Yeah anyway, AKWangChas the me, what’s the this oranges? and that’s my(the) sign
d1grfy39ztai4o.cloudfront.net/sites/default/files/images/membership/benefits/acp-email-sig-master-rgb.png
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4WvVpxjs39JiWs0DlQpEDVPkVE8zWQ_yXGWqg_yEb6vXZ24BowbRPs17KvXc9aKbwA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4R628Y5kGJdc_10NW9GpxbnhgdGNZ5xMbT1jQXXNPJtTfWjtvy3ThXWoYVLCI27w4w2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4cCq_IplesTWlVAxoy-Qwa-HNYukWA6f5lglWxqhjzsLN40nJWtXRp7PtdrYsRjrJA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4VkVFopYiUkfc_mv8OKLoAoR909AjIzeIUx9625jzV_yoXv6146rjwe1lJJVLk5wLw2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4R84IGhhWCaLLvo-yKkiNIzGZKZJrKlz1iH2RqD8QWbQLyiBBx7HsvfqPFv1KM9HYw2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4btk7hYWQg1z2kX5nceTBeZl0CLQkuqczRh2CGMVyUH-4i4SvXVCXqKsa-Sqund4EA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4bKB9i5JcPA7K-SjEXcuPVVVrXzaRGTMZefhtJAvGOh_zYa1TCmaxzxu3qmE3tiZUg2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4accNHXz-lYTJ0NRgvdwv3rDVqRv_U1pjJYM7_07_QhiIWx0Zp-n-gfXbi5Y0t6Lfw2
https://membersuite.aala.org.au/Sys/Profile/PhotoGallery/43401/0/226431?memberId=57474101&dh=24&cppr=0
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4XveGEGMqpC9PNldWuG5ANmeZvBlYhDALnTvm6iu4LT-ulT1E8T_YB2KqDhbT4JycA2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4SzN0476R5hPkVEPdTqOAxxFFbFR4EgPlN7QOlUJPjATmSA-zBgdW12y7WlxWjYZ8w2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4UDQ-nLw95DqsZJ7pTPY6Aq0i-7l-_Su8wILhkl6AgsfQLe5fdN8OQsPzD4bPp9EWQ2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4bXgChfdh9AR9OAygHxsGgXdxfZCPNqwdaL_9of_lRbiPcTwkJMRd4ZG-CCW7Ewh4Q2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4amezH8y5IVXnoHqq2yY0mfBMRVjI6PXuWJyGoPinVNxhy_JWn2aLpz1HmrHwA3EeQ2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4dwBgTDB2jyXS_kePhssCzESNnQRrQh_sjZzo2sVjCwAg5zg-ZiqKieioz_Uog545Q2
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4SqvOZfWLrRfNy_78c_wIcXrn5ZuRQpiM2nx_mNeBfUcYciShWD06cT2fO6wCY_MkA2
https:royalairforcesassociation.my.site.comcommunitysmy-details ID:00597651
https://membersuite.aala.org.au/resources/photo/uTljNHN_T9II2VPclRSi4eNGxo-iDlx56HJskPvqiCgSwf09BXS9R6u9s_iz4HlVFpFNCS2VqbU4CKumISoOHA2
在 2024年4月24日 星期三 下午10:11:28 [GMT+8], Peter Smythegs@anonymised.com 寫道:
Hi Brent
Like the others say, this problem should not be happening, and it is the first time that I am encountering it. Perhaps it has something to do with the way that you installed it. Could you provide those details (OS, Java version, application server, bin/war/docker, any extensions installed, etc.) - best would be opening an issue on https://osgeo-org.atlassian.net/jira/software/c/projects/GEOS/boards/8 so that we can track this - and perhaps you would like to install GeoServer in a different way (or maybe on a different server) to see if you can reproduce the problem? I can recommend https://github.com/geoserver/docker as a proven working solution for you to continue with.
Peter
GeoServer PSC
AWS Solutions Architect
https://github.com/petersmythe
On Wed, 24 Apr 2024 at 14:33, Brent Wood <pcreso@anonymised.com> wrote:
Is there a (simple) way to set Geoserver up to use the MultithreadedHttpClient as default instead of HTTPClient?
That would seem to fix the issue for me, before any bug fixes are implemented.
Brent
It sounds like we (GeoTools) should accept text/xml
especially when requesting getCapabilities documents. But I’m really not sure 403 is the correct response to not accepting the right content type.
Ian
On Mon, 22 Apr 2024 at 14:03, Peter Smythe <gs@anonymised.com839…> wrote:
With access to Brent’s GeoServer, I have managed to reproduce this problem, and it appears to be a combination of GeoTools HTTPClient (not MultithreadedHttpClient) and the GEBCO MapServer not allowing HTTP Header “accept”: “text/html, image/gif, image/jpeg, *; q=.2, /; q=.2” for some reason.
To reproduce:
In Postman, GET https://wms.gebco.net/mapserv?REQUEST=GETCAPABILITIES&VERSION=1.3.0&SERVICE=WMS works fine, until the Accept header is changed from the default / to text/html, image/gif, image/jpeg, *; q=.2, /; q=.2
Returns 403 Unauthorised
This Accept header appears to only be sent by GeoTools HTTPClient and is not sent by the GeoTools MultithreadedHttpClient, which is what I had on by default, when the cascaded WMS worked for me on my GeoServer (previous email):
(in GeoServer New WMS Connection)
Is this a GeoTools bug? Or GeoServer?
And then under what circumstances would the WMS data store fall back to the Simple HTTPClient rather than using the MultithreadedHttpClient (HTTP connection pooling), even if the above is ticked?
Peter
GeoServer PSC
On Sun, 21 Apr 2024 at 15:19, Peter Smythe <gs@anonymised.com> wrote:
Maybe try again, it works for me from GeoServer v2.25.0:
Peter
GeoServer PSC
On Sun, 21 Apr 2024 at 00:50, Brent Wood via Geoserver-users <geoserver-users@anonymised.com.sourceforge.net> wrote:
I’m looking to install geoserver on a ship.
I’d like to use the GEBCO WMS service to provide a background map layer, but cache it locally to avoid internet traffic.
The capabilities doc is at:
The layer I wish to provide is: GEBCO_LATEST_SUB_ICE_TOPO
I can connect & get the capabilities doc in a browser. I can select & open the layer in QGIS.
When I try to set up a WMS store in Geoserver I enter the required parameters, but get told the connection test to the URL failed with error 403.
I understand this means the Gebco server is refusing to reply with the doc. I’m not sure why the URL works from a browser but fails when sent from Geoserver, any suggestions appreciated, as far as I know it is an identical request, from the same host.
Brent Wood.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
