[Geoserver-users] export kmz to use in google maps
I'm using geoserver 2.7.2 and I'm trying export a raster layer to kmz to use
in google maps, but the longitude is flipped and not show correctly
<LatLonBox>
     <north>5.27215562971562</north>
     <south>-33.7515827465927</south>
     <east>-73.990943646787</east>
     <west>-32.3921901638168</west>
     <rotation>0.0</rotation>
</LatLonBox>
Anyone know how to solve this?
Cintia
View this message in context: http://osgeo-org.1560.x6.nabble.com/export-kmz-to-use-in-google-maps-tp5245870.html
Hi Cinthia,
default axis ordering depends on the WFS version, as explained here:
http://docs.geoserver.org/latest/en/user/services/wfs/basics.html#axis-ordering
Long story short, if you want long/lat order, use WFS 1.0.0, if you want lat/long order use WFS 1.1.0 or 2.0.0.
Hope this helps.
On Mon, Jan 18, 2016 at 1:32 PM, cintiafreitas <cintia.cpfreitas@anonymised.com> wrote:
I’m using geoserver 2.7.2 and I’m trying export a raster layer to kmz to use
5.27215562971562 -33.7515827465927 -73.990943646787 -32.3921901638168 0.0
Cintia
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
55054  Massarosa (LU)
fax:     +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Whoops, I replied too fast… I just realized you’re talking about KMZ, so it’s actually WMS:
http://docs.geoserver.org/latest/en/user/services/wms/basics.html#differences-between-wms-versions
http://docs.geoserver.org/latest/en/user/services/wms/basics.html#axis-ordering
Try WMS 1.1.0 if you want long/lat order, WMS 1.3.0 if you want lat/long order.
On Mon, Jan 18, 2016 at 2:59 PM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Hi Cinthia,
Hope this helps.
Cintia
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Stefano, thanks for your help. I'm using WMS 1.1.0, the latitude is ok, but
the longitude is reverse. My bbox is
bbox=-73.990943646787,-33.7515827465927,-32.3921901638168,5.27215562971562
My problem is exactly this:
http://gis.stackexchange.com/questions/173102/longitudes-look-flipped-when-displaying-geoserver-kml-on-google-maps
View this message in context: http://osgeo-org.1560.x6.nabble.com/export-kmz-to-use-in-google-maps-tp5245870p5245896.html
For WMS 1.3.0 I think you will need to specify CRS:84 and not EPSG:4326
-----Original Message-----
From: cintiafreitas [mailto:cintia.cpfreitas@anonymised.com]
Sent: Monday, January 18, 2016 2:15 PM
Subject: Re: [Geoserver-users] export kmz to use in google maps
Stefano, thanks for your help. I'm using WMS 1.1.0, the latitude is ok, but the
Site24x7 APM Insight: Get Deep Visibility into Application Performance APM
+ Mobile APM + RUM: Monitor 3 App instances at just $35/Month Monitor
end-to-end web transactions and take corrective actions now Troubleshoot
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
I put CRS, but didn't work yet.
The value to north and south is ok, but west and east is reverse.
View this message in context: http://osgeo-org.1560.x6.nabble.com/export-kmz-to-use-in-google-maps-tp5245870p5245906.html
This problem can be a bug or did I do something wrong?
View this message in context: http://osgeo-org.1560.x6.nabble.com/export-kmz-to-use-in-google-maps-tp5245870p5246082.html
