Oh shoot, I've updated the docs before the code is actually released. I
just wrote those, so haven't fine tuned them. Use the shortcut way,
that's also the old way of making a data directory. Just make
C:\geoserver_data_dir\WEB-INF where you put the services.xml and
catalog.xml
and then just copy over the full data/ directory from the webapp to:
C:\geoserver_data_dir\data.
I'll update the docs appropriately, that it's only RC7 and later that
the new way is effective, I think I wasn't counting on anyone actually
reading the new docs until the new version came out, which was sorta
silly.
Chris
Quoting Jeff Gao <gao.jeff@anonymised.com>:
Chris -
Thanks. I tried to setup the data dir by following steps you
suggested:
(1) setup an environment variable GEOSERVER_DATA_DIR on Windows
(2) create a directory in c:\geoserver_data_dir, and make the
variable
pointing to it.
(3) unzip geoserver.war. copy over catalog.xml and services.xml
(4) copy over demo, featureTypes, plugIns, styles and validation
directories.
However, having the data dir setup, when I deployed geoserver.war, I
still got following. Did I missed someting ?
Thanks.
<Nov 28, 2005 8:53:21 AM CST> <Error> <HTTP> <BEA-101046>
<[ServletContext(id=16
556490,name=geoserver,context-path=/geoserver)] action: null
java.lang.NullPointerException
at java.io.File.<init>(File.java:180)
at
org.vfny.geoserver.global.ApplicationState.getXmlTimestamp(Applicatio
nState.java:505)
at
org.vfny.geoserver.global.ApplicationState.init(ApplicationState.java
:96)
at
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServle
t.java:1158)
at
org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
at javax.servlet.GenericServlet.init(GenericServlet.java:258)
at
weblogic.servlet.internal.ServletStubImpl$ServletInitAction.run(Servl
etStubImpl.java:1028)
at
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Authenticate
dSubject.java:321)
at
weblogic.security.service.SecurityManager.runAs(SecurityManager.java:
121)
at
weblogic.servlet.internal.ServletStubImpl.createServlet(ServletStubIm
pl.java:904)
at
weblogic.servlet.internal.ServletStubImpl.createInstances(ServletStub
Impl.java:883)
at
weblogic.servlet.internal.ServletStubImpl.prepareServlet(ServletStubI
mpl.java:822)
at
weblogic.servlet.internal.WebAppServletContext.preloadServlet(WebAppS
ervletContext.java:3333)
at
weblogic.servlet.internal.WebAppServletContext.preloadServlets(WebApp
ServletContext.java:3278)
at
weblogic.servlet.internal.WebAppServletContext.preloadResources(WebAp
pServletContext.java:3259)
at
weblogic.servlet.internal.WebAppServletContext.setStarted(WebAppServl
etContext.java:5949)
at
weblogic.servlet.internal.WebAppModule.start(WebAppModule.java:862)
at
weblogic.j2ee.J2EEApplicationContainer.start(J2EEApplicationContainer
.java:2127)
at
weblogic.j2ee.J2EEApplicationContainer.activate(J2EEApplicationContai
ner.java:2168)
at
weblogic.management.deploy.slave.SlaveDeployer$ComponentActivateTask.
activateContainer(SlaveDeployer.java:2503)
at
weblogic.management.deploy.slave.SlaveDeployer$ActivateTask.doCommit(
SlaveDeployer.java:2421)
at
weblogic.management.deploy.slave.SlaveDeployer$Task.commit(SlaveDeplo
yer.java:2138)
at
weblogic.management.deploy.slave.SlaveDeployer$Task.checkAutoCommit(S
laveDeployer.java:2237)
at
weblogic.management.deploy.slave.SlaveDeployer$Task.prepare(SlaveDepl
oyer.java:2132)
at
weblogic.management.deploy.slave.SlaveDeployer$ActivateTask.prepare(S
laveDeployer.java:2384)
at
weblogic.management.deploy.slave.SlaveDeployer.processPrepareTask(Sla
veDeployer.java:866)
at
weblogic.management.deploy.slave.SlaveDeployer.prepareDelta(SlaveDepl
oyer.java:594)
at
weblogic.management.deploy.slave.SlaveDeployer.prepareUpdate(SlaveDep
loyer.java:508)
at
weblogic.drs.internal.SlaveCallbackHandler$1.execute(SlaveCallbackHan
dler.java:25)
at
weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:219)
at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:178)
<Nov 28, 2005 8:53:21 AM CST> <Error> <HTTP> <BEA-101216> <Servlet:
"action" fai
led to preload on startup in Web application: "geoserver".
