On Thu, Sep 3, 2015 at 9:53 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Pritimoy,
I see you have installed GDAL 1.11.2.
The current GeoServer versions depend on GDAL 1.9.2. We didn’t test more recent GDAL versions yet so we are not sure they will work fine (potential differences in JNI bindings or functions/methods).
Therefore I would recommend to use that one as indicated in the documentation.
http://docs.geoserver.org/stable/en/user/data/raster/gdal.html#installing-gdal-native-libraries
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.10/native/gdal/linux/
Although we don’t have specific libraries for Ubuntu 14.04, it seems other users successfully get them working:
http://osgeo-org.1560.x6.nabble.com/Problem-about-GDAL-extension-with-Geoserver-2-7-1-td5213994.html
Please, let us know.
Best Regards,
Daniele
On Thu, Sep 3, 2015 at 1:17 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I would double and triple check your binary path and library path.
I wonder if it is worth adding the library path to the geoserver status page for these kind of issues?
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools
in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Jody Garnett
On 2 September 2015 at 15:08, prpp <pritimoy.podder@anonymised.com> wrote:
I’m trying to install the GDAL plugin in Geoserver but failed to do so after
following the steps here
<http://docs.geoserver.org/latest/en/user/data/raster/gdal.html>
Tomcat logs:
WARNING: Failed to load the GDAL native libs. This is not a problem unless
you need to use the GDAL plugins: they won’t be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
I am using;
Ubuntu 14.04.3 LTS
Tomcat7
Geoserver as WAR
GDAL 1.11.2, released 2015/02/10
Geoserver 2.7.2
I copied the jars to the WEB-INF directory on my windows machine and it
works fine.
Thanks in advance.
Pritimoy
View this message in context: http://osgeo-org.1560.x6.nabble.com/Failed-to-load-the-GDAL-native-libs-GDAL-PLUGIN-cannot-be-enabled-tp5222384.html
in one place.
