On Wed, Feb 8, 2017 at 1:58 PM, admire <admire@anonymised.com> wrote:
Hi
How can I configure my mosaic with a footprint shapefile using the REST
API.
1) How can I post my footprint shapefile to my data store using rest ?
There is no way, you have to add the footprints in the mosaic directly.
2) Are there any tools or commands using the REST API to generate
footprints shapefile or I need to use gdal
I'd use GDAL. Mind, with recent versions of GeoServer you can also
embed the footprints as binary masks in the TIFF files directly (GDAL mask
bands)...
assuming that your rasters are TIFFs, of course, otherwise the vector
footprints
are the only way as far as I know.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
