the documentation for that operation seems a bit off, I open an issue for this:
https://github.com/GeoWebCache/geowebcache/issues/785
As far I can tell this is the correct way of truncating a layer via GWC REST API:
curl -v -u admin:geoserver --request POST
–url http://localhost:8080/geoserver/gwc/rest/masstruncate
–header ‘content-type: text/xml’
–data ‘BASE:LAND’
Anyway, to avoid the error you are getting you need to explicitly use text\xml for the content type.
Hope it helps,
Nuno Oliveira
On Thu, 2019-08-08 at 19:48 +0300, Artem Groznykh wrote:
Hi.
I tried to truncate cache for a layer and to create seeding tasks for a layer (GeoServer 2.15.2 on Windows 7). And I have errors
- Truncate (via /masstruncate)
Request:
POST - http://localhost:8080/geoserver/gwc/rest/masstruncate?requestType=truncateLayer&layer=workspace_name:layergroup_name
Response:
org.geowebcache.rest.exception.RestException 400 BAD_REQUEST: Format extension unknown or not specified: application/json
What does it mean?
In documentation there are no other params
- Seed
Request:
GET - http://localhost:8080/geoserver/gwc/rest/seed/workspace_name:layergroup_name.json
Headers:
{“Content-Type”: “application/json”}
Body:
“name”: “workspace_name:layergroup_name”,
“bounds”: {
“coords”: {“minX”:-111319.49079327358,“minY”:-111325.14286638453,“maxX”:11339882.520180937,“maxY”:8245444.2794010285}
“gridSetId”: “EPSG:900913”,
“zoomStart”: 5,
“zoomStop”: 9,
“type”: “seed”,
“tileFormat”: “image/png8”,
“threadCount”: 4,
“parameters”: {
“entry”: {}
Response:
Chunk [{“name”: “workspace_name:layergroup_name”,“bounds”:{“coords”:{“minX”:-111319.49079327358,“minY”:-111325.14286638453,“maxX”:11339882.520180937,“maxY”:8245444.2794010285}},“gridSetId”:“EPSG:900913”,“zoomStart”:5,“zoomStop”:9,“type”:“truncate”,“threadCount”:2,“format”:“image/png8”,“parameters”:{“entry”:{}}}] is not a valid entry
So, what is the valid entry?
I tried to remove “bounds” and “parameters”, change “gridSetId” to 900913, even to post XML body - nothing changed
Any suggestions?
Thanks in advance
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@anonymised.comsts.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
