[jdk1.6.0_25 (32 bit) on Win7 (64bit) with native jai installed]
Has anyone successfully deployed geoserver.war in servicemix (or karaf or
felix)? The steps I have taken so far are:
1. drop geoserver.war in deploy/ directory - NPE reading data directory
2. exploded geoserver.war in deploy directory and set GEOSERVER_DATA_DIR in
WEB-INF/web.xml - ClassNotFoundException
org.apache.xerces.jaxp.datatype.DatatypeFactoryImpl
3. removed servlet-api-2.5.jar from WEB-INF/lib - NoClassDefFoundError
org.geoserver.data.util.CoverageStoreUtils
Any help or suggestions would be much appreciated.
log output/stack trace:
karaf@anonymised.com> log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
03 Oct 08:27:03 WARN [config.CustomEditorConfigurer] - Passing
PropertyEditor in
stances into CustomEditorConfigurer is deprecated: use
PropertyEditorRegistrars
or PropertyEditor class names instead. Offending key
[org.geotools.util.Version;
offending editor instance:
org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
37d9
03 Oct 08:27:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\Users\BenUecker\geoserver_data_dir
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'burg'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'capitals'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'cite_lakes'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'dem'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'giant_polygon'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'grass'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'green'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'line'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'poi'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'point'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'polygon'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'poly_landmarks'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'pophatch'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'population'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'rain'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'raster'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'restricted'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'simple_roads'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'simple_streams'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded style 'tiger_roads'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded default workspace cite
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'cite'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'nurc'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'sde'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'sf'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'tiger'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded workspace 'topp'
03 Oct 08:27:05 INFO [org.geoserver] - Loaded store 'arcGridSample', enabled
03 Oct 08:27:05 INFO [org.geoserver] - Loaded coverage store 'arcGridSample'
03 Oct 08:27:08 WARN [referencing.factory] - Axis elements found in a wkt
defini
tion, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["W
GS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0
.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of
_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.
0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0],
UNIT["m",
1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
03 Oct 08:27:09 INFO [org.geoserver] - Loaded coverage 'Arc_Sample', enabled
03 Oct 08:27:09 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
Error in registry file at line number #66
javax.media.jai.operator.AffinePropertyGenerator
Error in registry file at line number #76
com.sun.media.jai.util.AreaOpPropertyGenerator
Error in registry file at line number #82
javax.media.jai.operator.ComplexPropertyGenerator
Error in registry file at line number #83
Error in registry file at line number #86
javax.media.jai.operator.DFTPropertyGenerator
Error in registry file at line number #87
Error in registry file at line number #89
Error in registry file at line number #92
Error in registry file at line number #103
Error in registry file at line number #106
javax.media.jai.operator.IDFTPropertyGenerator
Error in registry file at line number #109
javax.media.jai.operator.ImageFunctionPropertyGenerator
Error in registry file at line number #114
Error in registry file at line number #115
Error in registry file at line number #117
Error in registry file at line number #120
Error in registry file at line number #122
Error in registry file at line number #125
Error in registry file at line number #135
Error in registry file at line number #139
Error in registry file at line number #142
javax.media.jai.operator.RotatePropertyGenerator
Error in registry file at line number #143
javax.media.jai.operator.ScalePropertyGenerator
Error in registry file at line number #144
javax.media.jai.operator.ShearPropertyGenerator
Error in registry file at line number #147
javax.media.jai.operator.SubsampleBinaryToGrayPropertyGenerator
Error in registry file at line number #153
javax.media.jai.operator.TranslatePropertyGenerator
Error in registry file at line number #154
javax.media.jai.operator.TransposePropertyGenerator
Error in registry file at line number #155
Error in registry file at line number #157
javax.media.jai.operator.WarpPropertyGenerator
Error in registry file at line number #340
No descriptor by name "affine" is registered under mode "renderable".
Error in registry file at line number #350
No descriptor by name "conjugate" is registered under mode "renderable".
Error in registry file at line number #354
No descriptor by name "dft" is registered under mode "renderable".
Error in registry file at line number #356
No descriptor by name "dividecomplex" is registered under mode "renderable".
Error in registry file at line number #362
No descriptor by name "idft" is registered under mode "renderable".
Error in registry file at line number #367
No descriptor by name "magnitude" is registered under mode "renderable".
Error in registry file at line number #368
No descriptor by name "magnitudesquared" is registered under mode
"renderable".
