[Geoserver-users] Exception on Layer Preview
On the advice of the text in Geoserver I posted this as a bug via Jira. After that I got some advice from a user that it would probably have been better posted here, at least first.
For the record, the filed bug is GEOS-6940.
Bear with me, I’m new to Geoserver.
Geoserver 2.6.2, Mac OS X 10.10.2, Tomcat 7.0.56, .war file install.
Short version:
Data: Layer Preview and Data: Layer Groups throw an exception.
Data: Stores and Data: Layers are both empty, even though I’m fairly certain that I put stuff in those.
Data: Workspaces and Data: Styles look as I expect them to.
Here’s a chronology, mostly from memory, of how I got to the current, somewhat stuck, state that I’m in now.
Yesterday afternoon I had loaded a shapefile (of lines representing some roads) as a layer, and could preview it with default styling (all blue lines).
I created a layer group with just that one layer (as a start) and I could preview it.
Then I began trying to figure out how to style it.
I created a new style, using “Copy from existing style” of type “line”. No errors yet, but style isn’t being applied to my layer or layer group (based on changing the default color in the style for a line and that color not showing up in the Layer Preview).
I was trying to figure out how to instruct Geoserver to apply my new style to my layer (or layer group). I think (but I may be wrong) I need to tell the style (in the SLD XML) the layer name that I want it applied to. Trying that, it still didn’t show up with my new color in Layer Preview. But at one point in the process of tinkering with the style, when I tried to save it (like I had done several times before) Geoserver responded that I was no longer logged in. The ability to do other things indicated that I was, in fact, still logged in. Got this same error multiple times when trying to save my new style.
This morning I jumped back in, but on one of the (I think) Data: things on the left the HTTP request just hung. Tried to stop Tomcat politely via shell script, which failed. Finally did a kill -9, and restarted Tomcat.
Now when I hit Data: Layer Preview I’m getting the exception
org.apache.wicket.WicketRuntimeException: Can’t instantiate page using constructor public org.geoserver.web.demo.MapPreviewPage()
After a couple of “Caused by” chunks it comes down to a NPE at at org.geoserver.ows.LocalWorkspaceCatalogFilter.hideResource(LocalWorkspaceCatalogFilter.java:62)
I’m tempted to just wipe out all my data and restart Geoserver to see if problems go away, and I’ll start over, but I’d rather get to the root of this problem than just run away from it.
David
E-Mail to and from me, in connection with the transaction
of public business, is subject to the Wyoming Public Records
Act and may be disclosed to third parties.
