All,
I am trying to use the GeoPackage (mosaic) data store function in my Geoserver instance. I pulled DRG_US_100k and 24k maps from the Naval Research Laboratory Geopackage Downloader website (https://geoint.nrlssc.navy.mil/gpkg/#). I have tried large data sets (2GB) and small data sets (25MB) and I am able to add the gpkg file to the store. I can publish both the 100k and 24k layers but when I view them in the layer preview I just get a blank white openlayers UI. The NRL GPKG site has a couple of optional to download formats OpenGeo Suite 4.8 (GeoServer) and NSG GeoPackage (EPSG:432) and I have tried both formats and both come back as blank white layer previews.
Has anyone else seen this?
- 2.12.1
- 5927e49e781ddcdbf9213d32a439418347c17480
- 21-Nov-2017 22:02
- 18.1 (rev 306cf3bdde1bee0110dc1c3ba77819f1e294a45b)
- 1.12.1 (rev 1.12.x/22d18b47c9e80316d563c28d280602cb3dde624c
OS Verison
Red Hat Enterprise Linux Server release 7.4 (Maipo)
Java Version
openjdk version “1.8.0_161”
OpenJDK Runtime Environment (build 1.8.0_161-b14)
OpenJDK 64-Bit Server VM (build 25.161-b14, mixed mode)
Tomcat Version - 7.0.76-3.el7_4
Hi Patrick
I haven’t tried them, but I’d suggest to use at least GeoServer 2.13.x for GeoPackage, before that
version it was an unsupported module (although, most of the work in 2.13.x went into vector
geopackages, there have been some minor fixes on raster sources too)
On Tue, Jun 26, 2018 at 4:36 PM, Patrick Devine <pddevine@anonymised.com> wrote:
All,
- 2.12.1
- 21-Nov-2017 22:02
OS Verison
Java Version
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