Error in registry file at line number #373
No descriptor by name "multiplycomplex" is registered under mode
"renderable".
Error in registry file at line number #381
No descriptor by name "phase" is registered under mode "renderable".
Error in registry file at line number #383
No descriptor by name "polartocomplex" is registered under mode
"renderable".
Error in registry file at line number #386
No descriptor by name "rotate" is registered under mode "renderable".
Error in registry file at line number #387
No descriptor by name "scale" is registered under mode "renderable".
Error in registry file at line number #388
No descriptor by name "subsamplebinarytogray" is registered under mode
"renderab
le".
Error in registry file at line number #394
No descriptor by name "translate" is registered under mode "renderable".
Error in registry file at line number #395
No descriptor by name "transpose" is registered under mode "renderable".
Error in registry file at line number #402
Input factory object of class
"com.sun.media.jai.opimage.AddConstToCollectionCIF
" is not an instance of registry mode "collection"`s factory class
"javax.media.
jai.CollectionImageFactory".
Error in registry file at line number #407
"com.sun.media.jai.tilecodec.GZIPTileDecoderFactor
y" is not an instance of registry mode "tileDecoder"`s factory class
"javax.medi
a.jai.tilecodec.TileDecoderFactory".
Error in registry file at line number #408
"com.sun.media.jai.tilecodec.JPEGTileDecoderFactor
"javax.medi
Error in registry file at line number #409
"com.sun.media.jai.tilecodec.RawTileDecoderFactory
"javax.media
Error in registry file at line number #414
"com.sun.media.jai.tilecodec.GZIPTileEncoderFactor
y" is not an instance of registry mode "tileEncoder"`s factory class
"javax.medi
a.jai.tilecodec.TileEncoderFactory".
Error in registry file at line number #415
"com.sun.media.jai.tilecodec.JPEGTileEncoderFactor
"javax.medi
Error in registry file at line number #416
"com.sun.media.jai.tilecodec.RawTileEncoderFactory
"javax.media
Error in registry file at line number #421
Input factory object of class "com.sun.media.jai.rmi.JAIRMICRIF" is not an
insta
nce of registry mode "remoteRendered"`s factory class
"javax.media.jai.remote.Re
moteRIF".
Error in registry file at line number #426
insta
nce of registry mode "remoteRenderable"`s factory class
RemoteCRIF".
03 Oct 08:27:10 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
03 Oct 08:27:10 INFO [org.geoserver] - Loaded store 'img_sample2', disabled
03 Oct 08:27:10 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage 'Pk50095', disabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage 'img_sample2'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'Pk50095'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'mosaic', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage store 'mosaic'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'mosaic'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'worldImageSample',
enabled
'worldImageSample'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage 'Img_Sample', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'Img_Sample'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'sf', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded data store 'sf'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'archsites',
enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'sf'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'archsites'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'bugsites',
enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'bugsites'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'restricted',
enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'restricted'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'roads', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'roads'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'streams',
enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'streams'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'sfdem', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage store 'sfdem'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'sfdem'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'nyc', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded data store 'nyc'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'giant_polygon',
enab
led
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'nyc'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'giant_polygon'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'poi', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'poi'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'poly_landmarks',
ena
bled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'tiger_roads',
enable
d
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'tiger_roads'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'states_shapefile',
enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded data store 'states_shapefile'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'states', enabled
'states_shapefile'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'states'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded data store 'taz_shapes'
'tasmania_cities', en
abled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
03 Oct 08:27:11 INFO [org.geoserver] - Loaded feature type 'tasmania_roads',
ena
bled
03 Oct 08:27:11 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
'tasmania_state_bound
aries', enabled
