Hi GS users,
I am verymuch happy with Geoserver performance for vector layers., but for georaster it is really a problematic configaration.
Is there any possibility to configure oracle georasters which are occupying bulk disk size…and possibility to access with openlayers api or any other api (or anyone is using oracle mapviewer and using any oracle map api’s for only georaster). ImagemosaicJDBC is giving problems and no consistent solutions to resolve this issues. one of the main problem i am facing now is given below.
Can anyone faced similar problem with ImagemosaicJDBC for Geoserver 2.0.2 version. We have successfully installed and working on test server environment, but when tried to do the same implementation in the deployment environment., ImagemosaicJDBC is giving errors as given below.
are they really format errors or jar mismatch errors. AFAIK, ImagemosaicJDBC plugin has to be more consistent like vector layers configarations in GS. This error i have encountered before also and with help of GS users tech forum and checking one by one jar files, successfully configured (copying 2.0.1 & 2.0.3 imagemosaicjdbc jar files in 2.0.2 version has solved my problems). This time, tried very much, but not succeeded with this idea.
Could not list layers for this store, an error occurred retrieving them: Unable to acquire a reader for this coverage with format: ImageMosaicJDBC
The os used is linux centos, with Geoserver 2.0.2 (imagemosaicJDBC version is also taken correct version)
can anyone explain the parameters Normally this value is filled in the ID coloumn record (please correct me if i am wrong).
Both environments are same when compared. Why it is giving problem.
The configaration file parameters i am giving below for reference.
<?xml version="1.0" encoding="UTF-8" standalone="no"?> =======================================================The error log is also pasted below.
25 May 00:53:32 INFO [geoserver.web] - Getting list of coverages for saved store file:coverages/geortest/sri1.xml
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: Unable to acquire a reader for this coverage with format: ImageMosaicJDBC
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:92)
at org.geoserver.web.wicket.GeoServerDataProvider.getFilteredItems(GeoServerDataProvider.java:162)
at org.geoserver.web.data.layer.NewLayerPageProvider.getFilteredItems(NewLayerPageProvider.java:108)
at org.geoserver.web.wicket.GeoServerDataProvider.size(GeoServerDataProvider.java:177)
at org.geoserver.web.wicket.GeoServerTablePanel$Pager.first(GeoServerTablePanel.java:477)
at org.geoserver.web.wicket.GeoServerTablePanel$Pager.updateMatched(GeoServerTablePanel.java:467)
at org.geoserver.web.wicket.GeoServerTablePanel$Pager.(GeoServerTablePanel.java:442)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:188)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:82)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:95)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:92)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:71)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:114)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:94)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:128)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:104)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1239)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:532)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:409)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.Exception: Unable to acquire a reader for this coverage with format: ImageMosaicJDBC
at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:577)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:72)
… 83 more
25 May 00:53:32 INFO [geoserver.catalog] - Disposing grid coverage reader ‘sri1’
25 May 00:53:32 WARN [geoserver.catalog] - Error occured disposing coverage reader ‘sri1’
Any suggestions on how to resolve this issue…
Many thanks in advance,
Hari.
