[Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151
Good Morning,
I’m currently using Geoserver v2.12.0 combined with Java v1.8.141.
Geoserver is running as a windows service though Apache Tomcat v9.0.1
I haven’t had any issues so far until Java gets updated to a minor higher that X.X.141
I then get the error message as displayed in the subject line.
Application updates are managed centrally for obvious reasons.
My server is a 2012 R2 VM running off vSphere.
I have had to revert my VM several times now to get Java back to version 1.8.144 so Geoserver could run.
Because getting into more technical aspect of the problem my question is:
Has anyone experienced issues running Geoserver from the following spec as described below?
Windows 2012 R2 VM
Geoserver 2.12.0
Apache Tomcat 9.0.1
Java 1.8.151
PS: I will go into more details afterwards (i.e. log files (Tomcat/Geoserver), what I’ve done to try to troubleshoot the problem, etc…)
Thanks in advance for taking the time to look into it.
Kind Regards,
Sameer
Sameer,
as you indicate below, the log files, especially full stack traces, are essential to investigate this problem.
Kind regards,
Ben.
On 04/12/17 23:49, Abdool, Sameer wrote:
Good Morning,
I'm currently using Geoserver v2.12.0 combined with Java v1.8.141.
I haven't had any issues so far until Java gets updated to a minor higher that X.X.141
Windows 2012 R2 VM
Geoserver 2.12.0
Apache Tomcat 9.0.1
Java 1.8.151
PS: I will go into more details afterwards (i.e. log files (Tomcat/Geoserver), what I've done to try to troubleshoot the problem, etc...)
Kind Regards,
Sameer
Check out the vibrant tech community on one of the world's most
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
-----Original Message-----
Sent: 05 December 2017 09:34
To: 'Ben Caradoc-Davies'
Subject: RE: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151
Ben,
Thank you for getting back to me.
Please find log files attached.
Sameer
Sent: 04 December 2017 19:18
To: Abdool, Sameer <Sameer.Abdool@...8590...>; 'geoserver-users@lists.sourceforge.net' <geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151
Sameer,
Kind regards,
Ben.
Good Morning,
higher that X.X.141 I then get the error message as displayed in the subject line.
Windows 2012 R2 VM
Geoserver 2.12.0
Apache Tomcat 9.0.1
Java 1.8.151
etc...)
Kind Regards,
Sameer
-------- Check out the vibrant tech community on one of the world's
most engaging tech sites, Slashdot.org! http://sdm.link/slashdot
Ben Caradoc-Davies <ben@...6881...>
Director
Transient Software Limited <http://transient.nz/&gt; New Zealand
________________________
This email was scanned by our anti-virus solution.
geoserver.7z (115 KB)
tomcat.7z (9.01 KB)
Sameer,
it is not a bug: it is a "feature" (of Oracle JDK 8u151):
http://www.oracle.com/technetwork/java/javase/8u151-relnotes-3850493.html
"New Features
security-libs/javax.crypto
  New Security property to control crypto policy
This release introduces a new feature whereby the JCE jurisdiction policy files used by the JDK can be controlled via a new Security property. In older releases, JCE jurisdiction files had to be downloaded and installed separately to allow unlimited cryptography to be used by the JDK. The download and install steps are no longer necessary. To enable unlimited cryptography, one can use the new crypto.policy Security property. If the new Security property (crypto.policy) is set in the java.security file, or has been set dynamically by using the Security.setProperty() call before the JCE framework has been initialized, that setting will be honored. By default, the property will be undefined. If the property is undefined and the legacy JCE jurisdiction files don't exist in the legacy lib/security directory, then the default cryptographic level will remain at 'limited'. To configure the JDK to use unlimited cryptography, set the crypto.policy to a value of 'unlimited'. See the notes in the java.security file shipping with this release for more information."
