Environment: Ubuntu 20.04, Tomcat9 and JRE/JDK (openjdk 11) directly from default apt repository.
Geoserver: 2.19.2 running from .war.
I think the first line there says what’s wrong. Would it work better with a different JRE or JDK?
Here’s the stack trace:
2021-10-11 15:46:42,737 ERROR [gce.imagemosaic] - class java.util.Date cannot be cast to class org.geotools.util.DateRange (java.util.Date is in module java.base of loader ‘bootstrap’; org.geotools.util.DateRange is in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @7cbc3762)
java.lang.ClassCastException: class java.util.Date cannot be cast to class org.geotools.util.DateRange (java.util.Date is in module java.base of loader ‘bootstrap’; org.geotools.util.DateRange is in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @7cbc3762)
at org.geotools.gce.imagemosaic.properties.time.TimestampFileNameExtractor.lambda$setProperties$0(TimestampFileNameExtractor.java:97)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655)
at java.base/java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:658)
at org.geotools.gce.imagemosaic.properties.time.TimestampFileNameExtractor.setProperties(TimestampFileNameExtractor.java:95)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateAttributesFromCollectors(ImageMosaicConfigHandler.java:769)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateCatalog(ImageMosaicConfigHandler.java:621)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateConfiguration(ImageMosaicConfigHandler.java:1583)
at org.geotools.gce.imagemosaic.ImageMosaicFileFeatureConsumer$ImageMosaicFileConsumer.handleElement(ImageMosaicFileFeatureConsumer.java:275)
at org.geotools.gce.imagemosaic.ImageMosaicFileFeatureConsumer$ImageMosaicFileConsumer.handleElement(ImageMosaicFileFeatureConsumer.java:136)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.handleElement(ImageMosaicDirectoryWalker.java:169)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.handleFile(ImageMosaicDirectoryWalker.java:99)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:387)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:355)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:121)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:217)
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:531)
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1551)
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:263)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:216)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:584)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:111)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1572)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1517)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:53)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:128)
at com.sun.proxy.$Proxy113.getGridCoverageReader(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:99)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:60)
at org.geoserver.web.wicket.GeoServerDataProvider.getFilteredItems(GeoServerDataProvider.java:190)
at org.geoserver.web.data.layer.NewLayerPageProvider.getFilteredItems(NewLayerPageProvider.java:198)
at org.geoserver.web.wicket.GeoServerDataProvider.size(GeoServerDataProvider.java:208)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:662)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:657)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:236)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:105)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:111)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:110)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSuccessfulSave(CoverageStoreNewPage.java:86)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:71)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:138)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:111)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:218)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1312)
at org.apache.wicket.markup.html.form.Form.process(Form.java:976)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:797)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:174)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:601)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:660)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:122)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:158)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:101)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:688)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:367)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1639)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
2021-10-11 15:46:42,738 WARN [gce.imagemosaic] - Failure occurred while collecting the granules
org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:417)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:388)
2021-10-11 15:46:42,742 INFO [geoserver.web] - Getting list of coverages for saved store file:///data/geoserver-mosaics/rtma_gust
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:///data/geoserver-mosaics/rtma_gust and hints Hints:
EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
REPOSITORY = org.geoserver.catalog.CatalogRepository@…11151…
System defaults:
FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
STYLE_FACTORY = StyleFactoryImpl
COMPARISON_TOLERANCE = 1.0E-8
FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
FORCE_AXIS_ORDER_HONORING = http
GRID_COVERAGE_FACTORY = GridCoverageFactory
TILE_ENCODING = null
LENIENT_DATUM_SHIFT = true
FILTER_FACTORY = FilterFactoryImpl
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:182)
Caused by: java.io.IOException: Failed to create reader from file:///data/geoserver-mosaics/rtma_gust and hints Hints:
REPOSITORY = org.geoserver.catalog.CatalogRepository@anonymised.com.11151…
System defaults:
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1574)
… 140 more
Here are the .properties files in the directory I was trying to add the data source from:
On Mon, Oct 11, 2021 at 5:56 PM Devin Eyre <djeyre3@anonymised.com.84…> wrote:
System defaults:
System defaults:
… 140 more
timeregex.properties (70 Bytes)
indexer.properties (208 Bytes)
datastore.properties (269 Bytes)
I changed logging to verbose, and tried again to add an imagemosaic store, and have attached the log file here. The following line contains the error message:
ERROR [gce.imagemosaic] - class java.util.Date cannot be cast to class org.geotools.util.DateRange (java.util.Date is in module java.base of loader ‘bootstrap’; org.geotools.util.DateRange is in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @49872d67)
java.lang.ClassCastException: class java.util.Date cannot be cast to class org.geotools.util.DateRange (java.util.Date is in module java.base of loader ‘bootstrap’; org.geotools.util.DateRange is in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @49872d67)
On Mon, Oct 11, 2021 at 5:56 PM Devin Eyre <djeyre3@anonymised.com…84…> wrote:
System defaults:
System defaults:
… 140 more
geoserver.log (83.1 KB)
