Hi
I have created a custom content template for a GS layer and would like to have the layer title above a list of results. I am using ${type.name} as used in the examples and that works fine.
I thought that ${type.title} might work - just throws a java error saying that type.title is undefined. Do I need to define something elsewhere, or am I just using the wrong code?
Thanks
Chris
On Thu, May 8, 2014 at 8:33 AM, Chris Jackson <webturtles@anonymised.com> wrote:
Hi
Here is what you have in the object model given to the template, title is
not part of it:
http://docs.geoserver.org/stable/en/user/tutorials/freemarker.htm
To modify the object model given to the template some java programming
would be needed,
I can give you references to the classes involved if you are interested
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea
I suppose the quick win is to start off with a better name and use something like ${type.name?replace(?capitalize} I guess!
I can see benefits to having access to both layer title and abstract in the freemarker templates, one for the future perhaps?
Chris
Hi
Here is what you have in the object model given to the template, title is not part of it:
To modify the object model given to the template some java programming would be needed,
Ing. Andrea Aime
@geowolf
Technical Lead
