Sir,
I have downloaded this software (geoserver 2.0.2) and try to install silently. But it doesn’t work.
Can you provide me silent installation method for this software so that I can install it on some network systems remotely?
Thanks & Regards.
Milind.
Hi Milind,
The easiest way would be to grab the platform independent zip [1]. Upload it to the remote system and unpackage it. Should work fine.
-Justin
[1] http://downloads.sourceforge.net/geoserver/geoserver-2.0.2-bin.zip
On Wed, Aug 18, 2010 at 11:45 PM, Milind.Samant <milind.samant@anonymised.com > wrote:
Sir,
Thanks & Regards.
Milind.
This SF.net email is sponsored by
Make an app they can’t live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Can we create silent answer file for this software and how?
Regards.
Milind.
----- Original Message -----
To: Milind.Samant
Cc: geoserver-users@anonymised.comts.sourceforge.net
Sent: Monday, August 23, 2010 6:36 PM
Subject: Re: [Geoserver-users] Geoserver 2.0.2 installation
Hi Milind,
-Justin
Sir,
Thanks & Regards.
Milind.
Geoserver-users@anonymised.comists.sourceforge.net
Justin Deoliveira
Hi Milind,
I am actually unfamiliar with the notion of a silent answer file. A quick google search seems to indicate it would be a modification to the windows installer. Mike (CC’d) is our windows installer expert. He will probably have a better answer for you.
-Justin
On Thu, Aug 26, 2010 at 4:58 AM, Milind.Samant <milind.samant@anonymised.com84… > wrote:
Hi Justin,
Regards.
Milind.
To: Milind.Samant
Hi Milind,
-Justin
Sir,
Thanks & Regards.
Milind.
Justin Deoliveira
Justin Deoliveira
Hi. I know that it should be possible to modify the installer to add Silent functionality (taking all of the default options), although it's not set up this way currently. I'm not sure of a way to specify custom options in an answer file, but the NSIS scripting reference* mentions that certain command line flags can be used.
What specifically are you looking to do?
* http://nsis.sourceforge.net/Docs/Chapter4.html#4.12
Mike Pumphrey
On 8/26/2010 1:43 PM, Justin Deoliveira wrote:
Hi Milind,
installer. Mike (CC'd) is our windows installer expert. He will probably
-Justin
On Thu, Aug 26, 2010 at 4:58 AM, Milind.Samant<milind.samant@anonymised.com>wrote:
Hi Justin,
Regards.
Milind.
*To:* Milind.Samant<milind.samant@anonymised.com>
*Cc:* geoserver-users@lists.sourceforge.net
*Sent:* Monday, August 23, 2010 6:36 PM
*Subject:* Re: [Geoserver-users] Geoserver 2.0.2 installation
Hi Milind,
-Justin
On Wed, Aug 18, 2010 at 11:45 PM, Milind.Samant<milind.samant@anonymised.com>wrote:
Sir,
silently. But it doesn't work.
Thanks& Regards.
Milind.
Make an app they can't live without
Justin Deoliveira
jive
August 27, 2010, 12:48am
6
I have used the NSI installers previously in silent mode; you can supply some command line options for things such as the install directory.
For udig:
udig-1.2.0.win32.exe /S
Or with directory:
udig-1.2.0.win32.exe /S /D=C:\uDig
Jody
On 27/08/2010, at 6:43 AM, Justin Deoliveira wrote:
Hi Milind,
-Justin
On Thu, Aug 26, 2010 at 4:58 AM, Milind.Samant <milind.samant@anonymised.com > wrote:
Hi Justin,
Regards.
Milind.
To: Milind.Samant
Hi Milind,
-Justin
Sir,
Thanks & Regards.
Milind.
Justin Deoliveira
Justin Deoliveira
Sell apps to millions through the Intel(R) Atom™ Developer Program
Be part of this innovative community and reach millions of netbook users
worldwide. Take advantage of special opportunities to increase revenue and
speed time-to-market. Join now, and jumpstart your future.
http://p.sf.net/sfu/intel-atom-d2d_______________________________________________
