[Geoserver-users] Exception from Geoserver
Okay, I am trying to install geoserver as a war into a currently-installed
version of tomcat. The jdk is 1.4.2_04 and tomcat version is 4.1.3. (They
are old, but cannot be upgraded at the moment.)
When attempting to access the geoserver main page, I get:
GeoServer - Exception
The following exception was thrown:
java.lang.NoSuchMethodError:
javax.servlet.ServletResponse.getContentType()Ljava/lang/String;
Any ideas as for what I can look at? Could I be missing some required jar .
. . or am I just foolish for trying to install the current war download
under such an old configuration?
View this message in context: http://www.nabble.com/Exception-from-Geoserver-tp18816684p18816684.html
Which version of GeoServer are you using? Also, can you provide the
full stack trace?
For sure under such a config GeoServer will be slow as a turtle :slight_smile:
aaime wrote:
currently-installed
full stack trace?
The full stack trace is below, it is Geoserver 1.6.4.
I am in a chicken and the egg type situation--IT won't upgrade unless I
prove that I'm I'm doing will solve the problem we have. (And proving it on
my local development box wasn't enough). Nobody really wants to touch this
box--it's one of those servers that is running somehow and everyone is
afraid to touch it. It is a client's box and we don't really have full
control.
If I can get it running and get my google map mashup up, we will almost
definitely find the hours to upgrade the jdk. We are just going to have to
get the configuration right so that we have 2 jdks running side-by-side and
I think that is what they are concerned about.
2008-08-04 12:40:01 StandardWrapperValve[jsp]: Servlet.service() for servlet
jsp threw exception
javax.servlet.ServletException: Filter execution threw an exception
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:188)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:146)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:166)
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:209)
  at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:596)
  at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:433)
  at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:948)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:144)
  at
  at
  at
org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2358)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:133)
  at
  at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:118)
  at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:594)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:116)
  at
  at
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:127)
  at
  at
org.apache.catalina.valves.RequestDumperValve.invoke(RequestDumperValve.java:174)
  at
  at
  at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:152)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
  at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
  at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
  at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683)
  at java.lang.Thread.run(Thread.java:534)
----- Root Cause -----
  at
org.geoserver.filters.AlternativesResponseStream.getStream(AlternativesResponseStream.java:64)
  at
org.geoserver.filters.AlternativesResponseStream.write(AlternativesResponseStream.java:59)
  at sun.nio.cs.StreamEncoder$CharsetSE.writeBytes(StreamEncoder.java:336)
  at sun.nio.cs.StreamEncoder$CharsetSE.implClose(StreamEncoder.java:427)
  at sun.nio.cs.StreamEncoder.close(StreamEncoder.java:160)
  at java.io.OutputStreamWriter.close(OutputStreamWriter.java:222)
  at java.io.PrintWriter.close(PrintWriter.java:137)
  at
org.geoserver.filters.GZIPResponseWrapper.finishResponse(GZIPResponseWrapper.java:52)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
View this message in context: http://www.nabble.com/Exception-from-Geoserver-tp18816684p18817469.html
  at
  at
Ah, it's in the built-in gzip compression filter. The problem
is with Tomcat, we require at least servlet 2.4 specification,
so no less than Tomcat 5.
Good news is, that filter can be disabled. Go into web-inf/web.xml
and remove "GZIP Compression Filter" filter and its associated
filter mapping, then redeploy GeoServer.
Hope this helps
