We have tried Java8 and Java11. If I just make an ImageMosaic with some granules, my generated BrowseImageMosaicStore.properties is the same. I don’t know how to auto generate the datastore.properties file.
Some other errors we will see is:
Why is it trying to create the schema? I just want to connect to it.
22 Apr 12:09:12 ERROR [gce.imagemosaic] - Schema ‘BrowseImageMosaicStore’ already exists
java.lang.IllegalArgumentException: Schema ‘BrowseImageMosaicStore’ already exists
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:731)
at org.geotools.jdbc.JDBCDataStore.createSchema(JDBCDataStore.java:150)
at org.geotools.gce.imagemosaic.catalog.AbstractGTDataStoreGranuleCatalog.createType(AbstractGTDataStoreGranuleCatalog.java:563)
at org.geotools.gce.imagemosaic.catalog.RepositoryDataStoreCatalog.createType(RepositoryDataStoreCatalog.java:40)
This is a bit odd. I am providing the folder containing my properties files as usual.
22 Apr 12:09:12 DEBUG [gce.imagemosaic] - This plugin accepts File, URL or String. The string may describe a File or an URL
org.geotools.data.DataSourceException: This plugin accepts File, URL or String. The string may describe a File or an URL
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:219)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:563)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:104)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1594)
Sent: Saturday, April 22, 2023 3:14 AM
To: Mort, Ashley C RTX <Ashley.C.Mort@…11756…>
Subject: [External] Re: [Geoserver-users] Error while creating store with raster data -image mosaic
Thanks for the detail, the information in screen snap (and the information when a raster cannot be accessed) is not always useful for troubleshooting.
I assume you updated to Java 11, is the com.sun.imageio.plugins.jpeg.JPEGImageReaderSpi still available in Java 11?
What happens if you take a few granules and place them in a folder to generate a new image mosaic? You could compare a newly generated datastore.properties to the one you have been using.
Jody
On Fri, Apr 21, 2023 at 8:41 PM Mort, Ashley C RTX via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
I wanted to provide a little more detail on this question.
We’re working with an ImageMosaic Store that we’ve used successfully with every major GeoServer version from 2.17 - 2.21 but we are having the problems Ashish mentioned on GeoServer 2.22 or 2.23. We configure our Store to index the granules in Postgres using the ImageMosaic configuration files.
[datastore.properties]
StoreName=cite:ImageMosaicPostGIS
[BrowseImageMosaicStore.properties]
ExpandToRGB=false
TypeName=BrowseImageMosaicStore
SuggestedFormat=org.geotools.gce.image.WorldImageFormat
SuggestedSPI=com.sun.imageio.plugins.jpeg.JPEGImageReaderSpi
LevelsNum=1
PathType=ABSOLUTE
Heterogeneous=false
Caching=false
HeterogeneousCRS=false
LocationAttribute=location
Levels=1.2793554128E-4,1.0810019425E-4
CheckAuxiliaryMetadata=false
MosaicCRS=EPSG:404000
[indexer.properties]
Caching=false
AbsolutePath=true
Schema=*the_geom:Polygon,location:String
PropertyCollectors=
From: Jonchhen, Ashish RTX via Geoserver-users <geoserver-users@lists.sourceforge.net>
Sent: Friday, April 21, 2023 3:19 PM
Subject: [External] [Geoserver-users] Error while creating store with raster data -image mosaic
So we are trying to switch to Geoserver 2.22.2 version, but running into following problem while trying to create a store with image mosaic. I tried to test on the 2.21 version, it works on that with our properties. However, on 2.22 and above, it’s the same error I am seeing. Attached are the logs and a screenshot of the UI. Please let me know if you have solution for this. I have seen online that users are having some error while upgrading to the 2.22 and above. Please let me know if you have any question for me. Thank you
Ashish Jonchhen
Software Engineer I
C : +1 620.757.3966
ashish.jonchhen@…11756…
He/Him/His
Raytheon Intelligence & Space
1717 E. Cityline Drive
Richardson, TX 75082
RTX.com | LinkedIn | Twitter | Instagram
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Jody Garnett