The evidence that this is your problem can be found in geoserver.log. This is only a WARN so not immediately fatal (GeoServer continues when a data store cannot be loaded). There are several of these:
2017-12-04 10:14:57,078 WARN [org.geoserver] - Failed to load data store 'OS MasterMap'
com.thoughtworks.xstream.converters.ConversionException:
---- Debugging information ----
cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException
cause-message : Encryption raised an exception. A possible cause is you are using strong encryption algorithms and you have not installed the Java Cryptography Extension (JCE) Unlimit
ed Strength Jurisdiction Policy Files in this Java Virtual Machine
class : org.geoserver.catalog.impl.DataStoreInfoImpl
required-type : org.geoserver.catalog.impl.DataStoreInfoImpl
converter-type : org.geoserver.config.util.XStreamPersister$StoreInfoConverter
line number : 39
version : 2.12.0
The ERROR that results in the failure to initialise the geoserver context is caused by the embedded GeoWebCache failing to locate a missing layer (presumably caused by a failure to load a data store supplying the layer):
2017-12-04 10:14:59,733 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcFacade' defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation/Tomcat
%209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/applicationContext.xml]: Cannot resolve reference to bean 'DiskQuotaMonitor' while setting constructor argument; nested exception is
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaMonitor' defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation
/Tomcat%209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Cou
ld not locate a layer or layer group with id LayerGroupInfoImpl--3f96846b:15ebdb05dc8:-7fd2 within GeoServer configuration, the GWC configuration seems to be out of synch
The likely solution is to follow the instructions in the Oracle JDK 8u151 release notes to configure the JDK to use unlimited cryptography.
Kind regards,
Ben.
Ben,
Sameer
From: Ben Caradoc-Davies [mailto:ben@anonymised.com]
To: Abdool, Sameer <Sameer.Abdool@anonymised.com>; 'geoserver-users@lists.sourceforge.net' <geoserver-users@lists.sourceforge.net>
Sameer,
Kind regards,
Ben.
Good Morning,
Windows 2012 R2 VM
Geoserver 2.12.0
Apache Tomcat 9.0.1
Java 1.8.151
etc...)
Kind Regards,
Sameer
Director
Director
New Zealand
Hi Ben,
Thank you very much for the detailed explanation. I was too focused on JCE jurisdiction files replacement at first then diverted onto something else away from the real problem.
Can’t wait to try the fix tomorrow and will of course keep you posted.
By the way I could not find anything about what you mentioned in the Geoserver documentation apart from Java 1.9 incompatibility. Unless I’ve missed something. Maybe worth noting for future reference.
Kind Regards,
Sameer
Get Outlook for Android
Sent: Tuesday, 5 December, 20:16
To: Abdool, Sameer, ‘geoserver-users@lists.sourceforge.net’
Sameer, it is not a bug: it is a “feature” (of Oracle JDK 8u151): http://www.oracle.com/technetwork/java/javase/8u151-relnotes-3850493.html “New Features security-libs/javax.crypto New Security property to control crypto policy This release introduces a new feature whereby the JCE jurisdiction policy files used by the JDK can be controlled via a new Security property. In older releases, JCE jurisdiction files had to be downloaded and installed separately to allow unlimited cryptography to be used by the JDK. The download and install steps are no longer necessary. To enable unlimited cryptography, one can use the new crypto.policy Security property. If the new Security property (crypto.policy) is set in the java.security file, or has been set dynamically by using the Security.setProperty() call before the JCE framework has been initialized, that setting will be honored. By default, the property will be undefined. If the property is undefined and the legacy JCE jurisdiction files don’t exist in the legacy lib/security directory, then the default cryptographic level will remain at ‘limited’. To configure the JDK to use unlimited cryptography, set the crypto.policy to a value of ‘unlimited’. See the notes in the java.security file shipping with this release for more information.” The evidence that this is your problem can be found in geoserver.log. This is only a WARN so not immediately fatal (GeoServer continues when a data store cannot be loaded). There are several of these: 2017-12-04 10:14:57,078 WARN [org.geoserver] - Failed to load data store ‘OS MasterMap’ com.thoughtworks.xstream.converters.ConversionException: ---- Debugging information ---- cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException cause-message : Encryption raised an exception. A possible cause is you are using strong encryption algorithms and you have not installed the Java Cryptography Extension (JCE) Unlimit ed Strength Jurisdiction Policy Files in this Java Virtual Machine class : org.geoserver.catalog.impl.DataStoreInfoImpl required-type : org.geoserver.catalog.impl.DataStoreInfoImpl converter-type : org.geoserver.config.util.XStreamPersister$StoreInfoConverter line number : 39 version : 2.12.0 ------------------------------- The ERROR