> Please don't use backslashes in URLs. Forward slashes are reported to work (like this):
> <value>file:/D:/Workspace/shapefiles/VerdeRiverBuffer.shp</value>
Thanks for that suggestion.
However, I had already tried it both ways with no success, and same error, so something else is going on.
Specifics:
Version 2.0.2 from Windows Installer onto Windows XP SP3
default installation, except for change in data directory to path with no spaces
Access as localhost only
JDK 6.16
I have verified that the path to the shapefile is correct by copy-paste into Windows Explorer and browser.
The states shapefile is not corrupted- there is no problem in using it for a simple featuretype layer.
Other perturbations attempted
1. Using GUI (Add new datastore) to create the datastore directory and datastore.xml file (requires the mapping file to be in a separate directory, I use a mappingfiles directory as a sub-directory of the data directory)
2. Completely manual configuration, with the mapping file in the mappingfiles directory, or back in the conventional location under workspaces/...
3. Tried this format for url: file:///C:/GeoServer_2.0.2/data_dir_app-schema/data/shapefiles/states.shp, which is how the browser likes it.
In all cases the error is the same- Below is the log from startup with the completely manual configuration:
By the way, I notice that the prefix "file:" is stripped off in the error message
url=/C:/GeoServer_2.0.2/data_dir_app-schema/data/shapefiles/states.shp
Wondering if that is the source of the difficulty?
2010-07-26 08:09:13,250 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\GeoServer_2.0.2\data_dir_app-schema
2010-07-26 08:09:13,296 INFO [storage.DefaultStorageFinder] - *****************************************************************************************************************************************
2010-07-26 08:09:13,296 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to C:\GeoServer_2.0.2\data_dir_app-schema, using it as the default prefix. ***
2010-07-26 08:09:13,296 INFO [config.XMLConfiguration] - Failed to find geowebcache.xml. This is not a problem unless you are trying to use a custom XML configuration file.
2010-07-26 08:09:13,656 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded style 'line'
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded style 'point'
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded style 'polygon'
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded style 'raster'
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded default workspace gsml
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded workspace 'gsml'
2010-07-26 08:09:13,718 INFO [org.geoserver] - Loaded workspace 'topp_w'
2010-07-26 08:09:13,734 INFO [org.geoserver] - Loaded store 'gsml_GeologicUnit', enabled
2010-07-26 08:09:13,734 INFO [org.geoserver] - Loaded data store 'gsml_GeologicUnit'
2010-07-26 08:09:16,453 INFO [org.geoserver] - Loaded feature type 'GeologicUnit', enabled
2010-07-26 08:09:16,453 INFO [org.geoserver] - Loaded feature type 'gsml_GeologicUnit'
2010-07-26 08:09:16,468 INFO [org.geoserver] - Loaded layer 'GeologicUnit'
2010-07-26 08:09:16,468 INFO [org.geoserver] - Loaded store 'states_shapefile', enabled
2010-07-26 08:09:16,468 INFO [org.geoserver] - Loaded data store 'states_shapefile'
2010-07-26 08:09:16,500 INFO [org.geoserver] - Loaded feature type 'states', enabled
2010-07-26 08:09:16,500 INFO [org.geoserver] - Loaded feature type 'states_shapefile'
2010-07-26 08:09:16,500 INFO [org.geoserver] - Loaded layer 'states'
2010-07-26 08:09:16,515 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
2010-07-26 08:09:16,515 INFO [org.geoserver] - Loaded data store 'taz_shapes'
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded feature type 'tasmania_cities', enabled
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded feature type 'tasmania_roads', enabled
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded store 'topp_StatesUOM_d', enabled
2010-07-26 08:09:16,671 INFO [org.geoserver] - Loaded data store 'topp_StatesUOM_d'
2010-07-26 08:09:16,703 ERROR [complex.config] - Cannot find a DataAccess for parameters {memory mapped buffer=false, create spatial index=true, charset=ISO-8859-1, url=/C:/GeoServer_2.0.2/data_dir_app-schema/data/shapefiles/states.shp}
2010-07-26 08:09:16,703 WARN [org.geoserver] - Error connecting to 'topp_StatesUOM_d'. Disabling.
