[Geoserver-users] GeoFence updates
From the State of GeoServer talk, I saw that the internal-to-GeoServer version of GeoFence has received a number of improvements. Is the external web-app version of GeoFence still intended to be supported as well going forward?
I'm curious since managing the access separate from administering GeoServer seems like a good use case. That said, if there's a way to set up 'GeoFence admins' in GeoServer and avoid issues like https://github.com/geoserver/geofence/issues/9 (securing the GeoFence REST api), I'd be all ears.
Jim
Based on the README.md here https://github.com/geoserver/geofence the architecture of GeoFence is setup to maintain both standalone and embedded…
Jody Garnett
On Thu, 25 Apr 2019 at 14:38, Jim Hughes <jhughes@anonymised.com> wrote:
well going forward?
I’m curious since managing the access separate from administering
GeoServer seems like a good use case. That said, if there’s a way to
set up ‘GeoFence admins’ in GeoServer and avoid issues like
REST api), I’d be all ears.
Jim
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