that results in the failure to initialise the geoserver context is caused by the embedded GeoWebCache failing to locate a missing layer (presumably caused by a failure to load a data store supplying the layer): 2017-12-04 10:14:59,733 ERROR [context.ContextLoader] - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation/Tomcat %209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘DiskQuotaMonitor’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaMonitor’ defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation /Tomcat%209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Cou ld not locate a layer or layer group with id LayerGroupInfoImpl–3f96846b:15ebdb05dc8:-7fd2 within GeoServer configuration, the GWC configuration seems to be out of synch The likely solution is to follow the instructions in the Oracle JDK 8u151 release notes to configure the JDK to use unlimited cryptography. Kind regards, Ben. On 06/12/17 03:11, Abdool, Sameer wrote: > -----Original Message----- > From: Abdool, Sameer > Sent: 05 December 2017 09:34 > To: ‘Ben Caradoc-Davies’ > Subject: RE: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Ben, > > Thank you for getting back to me. > Please find log files attached. > > Regards, > Sameer > > -----Original Message----- > From: Ben Caradoc-Davies [mailto:ben@anonymised.com] > Sent: 04 December 2017 19:18 > To: Abdool, Sameer ; ‘geoserver-users@anonymised.com.sourceforge.net’ > Subject: Re: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Sameer, > > as you indicate below, the log files, especially full stack traces, are essential to investigate this problem. > > Kind regards, > Ben. > > On 04/12/17 23:49, Abdool, Sameer wrote: >> Good Morning, >> >> I’m currently using Geoserver v2.12.0 combined with Java v1.8.141. >> Geoserver is running as a windows service though Apache Tomcat v9.0.1 >> >> I haven’t had any issues so far until Java gets updated to a minor >> higher that X.X.141 I then get the error message as displayed in the subject line. >> >> Application updates are managed centrally for obvious reasons. >> My server is a 2012 R2 VM running off vSphere. >> >> I have had to revert my VM several times now to get Java back to version 1.8.144 so Geoserver could run. >> >> Because getting into more technical aspect of the problem my question is: >> Has anyone experienced issues running Geoserver from the following spec as described below? >> >> Windows 2012 R2 VM >> Geoserver 2.12.0 >> Apache Tomcat 9.0.1 >> Java 1.8.151 >> >> PS: I will go into more details afterwards (i.e. log files >> (Tomcat/Geoserver), what I’ve done to try to troubleshoot the problem, >> etc…) >> >> Thanks in advance for taking the time to look into it. >> >> Kind Regards, >> Sameer >> >> >> >> >> ---------------------------------------------------------------------- >> -------- Check out the vibrant tech community on one of the world’s >> most engaging tech sites, Slashdot.org! http://sdm.link/slashdot >> >> >> >> _______________________________________________ >> Geoserver-users mailing list >> >> Please make sure you read the following two resources before posting to this list: >> - Earning your support instead of buying it, but Ian Turton: >> http://www.ianturton.com/talks/foss4g.html#/ >> - The GeoServer user list posting guidelines: >> http://geoserver.org/comm/userlist-guidelines.html >> >> Geoserver-users@anonymised.comrceforge.net >> https://lists.sourceforge.net/lists/listinfo/geoserver-users >> > > – > Ben Caradoc-Davies > Director > Transient Software Limited New Zealand > > ________________________ > This email was scanned by our anti-virus solution. > > > > ------------------------------------------------------------------------------ > Check out the vibrant tech community on one of the world’s most > engaging tech sites, Slashdot.org! http://sdm.link/slashdot > > > > _______________________________________________ > Geoserver-users mailing list > > Please make sure you read the following two resources before posting to this list: > - Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/ > - The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html > > Geoserver-users@lists.sourceforge.net > https://lists.sourceforge.net/lists/listinfo/geoserver-users > – Ben Caradoc-Davies Director Transient Software Limited New Zealand ________________________ This email was scanned by our anti-virus solution.
Sameer,
the crypto policy change in Oracle JDK 8u151 is new (seven weeks old) and yes, you are right, not yet documented in the GeoServer manual. The new behaviour is supposed to be backwards compatible, so I suspect that your new JDK does not have the policy files installed (breaking your configuration because encrypted resources cannot be unencrypted). Did you install the policy files in your Oracle JDK 8u151?
http://docs.geoserver.org/latest/en/user/production/java.html
The change will not affect OpenJDK, which does not have crypto restrictions.
I will file a Jira issue to update the docs. I look forward to your confirmation that you are able to start GeoServer after changing your crypto.policy setting to unlimited (by uncommenting this line in java.security) or by installing the policy files.
Kind regards,
Ben.