2010-07-26 08:09:16,703 INFO [org.geoserver] -
org.geotools.data.DataSourceException: Cannot find a DataAccess for parameters (some not shown) {url=/C:/GeoServer_2.0.2/data_dir_app-schema/data/shapefiles/states.shp}
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.aquireSourceDatastores(AppSchemaDataAccessConfigurator.java:564)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:180)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:157)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:93)
at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:96)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:317)
at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:37)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:581)
at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:161)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:132)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
2010-07-26 08:09:16,703 INFO [org.geoserver] - Loaded feature type 'StatesUOM_F', enabled
2010-07-26 08:09:16,765 INFO [org.geoserver] - Loaded feature type 'topp_StatesUOM_d'
2010-07-26 08:09:16,765 INFO [org.geoserver] - Loaded layer 'StatesUOM_F'
2010-07-26 08:09:16,937 INFO [layer.TileLayerDispatcher] - ConfigurationLoader acquired lock, sleeping 5 seconds
2010-07-26 08:09:16,953 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2010-07-26 08:09:16,953 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2010-07-26 08:09:16,953 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2010-07-26 08:09:16,968 INFO [wfs.WFSService] - Configured to forward to http://localhost:8080/geoserver/wfs , timeout is 600000ms regex filter
2010-07-26 08:09:17,031 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 7 paths
2010-07-26 08:09:17,093 INFO [org.geoserver] - Loaded service 'wcs', enabled
2010-07-26 08:09:17,109 INFO [org.geoserver] - Loaded service 'wfs', enabled
2010-07-26 08:09:17,140 INFO [org.geoserver] - Loaded service 'wms', enabled
2010-07-26 08:09:18,937 INFO [layer.TileLayerDispatcher] - ConfigurationLoader woke up, initializing
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding layers from GeoServer Catalog Listener
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding: gsml:GeologicUnit
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding: topp_w:states
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding: topp_w:tasmania_cities
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding: topp_w:tasmania_roads
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding: topp_w:StatesUOM_F
2010-07-26 08:09:19,109 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
2010-07-26 08:09:19,109 INFO [config.XMLConfiguration] - Found configuration file in C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - Adding layers from C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources
2010-07-26 08:09:19,109 ERROR [layer.TileLayerDispatcher] - Configuration C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources contained no layers.
2010-07-26 08:09:19,109 ERROR [layer.TileLayerDispatcher] - Error reading service information from C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources: Error parsing file C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources\geowebcache.xml
2010-07-26 08:09:19,109 INFO [layer.TileLayerDispatcher] - ConfigurationLoader completed
2010-07-26 08:09:43,625 ERROR [complex.config] - Cannot find a DataAccess for parameters {memory mapped buffer=false, create spatial index=true, charset=ISO-8859-1, url=/C:/GeoServer_2.0.2/data_dir_app-schema/data/shapefiles/states.shp}
(From here:)
http://docs.geoserver.org/trunk/en/user/data/app-schema/data-stores.html#shapefile
Kind regards,
Ben.
On 26/07/10 04:44, Tara Athan wrote:
I started with a configuration using a .properties file for the
datastore, and that was working correctly.
Then I changed the mapping file to use a shapefile instead, following
the manual
<sourceDataStores>
<DataStore>
<id>datastore</id>
<parameters>
<Parameter>
<name>url</name>
<value>file:\C:\GeoServer_2.0.2\data_dir_app-schema\data\shapefiles\states.shp</value>
</Parameter>
<Parameter>
<name>memory mapped buffer</name>
<value>false</value>
</Parameter>
<Parameter>
<name>create spatial index</name>
<value>true</value>
</Parameter>
<Parameter>
<name>charset</name>
<value>ISO-8859-1</value>
</Parameter>
</parameters>
</DataStore>
</sourceDataStores>
I assume that the sourceType element also needs to be modified, so I used
<sourceType>states</sourceType>
although I couldn't find specifics for this element in the case of
shapefiles.
When I try to create the datastore, I get this error
Error creating data store, check the parameters. Error message: Cannot
{url=\C:\GeoServer_2.0.2\data_dir_app-schema\data\shapefiles\states.shp}
Any suggestions are appreciated.
Tara
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
Geoserver-users mailing list
Tara Athan
Owner, Athan Ecological Reconciliation Services
tara_athan at alt2is.com
707-272-2115 (cell, preferred)
707-485-1198 (office)
249 W. Gobbi St. #A
Ukiah, CA 95482
