[Geoserver-users] GeoCSS: isometric
Hi there,
Trying to figure out how to get the geometric filter functions working in GeoCSS with GeoServer 2.8.2… Have come across
{geometry: offset[(geom,10,-10)];}
and tried
{geometry: isometric[geom,10];}
The resulting SLD simply shows a straightforward PolygonSymbolizer without any Geometry functions. Any suggestions welcome!
Kind regards,
Edward
On Tue, Feb 9, 2016 at 8:34 PM, Edward Mac Gillavry <
emacgillavry@anonymised.com> wrote:
Hi there,
GeoCSS with GeoServer 2.8.2... Have come across
and tried
Err... I don't remember square parenthesis in the syntax... have you tried:
{geometry: isometric(geom,10);}
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea,
Here’s the examples showing square brackets:
OpenStreetMap Philippines
http://gis.stackexchange.com/a/102847
David Winslow
http://sourceforge.net/p/geoserver/mailman/message/27357107/
Without brackets didn’t work either:
  • {geometry: isometric(geom,10); fill: #000;}
Somehow, the word ‘geometry’ shows up in red in the editor too…?
Edward
Date: Tue, 9 Feb 2016 21:29:29 +0100
Subject: Re: [Geoserver-users] GeoCSS: isometric
To: emacgillavry@anonymised.com
CC: geoserver-users@lists.sourceforge.net
On Tue, Feb 9, 2016 at 8:34 PM, Edward Mac Gillavry <emacgillavry@anonymised.com> wrote:
Hi there,
and tried
Err… I don’t remember square parenthesis in the syntax… have you tried:
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, not fully awake, of course, square brackets to use an expression:
  • {geometry: [isometric(geom, 10)]; }
On Tue, Feb 9, 2016 at 9:40 PM, Edward Mac Gillavry <emacgillavry@anonymised.com> wrote:
Andrea,
David Winslow
Edward
Hi there,
and tried
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea,
Now that we have the proper GeoCSS syntax, the CSS plugin for GeoServer 2.8.2 is not generating an equivalent SLD…
  • {geometry: [isometric(geom, 10)]; fill: #000; }
gives me:
sld:NamedLayer
sld:NameDefault Styler</sld:Name>
sld:UserStyle
sld:FeatureTypeStyle
sld:Rule
sld:PolygonSymbolizer
sld:Fill
<sld:CssParameter name=“fill”>#000000</sld:CssParameter>
</sld:Fill>
</sld:PolygonSymbolizer>
sld:Fill
<sld:CssParameter name=“fill”>#330000</sld:CssParameter>
</sld:Fill>
</sld:Rule>
<sld:VendorOption name=“ruleEvaluation”>first</sld:VendorOption>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
No filter functions… Any clues?
Thanks in advance.
Edward
Date: Tue, 9 Feb 2016 21:50:03 +0100
Andrea,
David Winslow
Edward
Hi there,
and tried
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