'tasmania_state_boundaries'
'tasmania_water_bodie
s', enabled
03 Oct 08:27:12 INFO [org.geoserver] - Loaded layer 'tasmania_water_bodies'
03 Oct 08:27:12 INFO [org.geoserver] - Loaded layer group 'spearfish'
03 Oct 08:27:12 INFO [org.geoserver] - Loaded layer group 'tasmania'
03 Oct 08:27:12 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
03 Oct 08:27:12 INFO [org.geoserver] - Loaded service 'wcs', enabled
03 Oct 08:27:12 INFO [org.geoserver] - Loaded service 'wfs', enabled
03 Oct 08:27:12 INFO [org.geoserver] - Loaded service 'wms', enabled
03 Oct 08:27:12 INFO [gwc.config] - Initializing GeoServer specific GWC
configur
ation from gwc-gs.xml
java.lang.NoClassDefFoundError: Could not initialize class
javax.media.jai.JAI
at org.geoserver.jai.JAIInitializer.initJAI(JAIInitializer.java:48)
at
org.geoserver.jai.JAIInitializer.initialize(JAIInitializer.java:28)
at
org.geoserver.config.GeoServerLoader.loadInitializers(GeoServerLoader
.java:152)
at
org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(
GeoServerLoader.java:132)
at
org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitializa
tion(GeoServerLoaderProxy.java:54)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanF
actory.java:394)
at
Factory.initializeBean(AbstractAutowireCapableBeanFactory.java:1413)
at
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at
Factory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getOb
ject(AbstractBeanFactory.java:291)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
y.getSingleton(DefaultSingletonBeanRegistry.java:222)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
an(AbstractBeanFactory.java:288)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:190)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver
.resolveReference(BeanDefinitionValueResolver.java:322)
at
.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at
org.springframework.beans.factory.support.ConstructorResolver.resolve
ConstructorArguments(ConstructorResolver.java:630)
at
org.springframework.beans.factory.support.ConstructorResolver.autowir
eConstructor(ConstructorResolver.java:148)
at
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1003)
at
Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:907)
at
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:580)
at
org.springframework.context.support.AbstractApplicationContext.finish
BeanFactoryInitialization(AbstractApplicationContext.java:895)
at
org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:425)
at
org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:276)
at
org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:197)
at
org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:47)
at
org.geoserver.platform.GeoServerContextLoaderListener.contextInitiali
zed(GeoServerContextLoaderListener.java:18)
at
org.ops4j.pax.web.service.jetty.internal.HttpServiceContext$1.call(Ht
tpServiceContext.java:163)
at
tpServiceContext.java:159)
at
org.ops4j.pax.swissbox.core.ContextClassLoaderUtils.doWithClassLoader
(ContextClassLoaderUtils.java:60)
at
org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.addEventL
istener(HttpServiceContext.java:156)
at
org.ops4j.pax.web.service.jetty.internal.JettyServerImpl.addEventList
ener(JettyServerImpl.java:242)
at
org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl$Started
.addEventListener(ServerControllerImpl.java:262)
at
org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl.addEven
tListener(ServerControllerImpl.java:123)
at
org.ops4j.pax.web.service.internal.HttpServiceStarted.registerEventLi
stener(HttpServiceStarted.java:340)
at
org.ops4j.pax.web.service.internal.HttpServiceProxy.registerEventList
ener(HttpServiceProxy.java:131)
at
org.ops4j.pax.web.extender.war.internal.RegisterWebAppVisitorWC.visit
(RegisterWebAppVisitorWC.java:264)
at
org.ops4j.pax.web.extender.war.internal.model.WebApp.accept(WebApp.ja
va:473)
at
org.ops4j.pax.web.extender.war.internal.WebAppPublisher$HttpServiceLi
stener.register(WebAppPublisher.java:170)
at
stener.serviceChanged(WebAppPublisher.java:155)
at
stener.serviceChanged(WebAppPublisher.java:119)
at
org.ops4j.pax.swissbox.tracker.ReplaceableService.setService(Replacea
bleService.java:114)
at
org.ops4j.pax.swissbox.tracker.ReplaceableService.access$100(Replacea
bleService.java:28)
at
org.ops4j.pax.swissbox.tracker.ReplaceableService$CollectionListener.
serviceAdded(ReplaceableService.java:183)
at
org.ops4j.pax.swissbox.tracker.ServiceCollection$Tracker.addingServic
e(ServiceCollection.java:181)
at
org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(Service
Tracker.java:896)
at
org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.jav
a:261)
at
org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.ja
va:184)
at
org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:339)
at
org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:273)
at
org.ops4j.pax.swissbox.tracker.ServiceCollection.onStart(ServiceColle
ction.java:139)
at
org.ops4j.pax.swissbox.lifecycle.AbstractLifecycle$Stopped.start(Abst
ractLifecycle.java:121)
at
org.ops4j.pax.swissbox.lifecycle.AbstractLifecycle.start(AbstractLife
cycle.java:49)
at
org.ops4j.pax.swissbox.tracker.ReplaceableService.onStart(Replaceable
Service.java:146)
at
at
cycle.java:49)
at
org.ops4j.pax.web.extender.war.internal.WebAppPublisher.publish(WebAp
pPublisher.java:81)
at
org.ops4j.pax.web.extender.war.internal.WebXmlObserver.addingEntries(
WebXmlObserver.java:131)
at
org.ops4j.pax.swissbox.extender.BundleWatcher.register(BundleWatcher.
