I deployed geoserver-1.4.1-war.zip which deploys fine within tomcat but geoserver-1.5.0-RC3-war.zip does not and has the following error:
FAIL - Application at context path /geoserver could not be started
John J. Mitchell
John J. Mitchell
John Mitchell ha scritto:
John, thanks for the report.
Unfortunately we need more to address this issue: can you provide us
with a full log of the application start?
Andrea,
I have attached the log file.
John Mitchell
geoserver-1.5.0-RC3-war.zip does not and has the following error:FAIL - Application at context path /geoserver could not be started
with a full log of the application start?Cheers
John J. Mitchell
localhost.2007-03-28.log (21.2 KB)
Andrea,
Ouch!
org.springframework.beans.FatalBeanException: Could not instantiate class [org.vfny.geoserver.global.GeoServer]; constructor threw exception; nested exception is java.lang.NoSuchFieldError: KEY_CACHED_TILE_RECYCLING_ENABLED
at org.vfny.geoserver.global.GeoServer.initJAI(GeoServer.java:502)
at org.vfny.geoserver.global.GeoServer.load(GeoServer.java:361)
It seems you have an old JAI installed in your java runtime. Can you tell me which version do you have, I would like to put a warning in the user guide.
You have two possible solutions:
* upgrade your JAI install to a more recent one. Geoserver 1.5.x
requires the last stable version of both JAI and JAI image i/o
* remove JAI altogheter from your JDK/JRE, and Geoserver will use the
pure java versions it has in his classpath (that will slow down
raster handling compared to an install that has the right native
JAI, but at least it'll work).
I just downloaded the latest stable version 2 days ago: jai 1.1.3 and the actual file name is below:
jai-1_1_3-lib-windows-i586-jdk.exe
John Mitchell
Andrea,
Ouch!
class [org.vfny.geoserver.global.GeoServer ]; constructor threw
at org.vfny.geoserver.global.GeoServer.initJAI (GeoServer.java:502)
at org.vfny.geoserver.global.GeoServer.load(GeoServer.java:361)It seems you have an old JAI installed in your java runtime. Can you
user guide.You have two possible solutions:
- upgrade your JAI install to a more recent one. Geoserver 1.5.x
requires the last stable version of both JAI and JAI image i/o- remove JAI altogheter from your JDK/JRE, and Geoserver will use the
JAI, but at least it’ll work).Cheers
John J. Mitchell
Strange, according to http://java.sun.com/products/java-media/jai/forDevelopers/jai-apidocs/javax/media/jai/JAI.html#KEY_CACHED_TILE_RECYCLING_ENABLED
that constant has been around since 1.1.2 (so it's pretty recent).
Can you double check? It may be you have multiple jdk, and the container
is running on top of a different one than the one you updated?
