Hello all. This may have come up before but I did not see a solution. Thank in advance for your help!
I am struggling to add a GeoTiff raster file to Geoserver. After some transformations and adding color to the original GeoTiff (which would also not load) here are the details:
PERMISSIONS:
$ ls outputv2.tif -la
-rw-rw-rw- 1 nvidia nvidia 207210997 Aug 15 13:46 outputv2.tif
GDALINFO:
$ gdalinfo outputv2.tif
Driver: GTiff/GeoTIFF
Files: outputv2.tif
Size is 32410, 21019
Coordinate System is:
PROJCRS[“WGS 84 / Pseudo-Mercator”,
BASEGEOGCRS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
ELLIPSOID[“WGS 84”,6378137,298.257223563,
LENGTHUNIT[“metre”,1]]],
PRIMEM[“Greenwich”,0,
ANGLEUNIT[“degree”,0.0174532925199433]],
ID[“EPSG”,4326]],
CONVERSION[“Popular Visualisation Pseudo-Mercator”,
METHOD[“Popular Visualisation Pseudo Mercator”,
ID[“EPSG”,1024]],
PARAMETER[“Latitude of natural origin”,0,
ANGLEUNIT[“degree”,0.0174532925199433],
ID[“EPSG”,8801]],
PARAMETER[“Longitude of natural origin”,0,
ID[“EPSG”,8802]],
PARAMETER[“False easting”,0,
LENGTHUNIT[“metre”,1],
ID[“EPSG”,8806]],
PARAMETER[“False northing”,0,
ID[“EPSG”,8807]]],
CS[Cartesian,2],
AXIS[“easting (X)”,east,
ORDER[1],
LENGTHUNIT[“metre”,1]],
AXIS[“northing (Y)”,north,
ORDER[2],
USAGE[
SCOPE[“unknown”],
AREA[“World - 85°S to 85°N”],
BBOX[-85.06,-180,85.06,180]],
ID[“EPSG”,3857]]
Data axis to CRS axis mapping: 1,2
Origin = (-20037507.987483192235231,18434491.525901496410370)
Pixel Size = (1236.473576745130231,-1236.511728912020544)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=PACKBITS
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (-20037507.987,18434491.526) (179d59’59.99"W, 83d38’22.73"N)
Lower Left (-20037507.987,-7555748.504) (179d59’59.99"W, 55d59’11.76"S)
Upper Right (20036600.635,18434491.526) (179d59’30.65"E, 83d38’22.73"N)
Lower Right (20036600.635,-7555748.504) (179d59’30.65"E, 55d59’11.76"S)
Center ( -453.676, 5439371.511) ( 0d 0’14.67"W, 43d49’52.66"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Band 4 Block=256x256 Type=Byte, ColorInterp=Alpha
GEOSERVER ERROR LOG:
Caused by: java.io.IOException: Failed to create reader from file:///home/nvidia/Projects/onr/map_layers/GHS_SMOD_POP2015_GLOBE_R2016A_54009_1k_v1_0/outputv2.tif and hints Hints:
REPOSITORY = org.geoserver.catalog.CatalogRepository@anonymised.com
EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
System defaults:
FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
FILTER_FACTORY = FilterFactoryImpl
FORCE_AXIS_ORDER_HONORING = http
LENIENT_DATUM_SHIFT = true
FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
STYLE_FACTORY = StyleFactoryImpl
COMPARISON_TOLERANCE = 1.0E-8
GRID_COVERAGE_FACTORY = GridCoverageFactory
TILE_ENCODING = null
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1492)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1436)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:53)
at jdk.internal.reflect.GeneratedMethodAccessor426.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:127)
at com.sun.proxy.$Proxy35.getGridCoverageReader(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:86)
… 140 more
Constant Marks
Research Assistant | Computer Science and Engineering
University of North Texas
Office: Discovery Parks F216
e: constant.marks@anonymised.com
t: (303) 482 7292
