[Geoserver-users] Geometry column
Can anyone help answer my query below? Thanks a lot.
Wai See
-----Original Message-----
Sent: Monday, September 25, 2006 2:37 PM
To: 'Chris Holmes'
Cc: 'geoserver-users@lists.sourceforge.net'
Subject: RE: [Geoserver-users] Geometry column
Thanks for the replies. Suppose we keep the geometry column, how does it
compare in terms of performance between these two: sending a request to
GeoServer to update the feature geometry vs having our application access
PostGreSQL directly and call PostGIS functions to update the geometry
column?
Thanks.
Wai See
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: Sunday, September 24, 2006 10:22 PM
To: leewse@anonymised.com
Subject: Re: [Geoserver-users] Geometry column
You're actually probably wanting the 'geometryless' module, if you're
wanting to get geometries just from coordinates. It's a part of
geotools, but we're not shipping it with GeoServer yet. So if you look
at that code, you can find a jdbc datastore that just reads coordinates
from x and y columns.
best regards,
Chris
leewse@anonymised.com wrote:
Hi Ivan,
Thanks for reply. Please bear with me, but could you please elaborate on
these two points?
1.
it only needs
to know what GeoServer can offer.
2.
and if you want to draw map from plain coordinates you can export
postgres table to shape file.
Thanks a lot.
Wai See
Postgres/Postgis is only one of the sources GeoServer accepts. Thats
the nice thing with geoserver, your map doesnt need to know about
geometry column or postgres or about geoserver sources, it only needs
hope i helped
regards!
On 9/21/06, Lee Wai See <leewse@anonymised.com> wrote:
Our team has some questions which we hope GeoServer can help us with.
We are currently using PostgreSQL with PostGIS, and PostGIS stores the
geometries in a geometry column. Please correct me if I am wrong, but is
this only specific to PostGreSQL with PostGIS? In other words, if we
were to
change the database we want to use, can GeoServer still function without
this geometry column?
2. Then how would my map knows what to draw without the geometry
column?
Is it possible to draw a feature just from plain coordinates?
Lee Wai See
  [This e-mail is confidential and may be priviledged. If you are not
the
intended recipient, please kindly notify us immediately and delete the
message
from your system; please do not copy or use it for any purpose, nor
disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.4/449 - Release Date:
9/15/2006
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Ivan Grcic
National IT coordinator
Iaeste Croatia
Email: ivan.grcic@anonymised.com
Tel: +385 98 567 457
your
!DSPAM:1003,45129245234807785049143!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
No virus found in this incoming message.
Version: 7.1.405 / Virus Database: 268.12.8/455 - Release Date: 9/22/2006
Version: 7.1.405 / Virus Database: 268.12.9/457 - Release Date: 9/26/2006
Hi Lee,
Accessing PostgreSQL/PostGIS directly should be faster then going
through GeoServer first. If you have application that works well with
accessing/updating PostGIS directly you may as well continue to do it
like that. GeoServer should be used then to publish your data trough
some of services it offers!
regards,
Ivan
On 9/27/06, Lee Wai See <leewse@anonymised.com> wrote:
Wai See
To: 'Chris Holmes'
column?
Thanks.
Wai See
Holmes
best regards,
Chris
> Hi Ivan,
> these two points?
> 1.
>> it only needs
> 2.
> Thanks a lot.
> Regards,
> Wai See
>> hope i helped
>> regards!
>>> Hi,
>>> were to
>>> column?
>>> Regards,
>>> Lee Wai See
>>> the
>>> message
>>> disclose
>>> 9/15/2006
>>> your
>>> _______________________________________________
>>> Geoserver-users@lists.sourceforge.net
>>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
>> Ivan Grcic
>> Iaeste Croatia
your
Chris Holmes
Ivan Grcic
Iaeste Croatia
I am still at very begining with using the GeoServer, so still havent
tried to use WFS-T features. And I think there isn't many applications
that support it. I still have to research that area :slight_smile:
But I think that both ways (direct access to PostgreSQL and WFS-T)
should work fine, allthough I think that direct access is a bit
faster, especially for large amount of features.
Hi Ivan,
Thanks for the reply. But what would be the implications of not using WFS-T
for feature updates, if any?
Lee Wai See
Sent: Wednesday, September 27, 2006 6:20 PM
To: Lee Wai See
Hi Lee,
regards,
Ivan
> Hi,
> Regards,
> Wai See
> From: Lee Wai See [mailto:leewse@anonymised.com]
> To: 'Chris Holmes'
> column?
> Thanks.
> Regards,
> Wai See
> Holmes
> best regards,
> Chris
> > Hi Ivan,
> > these two points?
> > 1.
> >> it only needs
> > 2.
> > Thanks a lot.
> > Regards,
> > Wai See
> >> hope i helped
> >> regards!
> >>> Hi,
is
> >>> were to
without
> >>> column?
> >>> Regards,
> >>> Lee Wai See
> >>> the
> >>> message
> >>> disclose
> >>> 9/15/2006
share
> >>> your
cash
> >> Ivan Grcic
> >> Iaeste Croatia
> your
> Chris Holmes
your
Ivan Grcic
Iaeste Croatia
Ivan Grcic
Iaeste Croatia
Yeah, that would be my guess as well.
In the future we hope to make GeoServer as fast as anyone inserting by hand, and indeed faster in cases where people don't optimize (using WKB instead of WKT, ect.). Ideally we could also let people do an 'insert' with a shapefile or other formats that are smaller than GML. But for now the parsing of GML and inserting in to GeoServer is slower than it would be to go straight through JDBC.
best regards,
Chris
Ivan Grcic wrote:
Hi Lee,
regards,
Ivan
Wai See
To: 'Chris Holmes'
column?
Thanks.
Wai See
Holmes
best regards,
Chris
Hi Ivan,
these two points?
1.
it only needs
2.
Thanks a lot.
Wai See
hope i helped
regards!
were to
column?
Lee Wai See
the
message
disclose
9/15/2006
your
Ivan Grcic
Iaeste Croatia
your
Chris Holmes
Chris Holmes
