Hello everyone,
I tried to install GeoServer with GDAL extension on Geoservwer, but I am not
ablel to make it run. I Ubuntu 16.4 as operating system. When I run gdalinfo
I receive the following message:
Usage: gdalinfo [--help-general] [-json] [-mm] [-stats] [-hist] [-nogcp]
[-nomd]
[-norat] [-noct] [-nofl] [-checksum] [-proj4]
[-listmdd] [-mdd domain|`all`]*
[-sd subdataset] [-oo NAME=VALUE]* datasetname
FAILURE: No datasource specified.
When I run http://localhost:8080/geoserver/rest/about/status, I get the
following message:
Module name: ImageI/O-Ext GDAL Coverage Extension
Module : gs-gdal
Component : GridCoverage2DReader
Version : 1.1.17
Enabled : true
Available : false
Message : JNI GDAL Wrapper Version: unavailable
java.library.path: /var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/
In SERVER STATUS/Modules I get the following message:
Module Name: ImageI/O-Ext GDAL Coverage Extension
Module ID: gs-gdal
Version: 1.1.17
Component: GridCoverage2DReader
Message:
I tried different solutions, nothing worked. Any tip is very much
appreciated.
Kind regards,
Corina
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-installing-GDAL-tp5328170.html
Hi Corina,
it’s been a week, are you still experiencing the problem?
Some notes inline below.
On Mon, Jul 17, 2017 at 9:35 PM, Corina Tudorache via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
This means the JNI bridge is not available to Tomcat, typically means the GDAL package
we provided was not downloaded, or Tomcat did not receive the updated LD_LIBRARY_PATH.
Did you follow the instructions at http://docs.geoserver.org/latest/en/user/data/raster/gdal.html ?
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I am experiencing this same problem.
(Centos 7, Geoserver 2.11.1, GDAL 1.11.4)
Should I be installing a different (lower?) version of the GDAL package?
Chris
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-installing-GDAL-tp5328170p5330046.html
