Now, when I try to connect/download my layers I get the following error message:
version="1.1.1" > <ServiceException>
java.lang.reflect.UndeclaredThrowableExceptionUnable to obtain connection: Cannot create PoolableConnectionFactory (Something unusual has occurred to cause the driver to fail. Please report this exception.)
class org.postgis.PGbox2d
The other type of data (GeoTiff, shapefiles, ...) are working as expected.
Do you have an idea on the reason of such an issue?
Are you running GeoServer in Tomcat using JNDI (in order to share a connection pool). Or are you making each postgis datastore individually?
I do not know of a reason for such an issue so I am expecting that perhaps you have two database drivers loaded that are tripping on each other? It is common to move the postgresql driver from geoserver web application to tomcat libs (to setup a connection pool). If you just ugpraded geoserver perhaps you have two jdbc drivers trying to do the same activity.
in the geoserver logs , you should be able to find the complete stack trace, of which this is only a part. Can you paste that here?
There is a suspicious class org.postgis.PGbox2d in there. Maybe the postgres server has also been upgraded, and the postgis extension is missing?
You have some kind of class loader conflict, e.g. 2 different postgres jdbc drivers. For tomcat: Can you tell which files postgresql*.* exist under tomcat/lib and under tomcat/webapps/geoserver/WEB-INF/lib . There should be only 1.
Van: Nicolas De Ville De Goyet <ndeville@…10529…> Verzonden: dinsdag 7 februari 2023 15:09 Aan: GeoServer Mailing List List geoserver-users@lists.sourceforge.net Onderwerp: [Geoserver-users] Failing Postgis store when upgrading geoserver to 2.22.1
Dear,
I upgraded my geoserver instance to 2.22.1 and it created issues with
all my postgis stores.
message:
version=“1.1.1” >
The other type of data (GeoTiff, shapefiles, …) are working as expected.
Many thanks for your help,
Nicolas de Ville
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
You nailed it properly both of you. There was a conflict between two postgres jdbc drivers.
One was under tomcat/lib and a new one was added under tomcat/webapps/geoserver/WEB-INF/lib when I made the upgrade.
Again thank you for your help, it would have taken me ages to find that…
Have a good evening,
Nicolas
On 7/02/23 19:20, Hans Yperman wrote:
I see a few ways forward:
Van: Nicolas De Ville De Goyet ndeville@anonymised.com Verzonden: dinsdag 7 februari 2023 15:09 Aan: GeoServer Mailing List List geoserver-users@lists.sourceforge.net Onderwerp: [Geoserver-users] Failing Postgis store when upgrading geoserver to 2.22.1
Dear,
message:
version=“1.1.1” >
Nicolas de Ville
