers from it, apparently there's no way to specify the CRS in which you want to consume the data. I mean, let's say the Remote WMS A serves data in three different CRS's. When I add a layer from it, the Native CRS text box is filled with a value that can't be changed and I can't select which is the Native CRS (can I?). This forces me to probably make a re-projection in cases that perhaps it wouldn't be necessary. Is there a way to set which is the Native CRS apart from editing the XML's?
Thanks in advance.
Agur bero bat,
Enviado el: viernes, 12 de febrero de 2016 14:49
CC: GeoServer Users
Hi David,
something is not adding up... you cannot get two different label representations
Not sure what's going on there, could be some caching effect client side?
headers.
Also, can you check you're making requests directly to GeoServer, and not though
On Fri, Feb 12, 2016 at 2:07 PM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Agur bero bat,
CC: GeoServer Users
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 15, 2016 at 8:24 AM, David Alda Fernandez de Lezea <
Hi Andrea,
the XML's?
The native CRS is internal information that is not published outside of
GeoServer, and it's not used much
by GeoServer either.
You can set it up a "reproject from native to declared", the WMS really
works under a "reproject from native
to requested" in that case, so if the two match, GeoServer should not be
doing any reprojection.
At least in theory... it's been several years since I last looked in that
part of the code, I might be remembering
it wrong.
Try it out and let us know
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea,
But what about selecting which is your native. Geoserver assumes that it is 3857 in my case but the layers can be viewed on:
<CRS>CRS:84</CRS>
<CRS>EPSG:4326</CRS>
<CRS>EPSG:25830</CRS>
<CRS>EPSG:3857</CRS>
<!-- alias 3857 -->
<CRS>EPSG:102100</CRS>
(Taken from the getcapabilites document of the remote service)
So the native selection should be made by the user in my opinion.
If I set Forced to Declared, is GeoServer making a re-projection or it's just using the specified SRS code and passes it to the remote requests?
Thanks.
Agur bero bat,
Enviado el: lunes, 15 de febrero de 2016 9:36
CC: GeoServer Users
On Mon, Feb 15, 2016 at 8:24 AM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Hi Andrea,
The native CRS is internal information that is not published outside of GeoServer, and it's not used much
You can set it up a "reproject from native to declared", the WMS really works under a "reproject from native
to requested" in that case, so if the two match, GeoServer should not be doing any reprojection.
At least in theory... it's been several years since I last looked in that part of the code, I might be remembering
it wrong.
Ing. Andrea Aime
@geowolf
Technical Lead
David,
I believe my previous mail contains an answer to both your questions, please check it again?
About selecting what’s native, that’s not allowed for any data source, I agree making it editable
would make sense for WMS cascasding though, if you feel like implementing such support, or sponsoring it, there is a guide you can follow here:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
On Mon, Feb 15, 2016 at 9:53 AM, David Alda Fernandez de Lezea <dalda@anonymised.com…> wrote:
Andrea,
CRS:84
EPSG:4326
EPSG:25830
EPSG:3857
EPSG:102100
If I set Forced to Declared, is GeoServer making a re-projection or it’s just using the specified SRS code and passes it to the remote requests?
Thanks.
Agur bero bat,
CC: GeoServer Users
On Mon, Feb 15, 2016 at 8:24 AM, David Alda Fernandez de Lezea dalda@anonymised.com wrote:
Hi Andrea,
Thanks for your response. I’ll try to harvest all the information you ask me for as soon as possible.
Related with this I’d like to ask about something in GeoServer. When you add WMS cascaded DataStore and add layers from it, apparently there’s no way to specify the CRS in which you want to consume the data. I mean, let’s say the Remote WMS A serves data in three different CRS’s. When I add a layer from it, the Native CRS text box is filled with a value that can’t be changed and I can’t select which is the Native CRS (can I?). This forces me to probably make a re-projection in cases that perhaps it wouldn’t be necessary. Is there a way to set which is the Native CRS apart from editing the XML’s?
The native CRS is internal information that is not published outside of GeoServer, and it’s not used much
You can set it up a “reproject from native to declared”, the WMS really works under a “reproject from native
to requested” in that case, so if the two match, GeoServer should not be doing any reprojection.
At least in theory… it’s been several years since I last looked in that part of the code, I might be remembering
it wrong.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ok Andrea.
Thanks for your help.
Agur bero bat,
Enviado el: lunes, 15 de febrero de 2016 10:04
CC: GeoServer Users
David,
About selecting what's native, that's not allowed for any data source, I agree making it editable
On Mon, Feb 15, 2016 at 9:53 AM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Andrea,
<CRS>CRS:84</CRS>
<!-- alias 3857 -->
Thanks.
Agur bero bat,
CC: GeoServer Users
Hi Andrea,
it wrong.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