On 06/12/17 09:26, Abdool, Sameer wrote:
Hi Ben,
Can't wait to try the fix tomorrow and will of course keep you posted.
By the way I could not find anything about what you mentioned in the Geoserver documentation apart from Java 1.9 incompatibility. Unless I've missed something. Maybe worth noting for future reference.
Kind Regards,
Sameer
Get Outlook for Android<https://aka.ms/ghei36&gt;
To: Abdool, Sameer, 'geoserver-users@lists.sourceforge.net'
Sameer, it is not a bug: it is a "feature" (of Oracle JDK 8u151): http://www.oracle.com/technetwork/java/javase/8u151-relnotes-3850493.html "New Features security-libs/javax.crypto New Security property to control crypto policy This release introduces a new feature whereby the JCE jurisdiction policy files used by the JDK can be controlled via a new Security property. In older releases, JCE jurisdiction files had to be downloaded and installed separately to allow unlimited cryptography to be used by the JDK. The download and install steps are no longer necessary. To enable unlimited cryptography, one can use the new crypto.policy Security property. If the new Security property (crypto.policy) is set in the java.security file, or has been set dynamically by using the Security.setProperty() call before the JCE framework has been initialized, that setting will be honored. By default, the property will be undefined. If the property is undefined and the legacy JCE jurisdiction files don't exist in the legacy lib/security directory, then the default cryptographic level will remain at 'limited'. To configure the JDK to use unlimited cryptography, set the crypto.policy to a value of 'unlimited'. See the notes in the java.security file shipping with this release for more information." The evidence that this is your problem can be found in geoserver.log. This is only a WARN so not immediately fatal (GeoServer continues when a data store cannot be loaded). There are several of these: 2017-12-04 10:14:57,078 WARN [org.geoserver] - Failed to load data store 'OS MasterMap' com.thoughtworks.xstream.converters.ConversionException: ---- Debugging information ---- cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException cause-message : Encryption raised an exception. A possible cause is you are using strong encryption algorithms and you have not installed the Java Cryptography Extension (JCE) Unlimit ed Strength Jurisdiction Policy Files in this Java Virtual Machine class : org.geoserver.catalog.impl.DataStoreInfoImpl required-type : org.geoserver.catalog.impl.DataStoreInfoImpl converter-type : org.geoserver.config.util.XStreamPersister$StoreInfoConverter line number : 39 version : 2.12.0 ------------------------------- The ERROR that results in the failure to initialise the geoserver context is caused by the embedded GeoWebCache failing to locate a missing layer (presumably caused by a failure to load a data store supplying the layer): 2017-12-04 10:14:59,733 ERROR [context.ContextLoader] - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcFacade' defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation/Tomcat %209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/applicationContext.xml]: Cannot resolve reference to bean 'DiskQuotaMonitor' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaMonitor' defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation /Tomcat%209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Cou ld not locate a layer or layer group with id LayerGroupInfoImpl--3f96846b:15ebdb05dc8:-7fd2 within GeoServer configuration, the GWC configuration seems to be out of synch The likely solution is to follow the instructions in the Oracle JDK 8u151 release notes to configure the JDK to use unlimited cryptography. Kind regards, Ben. On 06/12/17 03:11, Abdool, Sameer wrote: > -----Original Message----- > From: Abdool, Sameer > Sent: 05 December 2017 09:34 > To: 'Ben Caradoc-Davies' > Subject: RE: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Ben, > > Thank you for getting back to me. > Please find log files attached. > > Regards, > Sameer > > -----Original Message----- > From: Ben Caradoc-Davies [mailto:ben@…6881…] > Sent: 04 December 2017 19:18 > To: Abdool, Sameer ; 'geoserver-users@lists.sourceforge.net' > Subject: Re: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Sameer, > > as you indicate below, the log files, especially full stack traces, are essential to investigate this problem. > > Kind regards, > Ben. > > On 04/12/17 23:49, Abdool, Sameer wrote: >> Good Morning, >> >> I'm currently using Geoserver v2.12.0 combined with Java v1.8.141. >> Geoserver is running as a windows service though Apache Tomcat v9.0.1 >> >> I haven't had any issues so far until Java gets updated to a minor >> higher that X.X.141 I then get the error message as displayed in the subject line. >> >> Application updates are managed