Hi List,
I’m seeing some very odd behaviour with external graphics.
The TextSymboliser is this:
road_no
Arial
10
bold
0.5
0.5
0
0
#FFFFFF
image/svg+xml
450
stretch
4
200
500
10
yes
This works fine in Oracle, but when coming from a PostGIS source, it is rendered as as bar:
If I remove the stretch line, it turns into a huge blob (only a small section is shown here - same scale image):
This is GeoServer 2.8.5. I think this may be a regression from 2.7.1. I don’t remember seeing it in the 2.7.1 deployment and it’s pretty obvious (just upgraded to 2.8.5).
I’ve disabled feature simplification, loose bboxes, and
Does anyone have any thoughts/experience with this? It seems odd that the data-store is making a difference to a style.
Jonathan
Hi Jonathan,
your mail seems to imply there were images, but I got none.
In any case, it seems indeed odd that just changing the database results in such a difference, and
cannot think of any reason for this to happen.
I’d go ahead and investigate more, if you find a way to reproduce, open a ticket with the necessary info
(sample data, style and so on) as it might be a good candidate for the monthly bug sprint fixes
On Thu, Sep 1, 2016 at 6:28 PM, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi List,
road_no
Arial
10
bold
0.5
0.5
0
0
#FFFFFF
image/svg+xml
450
stretch
4
200
500
10
yes
Jonathan
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
