[Geoserver-users] ERROR: Operation on mixed SRID geometries
I am working on a web map project with GeoServer 2.4.1, OpenLayers 2.12 and GeoExt.
I’m having some trouble with the OpenLayers.Control.WMSGetFeatureInfo. On certain layers, GeoServer returns “ERROR: Operation on mixed SRID geometries”.
The request from OpenLayers for one of the layers looks like this: http://myserver:8080/geoserver/ows?LAYERS=heartland%3Atraffic_scenario_a&QUERY_LAYERS=heartland%3Atraffic_scenario_a&STYLES=&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=-10721313.983985%2C5029177.270038%2C-10642507.407823%2C5080619.390073&FEATURE_COUNT=3&HEIGHT=673&WIDTH=1031&FORMAT=image%2Fpng&INFO_FORMAT=application%2Fvnd.ogc.gml&X=265&Y=258
The query looks like this:
SELECT count(*) AS gt_result_ FROM (SELECT * FROM “heartland”.“traffic_scenario_a” WHERE (“geom” && ST_GeomFromText(‘POLYGON ((-10701440.356630858 5061280.821917198, -10700675.986348007 5061280.821917198, -10700675.986348007 5060516.45163436, -10701440.356630858 5060516.45163436, -10701440.356630858 5061280.821917198))’, 0) AND ST_Intersects(“geom”, ST_GeomFromText(‘POLYGON ((-10701440.356630858 5061280.821917198, -10700675.986348007 5061280.821917198, -10700675.986348007 5060516.45163436, -10701440.356630858 5060516.45163436, -10701440.356630858 5061280.821917198))’, 0)) AND ((“tot_avg__5” > 0 AND “tot_avg__5” <= 4) OR (“tot_avg__5” > 4 AND “tot_avg__5” <= 5) OR (“tot_avg__5” > 5 AND “tot_avg__5” <= 6) OR (“tot_avg__5” > 6 AND “tot_avg__5” <= 7) OR (“tot_avg__5” > 7 AND “tot_avg__5” <= 8) OR (“tot_avg__5” > 8 AND “tot_avg__5” <= 9) OR (“tot_avg__5” > 9 AND “tot_avg__5” <= 10) OR (“tot_avg__5” > 10 AND “tot_avg__5” <= 20))) LIMIT 3) gt_limited_
As you can see, the SRID in the ST_GeomFromText functions is 0. When I manually change the SRID in the query to 3857 (which is the SRID of the layer), I can run the query successfully. The entry in geometry_columns is correct (3857). It also matches the geom column in my traffic_scenario_a table.
How can I fix this so that GeoServer uses the correct SRID in this query?
Bettina Lechner
blechner@…6560…
On Tue, Jun 3, 2014 at 6:18 PM, Bettina Lechner <blechner@anonymised.com>
and GeoExt.
geometries”.
"heartland"."traffic_scenario_a" WHERE ("geom" && ST_GeomFromText('POLYGON
5061280.821917198))', 0) AND ST_Intersects("geom", ST_GeomFromText('POLYGON
5061280.821917198))', 0)) AND (("tot_avg__5" > 0 AND "tot_avg__5" <= 4) OR
("tot_avg__5" > 4 AND "tot_avg__5" <= 5) OR ("tot_avg__5" > 5 AND
"tot_avg__5" <= 6) OR ("tot_avg__5" > 6 AND "tot_avg__5" <= 7) OR
("tot_avg__5" > 7 AND "tot_avg__5" <= 8) OR ("tot_avg__5" > 8 AND
"tot_avg__5" <= 9) OR ("tot_avg__5" > 9 AND "tot_avg__5" <= 10) OR
("tot_avg__5" > 10 AND "tot_avg__5" <= 20))) LIMIT 3) gt_limited_
table.
That is a PostGIS backend, isn't it? What is the geometry_columns saying
about that table/column?
Also, any possibility you might have even just one geometry in the table
with srid=0?
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Yes, it is PostGIS. Sorry, I forgot to mention that.
Here’s the geometry_columns content for that table:
f_table_catalog
f_table_schema
f_table_name
f_geometry_column
coord_dimension
srid
type
heartland
heartland
traffic_scenario_a
geom
2
3857
MULTIPOLYGON
Running
SELECT DISTINCT(ST_SRID(ST_AsEWKT(geom))) FROM heartland.traffic_scenario_a;
Returns only one row containing 3857.
Thank you!
Bettina
(402) 554-2088
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: Tuesday, June 03, 2014 11:36
To: Bettina Lechner
Subject: Re: [Geoserver-users] ERROR: Operation on mixed SRID geometries
That is a PostGIS backend, isn’t it? What is the geometry_columns saying about that table/column?
Also, any possibility you might have even just one geometry in the table with srid=0?
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jun 3, 2014 at 6:44 PM, Bettina Lechner <blechner@anonymised.com>
f_table_catalog
f_table_schema
f_table_name
f_geometry_column
coord_dimension
srid
type
heartland
heartland
traffic_scenario_a
geom
2
3857
MULTIPOLYGON
Running
Hmm... wondering if it's the GeoServer version, it's pretty old now. Any
chance you can upgrade to 2.5.1?
Ing. Andrea Aime
@geowolf
Technical Lead
I will try that, yes.
On further reflection, I thought of something else that is possibly related:
I use shp2pgsql to import Esri shapefiles into PostGIS. For some reason, when the table is created, the SRID is set to 0. Then I change it to the appropriate one in PostGIS. When I then add it to GeoServer, it doesn’t pick up on that and leaves the “Native SRS” field blank, so I have to use the Declared SRS instead.
Bettina
(402) 554-2088
f_table_catalog
f_table_schema
f_table_name
f_geometry_column
coord_dimension
srid
type
heartland
heartland
traffic_scenario_a
geom
2
3857
MULTIPOLYGON
Running
Hmm… wondering if it’s the GeoServer version, it’s pretty old now. Any chance you can upgrade to 2.5.1?
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jun 3, 2014 at 7:50 PM, Bettina Lechner <blechner@anonymised.com>
related:
When using shp2pgsql it's a good practice to pass the -s parameter (and -I
too) while importing, e.g., if your shapefile
is in WGS84 you'll use:
shp2pgsql -s 4326 -I myshapefile.shp mytable
Ing. Andrea Aime
@geowolf
Technical Lead