centrally for obvious reasons. >> My server is a 2012 R2 VM running off vSphere. >> >> I have had to revert my VM several times now to get Java back to version 1.8.144 so Geoserver could run. >> >> Because getting into more technical aspect of the problem my question is: >> Has anyone experienced issues running Geoserver from the following spec as described below? >> >> Windows 2012 R2 VM >> Geoserver 2.12.0 >> Apache Tomcat 9.0.1 >> Java 1.8.151 >> >> PS: I will go into more details afterwards (i.e. log files >> (Tomcat/Geoserver), what I've done to try to troubleshoot the problem, >> etc...) >> >> Thanks in advance for taking the time to look into it. >> >> Kind Regards, >> Sameer >> >> >> >> >> ---------------------------------------------------------------------- >> -------- Check out the vibrant tech community on one of the world's >> most engaging tech sites, Slashdot.org! http://sdm.link/slashdot >> >> >> >> _______________________________________________ >> Geoserver-users mailing list >> >> Please make sure you read the following two resources before posting to this list: >> - Earning your support instead of buying it, but Ian Turton: >> http://www.ianturton.com/talks/foss4g.html#/ >> - The GeoServer user list posting guidelines: >> http://geoserver.org/comm/userlist-guidelines.html >> >> Geoserver-users@lists.sourceforge.net >> https://lists.sourceforge.net/lists/listinfo/geoserver-users >> > > -- > Ben Caradoc-Davies > Director > Transient Software Limited New Zealand > > ________________________ > This email was scanned by our anti-virus solution. > > > > ------------------------------------------------------------------------------ > Check out the vibrant tech community on one of the world's most > engaging tech sites, Slashdot.org! http://sdm.link/slashdot > > > > _______________________________________________ > Geoserver-users mailing list > > Please make sure you read the following two resources before posting to this list: > - Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/ > - The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html > > Geoserver-users@lists.sourceforge.net > https://lists.sourceforge.net/lists/listinfo/geoserver-users > -- Ben Caradoc-Davies Director Transient Software Limited New Zealand ________________________ This email was scanned by our anti-virus solution.
Director
New Zealand
Ben,
I did copy the JCE jar files as previously done but to no avail. I also performed an install of Ju151 as well as Ju144 side by side and assess behaviour so that failed as well. Hence I diverted away from thinking the Java Policy files were at fault.
Downgraded tomcat version to 8.5 and no success still, thinking that maybe tomcat 9.0.1 was not stable enough combined with Ju151 as it’s relying on the jvm.dll
I even gone as far as checking the windows registry settings for Java.
I really tried different approach but did not read the Ju151 release notes about the new security feature nor understood the log entries properly.
I’ll let you know how it goes tomorrow.
Sameer
Sent: Tuesday, 5 December, 21:03
To: Abdool, Sameer
Cc: ‘geoserver-users@lists.sourceforge.net’
Sameer, the crypto policy change in Oracle JDK 8u151 is new (seven weeks old) and yes, you are right, not yet documented in the GeoServer manual. The new behaviour is supposed to be backwards compatible, so I suspect that your new JDK does not have the policy files installed (breaking your configuration because encrypted resources cannot be unencrypted). Did you install the policy files in your Oracle JDK 8u151? http://docs.geoserver.org/latest/en/user/production/java.html The change will not affect OpenJDK, which does not have crypto restrictions. I will file a Jira issue to update the docs. I look forward to your confirmation that you are able to start GeoServer after changing your crypto.policy setting to unlimited (by uncommenting this line in java.security) or by installing the policy files. Kind regards, Ben. On 06/12/17 09:26, Abdool, Sameer wrote: > Hi Ben, > > Thank you very much for the detailed explanation. I was too focused on JCE jurisdiction files replacement at first then diverted onto something else away from the real problem. > > Can’t wait to try the fix tomorrow and will of course keep you posted. > > By the way I could not find anything about what you mentioned in the Geoserver documentation apart from Java 1.9 incompatibility. Unless I’ve missed something. Maybe worth noting for future reference. > > Kind Regards, > Sameer > > Get Outlook for Android > > > > From: Ben Caradoc-Davies > Sent: Tuesday, 5 December, 20:16 > Subject: Re: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > To: Abdool, Sameer, ‘geoserver-users@lists.sourceforge.net’ > > > Sameer, it is not a bug: it is a “feature” (of Oracle JDK 8u151): http://www.oracle.com/technetwork/java/javase/8u151-relnotes-3850493.html “New Features security-libs/javax.crypto New Security property to control crypto policy This release introduces a new feature whereby the JCE jurisdiction policy files used by the JDK can be controlled via a new Security property. In older releases, JCE jurisdiction files had to be downloaded and installed separately to allow unlimited cryptography to be used by the JDK. The download and install steps are no longer necessary. To enable unlimited cryptography, one can use the new crypto.policy Security property. If the new Security property (crypto.policy) is set in the java.security file, or has been set dynamically by using the Security.setProperty() call before the JCE framework has been initialized, that setting will be honored. By default, the property will be undefined. If the property is undefined and the legacy JCE jurisdiction files don’t exist in the legacy lib/security directory, then the default cryptographic level will remain at ‘limited’. To configure the JDK to use unlimited cryptography, set the crypto.policy to a value of ‘unlimited’. See the notes in the java.security file shipping with this release for more information.” The evidence that this is your problem can be found in geoserver.log. This is only a WARN so not immediately fatal (GeoServer continues when a data store cannot be loaded). There are several of these: 2017-12-04 10:14:57,078 WARN [org.geoserver] - Failed to load data store ‘OS MasterMap’ com.thoughtworks.xstream.converters.ConversionException: ---- Debugging information ---- cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException cause-message : Encryption raised an exception. A possible cause is you are using strong encryption algorithms and you have not installed the Java Cryptography Extension (JCE) Unlimit ed Strength Jurisdiction Policy Files in this Java Virtual Machine class : org.geoserver.catalog.impl.DataStoreInfoImpl required-type : org.geoserver.catalog.impl.DataStoreInfoImpl converter-type : org.geoserver.config.util.XStreamPersister$StoreInfoConverter line number : 39 version : 2.12.0 ------------------------------- The ERROR that results in the failure to initialise the geoserver context is caused by the embedded GeoWebCache failing to locate a missing layer (presumably caused by a failure to load a data store supplying the layer): 2017-12-04 10:14:59,733 ERROR [context.ContextLoader] - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation/Tomcat %209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘DiskQuotaMonitor’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaMonitor’ defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation /Tomcat%209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Cou ld not locate a layer or layer group with id LayerGroupInfoImpl–3f96846b:15ebdb05dc8:-7fd2 within GeoServer configuration, the GWC configuration seems to be out of synch The likely solution is to follow the instructions in the Oracle JDK 8u151 release notes to configure the JDK to use unlimited cryptography. Kind regards, Ben. On 06/12/17 03:11, Abdool, Sameer wrote: > -----Original Message----- > From: Abdool, Sameer > Sent: 05 December 2017 09:34 > To: ‘Ben Caradoc-Davies’ > Subject: RE: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Ben, > > Thank you for getting back to me. > Please find log files attached. > > Regards, > Sameer > > -----Original Message----- > From: Ben Caradoc-Davies [mailto:ben@anonymised.com881…] > Sent: 04 December 2017 19:18 > To: Abdool, Sameer ; ‘geoserver-users@lists.sourceforge.net’ > Subject: Re: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Sameer, > > as you indicate below, the log files, especially full stack traces, are essential to investigate this problem. > > Kind regards, > Ben. > > On 04/12/17 23:49, Abdool, Sameer wrote: >> Good Morning, >> >> I’m currently using Geoserver v2.12.0 combined with Java v1.8.141. >> Geoserver is running as a windows service though Apache Tomcat v9.0.1 >> >> I haven’t had any issues so far until Java gets updated to a minor >> higher that X.X.141 I then get the error message as displayed in the subject line. >> >> Application updates are managed centrally for obvious reasons. >> My server is a 2012 R2 VM running off vSphere. >> >> I have had to revert my VM several times now to get Java back to version 1.8.144 so Geoserver could run. >> >> Because getting into more technical aspect of the problem my question is: >> Has anyone experienced issues running Geoserver from the following spec as described below? >> >> Windows 2012 R2 VM >> Geoserver 2.12.0 >> Apache Tomcat 9.0.1 >> Java 1.8.151 >> >> PS: I will go into more details afterwards (i.e. log files >> (Tomcat/Geoserver), what I’ve done to try to troubleshoot the problem, >> etc…) >> >> Thanks in advance for taking the time to look into it. >> >> Kind Regards, >> Sameer >> >> >> >> >> ---------------------------------------------------------------------- >> -------- Check out the vibrant tech community on one of the world’s >> most engaging tech sites, Slashdot.org! http://sdm.link/slashdot >> >> >> >> _______________________________________________ >> Geoserver-users mailing list >> >> Please make sure you read the following two resources before posting to this list: >> - Earning your support instead of buying it, but Ian Turton: >> http://www.ianturton.com/talks/foss4g.html#/ >> - The GeoServer user list posting guidelines: >> http://geoserver.org/comm/userlist-guidelines.html >> >> Geoserver-users@lists.sourceforge.net >> https://lists.sourceforge.net/lists/listinfo/geoserver-users >> > > – > Ben Caradoc-Davies > Director > Transient Software Limited New Zealand > > ________________________ > This email was scanned by our anti-virus solution. > > > > ------------------------------------------------------------------------------ > Check out the vibrant tech community on one of the world’s most > engaging tech sites, Slashdot.org! http://sdm.link/slashdot > > > > _______________________________________________ > Geoserver-users mailing list > > Please make sure you read the following two resources before posting to this list: > - Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/ > - The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html > > Geoserver-users@lists.sourceforge.net > https://lists.sourceforge.net/lists/listinfo/geoserver-users > – Ben Caradoc-Davies Director Transient Software Limited New Zealand ________________________ This email was scanned by our anti-virus solution. > > – Ben Caradoc-Davies Director Transient Software Limited New Zealand ________________________ This email was scanned by our anti-virus solution.
Ben,
I forgot to mention that I’m using JRE rather than the JDK.
I guess that won’t make any difference or will it?
Sameer
Sent: Tuesday, December 5, 2017 9:02:29 PM
To: Abdool, Sameer
Sameer,
Kind regards,
Ben.
Hi Ben,
Kind Regards,
Sameer
Get Outlook for Android<https://aka.ms/ghei36>
Sameer, it is not a bug: it is a “feature” (of Oracle JDK 8u151): http://www.oracle.com/technetwork/java/javase/8u151-relnotes-3850493.html “New Features security-libs/javax.crypto New Security property to control crypto policy This release introduces a new feature whereby the JCE jurisdiction policy files used by the JDK can be controlled via a new Security property. In older releases, JCE jurisdiction files had to be downloaded and installed separately to allow unlimited cryptography to be used by the JDK. The download and install steps are no longer necessary. To enable unlimited cryptography, one can use the new crypto.policy Security property. If the new Security property (crypto.policy) is set in the java.security file, or has been set dynamically by using the Security.setProperty() call before the JCE framework has been initialized, that setting will be honored. By default, the property will be undefined. If the property is undefined and the legacy JCE jurisdiction files don’t exist in the legacy lib/security directory, then the default cryptographic level will remain at ‘limited’. To configure the JDK to use unlimited cryptography, set the crypto.policy to a value of ‘unlimited’. See the notes in the java.security file shipping with this release for more information.” The evidence that this is your problem can be found in geoserver.log. This is only a WARN so not immediately fatal (GeoServer continues when a data store cannot be loaded). There are several of these: 2017-12-04 10:14:57,078 WARN [org.geoserver] - Failed to load data store ‘OS MasterMap’ com.thoughtworks.xstream.converters.ConversionException: ---- Debugging information ---- cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException cause-message : Encryption raised an exception. A possible cause is you are using strong encryption algorithms and you have not installed the Java Cryptography Extension (JCE) Unlimit ed Strength Jurisdiction Policy Files in this Java Virtual Machine class : org.geoserver.catalog.impl.DataStoreInfoImpl required-type : org.geoserver.catalog.impl.DataStoreInfoImpl converter-type : org.geoserver.config.util.XStreamPersister$StoreInfoConverter line number : 39 version : 2.12.0 ------------------------------- The ERROR that results in the failure to initialise the geoserver context is caused by the embedded GeoWebCache failing to locate a missing layer (presumably caused by a failure to load a data store supplying the layer): 2017-12-04 10:14:59,733 ERROR [context.ContextLoader] - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation/Tomcat %209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘DiskQuotaMonitor’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaMonitor’ defined in URL [jar:file:/C:/Program%20Files%20(x86)/Apache%20Software%20Foundation /Tomcat%209.0/webapps/geoserver/WEB-INF/lib/gs-gwc-2.12.0.