Hi Simone,
Thanks for the pointer. Though the issue is not resolved but I've a workaround now. I shared the filestore with 'Everyone' granting read/write permissions and configured the WorldImage stores using UNC path of the shared folder.
Thanks everyone for replying
Thanks & Regards,
Samyajit Talukdar
-----Original Message-----
From: simboss1@anonymised.com [mailto:simboss1@anonymised.com] On Behalf Of Simone Giannecchini
Sent: 19 June 2014 10:30
To: Samyajit Talukdar
Cc: Jody Garnett; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Geo Server 2.1.0 WorldImage store not able to access mapped drive
Ciao Samyajit,
as I suggested, this is usually a permission problem of the account GeoServer is using to run.
Make sure it can interact with remotely mapped drives (this is not the case for System Accounts in Windows afair)
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Jun 19, 2014 at 11:15 AM, Samyajit Talukdar <Samyajit.Talukdar@anonymised.com582...> wrote:
Thanks for your reply. Sorry about the company footer. It gets
automatically attached en route to the recipient.
I understand this is an old version but immediate update is not on the
cards.
I tried opening up the images in fire fox and pasting the url. This
did not help.
Thanks
Samyajit
From: Jody Garnett [mailto:jody.garnett@anonymised.com]
Sent: 19 June 2014 09:22
That is an older copy of GeoServer, we find (and fix) issues with
windows filenames fairly often. This has gotten a lot better recently
thanks to the generation donation of a windows build box
Try using a browser such as fire fox to determine the URL to your
world image file - and then cut and paste that into the configuration
screen. It could be that world+image is fine with your remote file
server, but the file browser is unable to browse it.
(you may also wish to remove your company Privileged/Confidential
information footer when posting a question on a public email list such
as this).
Jody
Jody Garnett
On Thu, Jun 19, 2014 at 5:33 PM, Samyajit Talukdar
<Samyajit.Talukdar@anonymised.com> wrote:
I have an installation of Geo Server 2.1.0 deployed as an application
on Oracle Weblogic Managed Server. I need to configure a WorldImage
store. The World Image files are stored in folder(WPM_Images) on a
remote file server running on Windows 2008 R2. The folder has been
shared and mapped as Network Map Drive(W) on the box where the
Weblogic Managed Server is hosted. The images can be accessed as
W:\*.PNG. However, when the WorldImage store is configured, the W
drive is not visible from the browse function. Does Geo Sever 2.1.0
support mapped drive or do I need to use UNC path? Any help would be greatly appreciated.
Thanks & Regards
Samyajit Talukdar
Privileged/Confidential information may be contained in this Email
and any files transmitted with it. If you are not the intended
recipient you should not retain, copy or use this Email for any
purpose or disclose all or part of its contents to any person. If you
have received this Email in error please notify the postmaster and
sender immediately and delete this Email from your system.
Opinions, conclusions and other information in this message that do
not relate to the official business of Scottish Water ("SW"),
Scottish Water Solutions Ltd ("SWS") or Scottish Water Solutions 2
Ltd ("SWS2") shall be understood as neither given nor endorsed by
them. The contents of Emails sent and received by SW, SWS and SWS2 are monitored.
WARNING: Although SW, SWS and SWS2 have taken reasonable precautions
to ensure no viruses or other malicious software are present, SW, SWS
and SWS2 cannot accept responsibility for any loss or damage arising
from the use of this Email or attachments however caused. The
recipient should therefore check this Email and any attachments for
the presence of viruses or other malicious software.
Scottish Water
www.scottishwater.co.uk
www.scottishwatersolutions.co.uk
postmaster@anonymised.com
--------- HPCC Systems Open Source Big Data Platform from LexisNexis
Risk Solutions Find What Matters Most in Your Big Data with HPCC
Systems Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
