[Geoserver-users] errors in WMS
Hi
I have geoserver (app-schema) 2.1snapshot, but only using simple features for about 9000 points in postgis [EPSG:28355] and am trying to render it via WMS as an overlay in googleMaps.
On more than one occasion I get a tile returning blank (while other tiles render) and this exception
19 May 13:16:34 ERROR [geotools.rendering] -
java.lang.NullPointerException
at org.geotools.geometry.jts.LiteShape2.(LiteShape2.java:157)
at org.geotools.renderer.lite.StreamingRenderer$RenderableFeature.getTransformedShape(StreamingRenderer.java:2621)
at org.geotools.renderer.lite.StreamingRenderer$RenderableFeature.getShape(StreamingRenderer.java:2567)
at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:2055)
at org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:1988)
at org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1882)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1795)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:700)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:468)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:495)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:49)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:761)
Followed by
19 May 13:16:34 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: org.vfny.geoserver.wms.WmsException: Rendering process failed
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:516)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:233)
At different zoom levels – it acts differently.
I will be happy to proved the URL for the WMS (just not on the public mailing list).
I also seem to be getting exceptions on GetFeatureInfo (which I don’t understand):
19 May 13:29:22 ERROR [geoserver.ows] -
java.lang.ClassCastException: org.geoserver.security.decorators.ReadOnlyFeatureCollection cannot be cast to org.geotools.data.simple.SimpleFeatureCollection
at org.vfny.geoserver.wms.responses.featureInfo.HTMLTableFeatureInfoResponse.writeTo(HTMLTableFeatureInfoResponse.java:99)
at org.vfny.geoserver.wms.responses.GetFeatureInfoResponse.writeTo(GetFeatureInfoResponse.java:184)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:61)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:775)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
I have not set any ‘data access rules’ i can see in the gui and don’t know why I am getting this error.
If you have any suggestions – please let me know
Terry,
do you have any null geometries? I had a peek in the code and it looks like a geometry is null; this could be because it is being broken by a transformation, so it might not be caused by null in your input date.
Kind regards,
Ben.
On 19/05/10 13:43, Terry.Rankine@anonymised.com wrote:
Hi
         at org.geotools.geometry.jts.LiteShape2.<init>(LiteShape2.java:157)
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Ben Caradoc-Davies ha scritto:
Terry,
I've committed a fix for a similar issue a couple of days ago.
How old is your build?
If it's still reproducable I would like to have the data set and the
request that makes it fail for further investigation
Andrea Aime
OpenGeo - http://opengeo.org
I can try a rebuild - it's about 3-4 weeks old now?
As for the null-geometries, the DB has a constraint on no-null geoms, and I had a look at the dataset, and its complete.
What order did you want to proceed?
Terry
-----Original Message-----
Sent: Wednesday, 19 May 2010 2:33 PM
To: Caradoc-Davies, Ben (CESRE, Kensington)
Cc: Rankine, Terry (CESRE, Kensington); geoserver-users@anonymised.comet
Subject: Re: [Geoserver-users] [ExternalEmail] errors in WMS
Terry,
Andrea Aime
Check the latest nightly, if that does not fix it, package
the data, style and request :slight_smile:
Andrea Aime
I want to set up a big dataset today for testing purposes (400.000+ features, road system of germany from osm data). If i finish soon enough i can look for null geometries and test a nightly build against it if there are none.
I had some mysterious NPEs 2-3 weeks ago and switched back to 2.0.1. I thought i messed up the code or the datastore myself back then and didn't report the problem.
If you are interested in the results (and a JDWP connection if it's reproduceable?) i can set you up. Otherwise i'll spare myself from setting up another GeoServer instance.
Lennart
Am 19.05.2010 um 08:35 schrieb <Terry.Rankine@anonymised.com> <Terry.Rankine@anonymised.com367...>:
Terry
Cc: Rankine, Terry (CESRE, Kensington); geoserver-users@anonymised.com.net
Terry,
Andrea Aime
Geoserver-users mailing list
Lennart Jütte ha scritto:
Were they NPE or exception related to array index access ones? The
latter have been fixed in nightly builds as well
Andrea Aime