java:186)
at
org.ops4j.pax.swissbox.extender.BundleWatcher.access$000(BundleWatche
r.java:45)
at
org.ops4j.pax.swissbox.extender.BundleWatcher$1.bundleChanged(BundleW
atcher.java:127)
at
org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerC
allback(EventDispatcher.java:807)
at
org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(
EventDispatcher.java:729)
at
org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(Event
Dispatcher.java:610)
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:3761)
at org.apache.felix.framework.Felix.startBundle(Felix.java:1787)
at
org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1163)
at
org.apache.felix.framework.StartLevelImpl.run(StartLevelImpl.java:264
at java.lang.Thread.run(Thread.java:662)
03 Oct 08:27:12 INFO [storage.DefaultStorageFinder] -
03 Oct 08:27:12 INFO [storage.DefaultStorageFinder] - *** Found Servlet
context
parameter GEOSERVER_DATA_DIR set to C:\Users\BenUecker\geoserver_data_dir,
using
it as the default prefix. ***
03 Oct 08:27:13 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version
120
03 Oct 08:27:13 INFO [config.XMLConfiguration] - Failed to find
geowebcache.xml.
This is not a problem unless you are trying to use a custom XML
configuration f
ile.
03 Oct 08:27:13 INFO [config.XMLConfiguration] - Configuration file cannot
be re
ad or does not exist!
03 Oct 08:27:13 INFO [config.XMLConfiguration] - Found configuration file in
C:\
Users\BenUecker\apache-servicemix-4.3.0\apache-servicemix-4.3.0\null\..\resource
s
C:\
s
03 Oct 08:27:13 INFO [config.XMLConfiguration] - Found no configuration file
in
C:\Users\BenUecker\apache-servicemix-4.3.0\apache-servicemix-4.3.0\null\..\resou
rces If you are running GWC in GeoServer this is probably not an issue.
03 Oct 08:27:13 INFO [config.XMLConfiguration] - Adding layers from
C:\Users\Ben
Uecker\apache-servicemix-4.3.0\apache-servicemix-4.3.0\null\..\resources
03 Oct 08:27:13 ERROR [layer.TileLayerDispatcher] - Configuration
C:\Users\BenUe
contained
no layers.
C:\
s
03 Oct 08:27:13 WARN [storage.EntityStoreBuilder] - Neither disk quota page
stor
e' cache memory percent nor cache size was provided. Defaulting to 25% Heap
Size
03 Oct 08:27:15 INFO [storage.BDBQuotaStore] - Berkeley DB JE Disk Quota
page st
ore configured at
C:\Users\BenUecker\geoserver_data_dir\gwc\diskquota_page_store
03 Oct 08:27:15 INFO [storage.BDBQuotaStore] - Quota Store initialized.
Global q
uota: 0.0B
03 Oct 08:27:15 INFO [diskquota.ConfigLoader] - DiskQuota configuration not
foun
d: C:\Users\BenUecker\geoserver_data_dir\gwc\geowebcache-diskquota.xml
03 Oct 08:27:15 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota
period
ic enforcement task
03 Oct 08:27:15 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with
the
ir own quotas.
03 Oct 08:27:15 INFO [diskquota.DiskQuotaMonitor] - 22 layers attached to
global
quota 500.0MiB
03 Oct 08:27:15 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic
enforcem
ent task set up every 10 SECONDS
03 Oct 08:27:16 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked
setServletPre
fix(gwc)
03 Oct 08:27:16 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller...
03 Oct 08:27:16 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found,
poll
er will not run.
03 Oct 08:27:16 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 9
paths
03 Oct 08:27:16 INFO [wms.WMSService] - Will NOT recombine tiles for
non-tiling
clients.
03 Oct 08:27:17 INFO [wms.WMSService] - Will proxy requests to backend that
are
not getmap or getcapabilities.