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Cou ld not locate a layer or layer group with id LayerGroupInfoImpl–3f96846b:15ebdb05dc8:-7fd2 within GeoServer configuration, the GWC configuration seems to be out of synch The likely solution is to follow the instructions in the Oracle JDK 8u151 release notes to configure the JDK to use unlimited cryptography. Kind regards, Ben. On 06/12/17 03:11, Abdool, Sameer wrote: > -----Original Message----- > From: Abdool, Sameer > Sent: 05 December 2017 09:34 > To: ‘Ben Caradoc-Davies’ > Subject: RE: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Ben, > > Thank you for getting back to me. > Please find log files attached. > > Regards, > Sameer > > -----Original Message----- > From: Ben Caradoc-Davies [mailto:ben@anonymised.com] > Sent: 04 December 2017 19:18 > To: Abdool, Sameer ; ‘geoserver-users@anonymised.comnet’ > Subject: Re: [Geoserver-users] FAIL - Application at context path [/geoserver] could not be started - Geoserver v2.12.0 - Java v1.8.151 > > Sameer, > > as you indicate below, the log files, especially full stack traces, are essential to investigate this problem. > > Kind regards, > Ben. > > On 04/12/17 23:49, Abdool, Sameer wrote: >> Good Morning, >> >> I’m currently using Geoserver v2.12.0 combined with Java v1.8.141. >> Geoserver is running as a windows service though Apache Tomcat v9.0.1 >> >> I haven’t had any issues so far until Java gets updated to a minor >> higher that X.X.141 I then get the error message as displayed in the subject line. >> >> Application updates are managed centrally for obvious reasons. >> My server is a 2012 R2 VM running off vSphere. >> >> I have had to revert my VM several times now to get Java back to version 1.8.144 so Geoserver could run. >> >> Because getting into more technical aspect of the problem my question is: >> Has anyone experienced issues running Geoserver from the following spec as described below? >> >> Windows 2012 R2 VM >> Geoserver 2.12.0 >> Apache Tomcat 9.0.1 >> Java 1.8.151 >> >> PS: I will go into more details afterwards (i.e. log files >> (Tomcat/Geoserver), what I’ve done to try to troubleshoot the problem, >> etc…) >> >> Thanks in advance for taking the time to look into it. >> >> Kind Regards, >> Sameer >> >> >> >> >> ---------------------------------------------------------------------- >> -------- Check out the vibrant tech community on one of the world’s >> most engaging tech sites, Slashdot.org! http://sdm.link/slashdot >> >> >> >> _______________________________________________ >> Geoserver-users mailing list >> >> Please make sure you read the following two resources before posting to this list: >> - Earning your support instead of buying it, but Ian Turton: >> http://www.ianturton.com/talks/foss4g.html#/ >> - The GeoServer user list posting guidelines: >> http://geoserver.org/comm/userlist-guidelines.html >> >> Geoserver-users@lists.sourceforge.net >> https://lists.sourceforge.net/lists/listinfo/geoserver-users >> > > – > Ben Caradoc-Davies > Director > Transient Software Limited New Zealand > > ________________________ > This email was scanned by our anti-virus solution. > > > > ------------------------------------------------------------------------------ > Check out the vibrant tech community on one of the world’s most > engaging tech sites, Slashdot.org! http://sdm.link/slashdot > > > > _______________________________________________ > Geoserver-users mailing list > > Please make sure you read the following two resources before posting to this list: > - Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/ > - The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html > > Geoserver-users@anonymised.comsourceforge.net > https://lists.sourceforge.net/lists/listinfo/geoserver-users > – Ben Caradoc-Davies Director Transient Software Limited New Zealand ________________________ This email was scanned by our anti-virus solution.
Ben Caradoc-Davies ben@anonymised.com
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Sameer,
I do not think that should make any difference.
Kind regards,
Ben.
On 06/12/17 10:22, Abdool, Sameer wrote:
Ben,
I forgot to mention that I'm using JRE rather than the JDK.
I guess that won't make any difference or will it?
Sameer
Director
New Zealand
Thank you, Sameer. It is possible that backwards-compatibility (support for policy jars) does not work as documented by Oracle for 8u151 or later. This will be a very important finding for many GeoServer users.
Kind regards,
Ben.
On 06/12/17 10:18, Abdool, Sameer wrote:
Ben,
Downgraded tomcat version to 8.5 and no success still, thinking that maybe tomcat 9.0.1 was not stable enough combined with Ju151 as it's relying on the jvm.dll
I'll let you know how it goes tomorrow.
Sameer
Director
New Zealand
