[Geoserver-users] Freemarker templates
Hi andrea,
the reason why it does not work in my application is the following. I use
mapbender 2.5 and when there are more layer requestable the request does not
use the header.ftl and the footer.ftl.
I placing them into \data_dir\featureTypes and it works for all layer but
only if ther is only one layer requestable.
is it a problem in mapbender?
Greeting Thomas
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet: Dienstag, 28. Oktober 2008 10:38
An: Janßen, Thomas
Betreff: Re: [Geoserver-users] Freemarker templates
Janßen, Thomas ha scritto:
I have writen a header.ftl and a footer.ftl. I have copied it into
\data_dir\featureTypes\TEST\ and it works fine.
but now i want to use the files for all layers.
into which folder must i copy the header.ftl and the footer.ftl?
Just move them up one level, placing them into \data_dir\featureTypes
Andrea Aime
OpenGeo - http://opengeo.org
Hi andrea,
use the header.ftl and the footer.ftl. I placing them into \data_dir\featureTypes and it works for all layer but
I have no idea since I never used mapbender. If the functionality works
fine in the GeoServer preview you can probably assume it's an issue
with MapBender. (click on the map and see the result appear below it, provided you're not using 1.6.5 that has a bug in
that respect, try out GeoServer 1.7.0 in that case)
Andrea Aime
Hi Thomas,
from the mapbender side, this is true: mapbender collects all
layernames that shall be queried for one wms and sends one
getfeatureinfo request. The question is, whether your header / footer
should surround all layer results once or surround each layers result?
You could also consider adding an enhancement ticket with mapbender to
support layerwise getFI requests.
Haven't used templates with geoserver, but what about symlinks in each
FT directory? Could that work?
Cheers, Michael
2008/10/28 Andrea Aime <aaime@anonymised.com>:
Hi andrea,
Andrea Aime
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Michael Schulz
mschulz@anonymised.com
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Unless I am interpreting wrong it sounds like the issue is that GeoServer is not loading the template when multiple layers are selected in a GetFeatureInfo, and one of the layers does not have a template attached to it? Sounds like it might be an issue on our side?
Justin Deoliveira