03 Oct 08:27:17 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**]
onto ha
ndler 'dispatcher'
03 Oct 08:27:17 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto
handl
er 'dispatcher'
03 Oct 08:27:17 INFO [georss.GeoRSSPoller] - destroy() invoked
03 Oct 08:27:17 INFO [geowebcache.GeoWebCacheDispatcher] -
.destroy() was invoked, shutting down.
03 Oct 08:27:17 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor
shutting
down...
03 Oct 08:27:17 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota
usage mo
nitor...
03 Oct 08:27:17 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota
usage
monitor...
statisti
cs gathering monitor...
03 Oct 08:27:17 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down
quot
a update background task due to InterruptedException
03 Oct 08:27:17 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down
quota
update background task due to interrupted exception
03 Oct 08:27:17 INFO [storage.BDBQuotaStore] - Requesting to close quota
store..
03 Oct 08:27:17 INFO [storage.BDBQuotaStore] - Quota store closed.
03 Oct 08:27:17 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down
for
running and pending seed tasks...
03 Oct 08:27:17 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool
execut
or shut down complete.
03 Oct 08:27:17 INFO [storage.StorageBroker] - Destroying StorageBroker
03 Oct 08:27:19 WARN [support.DisposableBeanAdapter] - Invocation of destroy
met
hod failed on bean with name 'geoServerLoader':
y.BeanCreationNotAllowedException: Error creating bean with name
'wmsLifecycleHa
ndler': Singleton bean creation not allowed while the singletons of this
factory
are in destruction (Do not request a bean from a BeanFactory in a destroy
metho
d implementation!)
03 Oct 08:27:19 ERROR [context.ContextLoader] - Context initialization
failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
wit
h name 'restWrapper' defined in URL
[bundle://202.1:129/applicationContext.xml]:
Initialization of bean failed; nested exception is
ctory.BeanCreationException: Error creating bean with name 'storeFileFinder'
def
ined in URL [bundle://202.1:130/applicationContext.xml]: Instantiation of
bean f
ailed; nested exception is java.lang.NoClassDefFoundError: Could not
initialize
class org.geoserver.data.util.CoverageStoreUtils
at
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
va:473)
at
at
at
at
at
bleService.java:28)
at
at
at
Tracker.java:896)
at
a:261)
at
va:184)
at
at
at
ction.java:139)
at
at
cycle.java:49)
at
Service.java:146)
at
at
cycle.java:49)
at
pPublisher.java:81)
at
at
java:186)
at
r.java:45)
at
atcher.java:127)
at
at
at
at
at
Caused by: org.springframework.beans.factory.BeanCreationException: Error
creati
ng bean with name 'storeFileFinder' defined in URL
onContext.xml]: Instantiation of bean failed; nested exception is
java.lang.NoCl
reUtils
at
eConstructor(ConstructorResolver.java:288)
at
at
at
at
at
at
at
at
at
org.springframework.context.support.AbstractApplicationContext.getBea
n(AbstractApplicationContext.java:1075)
at
org.geoserver.rest.RESTDispatcher.addRoutes(RESTDispatcher.java:131)
at
org.geoserver.rest.RESTDispatcher.createRoot(RESTDispatcher.java:231)
at
org.geoserver.rest.RESTDispatcher.initApplicationContext(RESTDispatch
er.java:76)
at
org.springframework.context.support.ApplicationObjectSupport.initAppl
icationContext(ApplicationObjectSupport.java:119)
at
org.springframework.web.context.support.WebApplicationObjectSupport.i
nitApplicationContext(WebApplicationObjectSupport.java:72)
at
org.springframework.context.support.ApplicationObjectSupport.setAppli
cationContext(ApplicationObjectSupport.java:73)
at
org.springframework.context.support.ApplicationContextAwareProcessor.
invokeAwareInterfaces(ApplicationContextAwareProcessor.java:106)
at
postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:85)
at
actory.java:394)
at
at
... 54 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class
org.geoser
at
org.geoserver.catalog.rest.StoreFileFinder.<clinit>(StoreFileFinder.j
ava:24)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstruct
orAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingC
onstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:1
26)
at
org.springframework.beans.factory.support.SimpleInstantiationStrategy
.instantiate(SimpleInstantiationStrategy.java:108)
at
eConstructor(ConstructorResolver.java:280)
... 74 more
View this message in context: http://osgeo-org.1803224.n2.nabble.com/geoserver-2-1-1-in-servicemix-4-3-tp6854832p6854832.html
