[Geoserver-users] Facing issue in external graphic using GeoTools
Hi Team,
We are trying to generate SVG from SLD using external graphic link, but the final output is not what we expect.
For more information please go through below link,
https://stackoverflow.com/questions/71014637/facing-issue-in-external-graphic-using-geotools
You will find the code snippet with input and expected output.
So request you to please help us with the solution.
Thanks in advance.
Aniket Joshi
Contractor
ZS Associates India Pvt. Ltd.
World Trade Center, Tower 3, Kharadi, Pune 411014, Maharashtra, India
www.zs.com
ZS Impact where it matters.
Checking the stackoverflow link, this was more of a geootols user list question … with an example program missing some batik dependencies required to access and draw SVG graphics.
Passing on the response from Aniket Joshi:
This issue is resolved for me. The bug is due to missing library batik-codec and firewall issues for the external links.
Thanks for attempting to help Brad.
Jody Garnett
On Sun, 6 Feb 2022 at 23:58, Aniket Joshi <aniket.joshi@anonymised.com> wrote:
Hi Team,
Thanks in advance.
Aniket Joshi
Contractor
www.zs.com
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
