Since GetFeatureInfo is published using Freemarker template it would be nice to have at least possibility to edit header.ftl, content.ftl, and footer.ftl online trough GeoServer GUI. Editor would put template file in feature type folder. This would be rather powerful feature since it would enable GeoServer user to edit templates just like they edit styles for feature. Otherwise administrator who has access to file system has to put templates on the right position. It would also be nice if editor could have a syntax check, but plain text editor would be just fine.
I think it would be nice to have such editor, indeed. The issue is probably just finding developer time to do it.
Is it something you’d like to develop yourself?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I had written a draft for such an editor 2 years ago. Alas, I didn’t publish it soon enough (busy time, then lazy-time, then next time I tried, it didn’t work with latest GS release) and now it needs some refreshing to work with last geoserver version.
It’s still on my todolist to refresh this extension, but i’m a bit busy, so it might not happen before summer.
I think it worked for version 2.9 of geoserver. I can provide the code as-is, if you want.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Dear Andrea and Jean,
I hope to see Freemarker template editor on wish list. I understand it is a serious work for someone who is skillful enough. I have identified the pain and need for it and hope it will be recognized by some institution or company who are willing to adequately support this kind of development. As I understood Jean has a skills but not enough time for it. So I hope there is going to happen a “win win” situation by institution who will support it and Jaen who can deliver it.