javax.servlet.UnavailableException
at
t.java:1169)
at
at
at
dSubject.java:321)
at
121)
at
pl.java:904)
at
Impl.java:883)
at
mpl.java:822)
at
at
at
at
at
at
.java:2127)
at
ner.java:2168)
at
at
at
yer.java:2138)
at
at
oyer.java:2132)
at
at
at
oyer.java:594)
at
loyer.java:508)
at
dler.java:25)
at
On 11/25/05, Chris Holmes <cholmes@anonymised.com> wrote:
> My guess is that weblogic isn't actually exploding the war, so
> like can't actually get a real file or something like that.
> If you can set your servlet container to expand the war, it's
generally
> an option. Or you can define a data directory outside of the war.
I'm
> working on improving this right now, but it should work out ok for
you:
> http://docs.codehaus.org/display/GEOSDOC/GeoServer+Data+Directory
You
> have to set the location of the dataDir someplace, and then you
have to
> set up the data dir. The best way is to probably download the
source
> release (sorry it's so big, that was a mistake), and then copy out
> cite/confUserBasic - which _is_ a data directory, so you just have
to
> point at it. If you have trouble let me know and I can try to zip
one
> up and send it to you.
> best regards,
> Chris
> > Hi all:
> > Please help:
> > When I tried to deploy geoserver-1.3.0-RC3-war to Weblogic 8.1, I
got
> > following errors:
> > log4j:WARN No appenders could be found for logger
> > (org.apache.struts.util.Proper
> > tyMessageResources).
> > log4j:WARN Please initialize the log4j system properly.
> > <Nov 24, 2005 4:31:09 PM CST> <Error> <HTTP> <BEA-101046>
> > <[ServletContext(id=31
> > 472225,name=geoserver,context-path=/geoserver)] action: null
> > at
org.vfny.geoserver.global.GeoserverDataDirectory.getGeoserverDataDire
> > ctory(GeoserverDataDirectory.java:67)
> > at
> > nState.java:514)
> > at
> > :96)
> > at
> > t.java:1158)
> > at
> > at
> > at
> > etStubImpl.java:993)
> > at
> > dSubject.java:317)
> > at
> > 118)
> > at
> > pl.java:869)
> > at
> > Impl.java:848)
> > at
> > mpl.java:787)
> > at
> > ervletContext.java:3252)
> > at
> > ServletContext.java:3197)
> > at
> > pServletContext.java:3174)
> > at
weblogic.servlet.internal.HttpServer.preloadResources(HttpServer.java
> > :688)
> > at
weblogic.servlet.internal.WebService.preloadResources(WebService.java
> > :483)
> > at
weblogic.servlet.internal.ServletInitService.resume(ServletInitServic
> > e.java:30)
> > at
weblogic.t3.srvr.SubsystemManager.resume(SubsystemManager.java:131)
> > at weblogic.t3.srvr.T3Srvr.resume(T3Srvr.java:964)
> > at weblogic.t3.srvr.T3Srvr.run(T3Srvr.java:359)
> > at weblogic.Server.main(Server.java:32)
> > <Nov 24, 2005 4:31:09 PM CST> <Error> <HTTP> <BEA-101216>
<Servlet:
> > "action" fai
> > at
> > t.java:1169)
> > at
> > at
> > at
> > at
> > dSubject.java:317)
> > at
> > 118)
> > at
> > pl.java:869)
> > at
> > Impl.java:848)
> > at
> > mpl.java:787)
> > at
> > at
> > at
> > at
> > :688)
> > at
> > :483)
> > at
> > e.java:30)
> > at
> > thanks in advance
> > Jeff Gao
> > This SF.net email is sponsored by: Splunk Inc. Do you grep
through
> > log files
> > for problems? Stop! Download the new AJAX search engine that
makes
> > searching your log files as easy as surfing the web. DOWNLOAD
> > SPLUNK!
> > http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
> > _______________________________________________
> > Geoserver-users mailing list
> > Geoserver-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
> This mail sent through IMP: https://webmail.limegroup.com/
Jeff Gao
