I've spatial coverage data in an Oracle Spatial Database table. I've exposed the table as a layer. When I'm invoke the layer as a PNG image or using Open Layer application(tiled request) within Geo Server, I see that it is taking quite a long time to render the images. From the log (log profile = GEOSERVER_DEVELOPER_LOGGING.properties), I see that GeoServer has taken ~3.5 secs (between 11:55:02,871 - 11:55:06,434 AM) to 'set up image' and process the getMap request. I would like to know what exactly is happening within this 3.5 secs. Is this time being taken by the SQL query to determine the polygons within the bounding box supplied? The overall time required by the request to be processed and displayed on the client machine is around 9 secs which is quite slow. Any help would be greatly appreciated. Below is the log.
=========================== GeoServer Log ===================
2014-07-10 11:55:02,777 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/icc_sa/wms
2014-07-10 11:55:02,777 INFO [org.geoserver.wms] -
Request: getServiceInfo
2014-07-10 11:55:02,777 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:02,777 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:02,777 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:02,777 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:02,793 INFO [org.geoserver.wms] -
2014-07-10 11:55:02,793 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:02,793 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:02,793 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:02,793 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:02,809 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:02,809 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:02,809 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:02,809 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:02,809 INFO [org.geoserver.wms] -
2014-07-10 11:55:02,824 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:02,824 INFO [org.geoserver.wms] -
2014-07-10 11:55:02,824 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:02,824 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:02,824 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:02,840 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 3in cache: miss
2014-07-10 11:55:02,840 DEBUG [org.geoserver.wms.map] - Building meta tile 15, 3
2014-07-10 11:55:02,840 DEBUG [org.geoserver.wms.map] - setting up 768x768 image
2014-07-10 11:55:02,871 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 0in cache: miss
2014-07-10 11:55:02,871 DEBUG [org.geoserver.wms.map] - Building meta tile 15, 0
2014-07-10 11:55:02,871 DEBUG [org.geoserver.wms.map] - setting up 768x768 image
2014-07-10 11:55:06,434 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.709375 : -4.478, 55.01775 : 55.249125]
BgColor = java.awt.Color[r=255,g=255,b=255]
Crs = GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]
SRS = EPSG:4326
Exceptions = application/vnd.ogc.se_inimage
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
Styles = [StyleImpl[ name=Style_ICC_SA_DMA]]
Sld = null
SldBody = null
SldVersion = null
ValidateSchema = false
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
TilesOrigin = Point2D.Double[-8.18, 54.555]
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
FeatureVersion = null
RemoteOwsType = null
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
BaseUrl = http://ip:80/geoserver/
RawKvp = {BBOX=-4.709375,55.01775,-4.478,55.249125, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
RequestCharset = UTF-8
2014-07-10 11:55:06,449 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 0in cache: hit!
2014-07-10 11:55:06,449 DEBUG [org.geoserver.wms.map] - Writing png image ...
2014-07-10 11:55:06,449 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.478 : -4.246625, 55.01775 : 55.249125]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.478,55.01775,-4.246625,55.249125, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,465 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:06,465 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/icc_sa/wms
2014-07-10 11:55:06,465 INFO [org.geoserver.wms] -
2014-07-10 11:55:06,481 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:06,481 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/icc_sa/wms
2014-07-10 11:55:06,481 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:06,481 INFO [org.geoserver.wms] -
2014-07-10 11:55:06,481 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:06,481 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:06,543 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 0in cache: hit!
2014-07-10 11:55:06,559 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.246625 : -4.01525, 55.01775 : 55.249125]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.246625,55.01775,-4.01525,55.249125, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,559 DEBUG [org.geoserver.wms.map] - Writing png image ...
2014-07-10 11:55:06,590 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:06,590 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/icc_sa/wms
2014-07-10 11:55:06,590 INFO [org.geoserver.wms] -
2014-07-10 11:55:06,590 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:06,606 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:06,606 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:06,606 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:06,637 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.478 : -4.246625, 55.249125 : 55.4805]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.478,55.249125,-4.246625,55.4805, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,637 DEBUG [org.geoserver.wms.map] - Writing png image ...
2014-07-10 11:55:06,652 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 3in cache: hit!
2014-07-10 11:55:06,652 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.246625 : -4.01525, 55.4805 : 55.711875]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.246625,55.4805,-4.01525,55.711875, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,652 DEBUG [org.geoserver.wms.map] - Writing png image ...
2014-07-10 11:55:06,668 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 3in cache: hit!
2014-07-10 11:55:06,668 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.246625 : -4.01525, 55.249125 : 55.4805]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.246625,55.249125,-4.01525,55.4805, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
Request: getMap
Bbox = ReferencedEnvelope[-4.709375 : -4.478, 55.249125 : 55.4805]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.709375,55.249125,-4.478,55.4805, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,668 DEBUG [org.geoserver.wms.map] - Writing png image ...
Request: getMap
Bbox = ReferencedEnvelope[-4.478 : -4.246625, 55.4805 : 55.711875]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.478,55.4805,-4.246625,55.711875, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,731 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:06,746 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:06,746 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/icc_sa/wms
2014-07-10 11:55:06,746 INFO [org.geoserver.wms] -
2014-07-10 11:55:06,746 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2014-07-10 11:55:06,746 DEBUG [org.geoserver.ows] - establishing Style_ICC_SA_DMA style for icc_sa:ICC_SA_LAYER_DMA_COVERAGE
2014-07-10 11:55:06,762 DEBUG [org.geoserver.wms] - Tiled request detected, activating on the fly meta tiler
2014-07-10 11:55:06,762 DEBUG [org.geoserver.wms] - setting up map
2014-07-10 11:55:06,762 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:06,777 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:06,824 DEBUG [org.geoserver.wms.map] - Looked for meta tile 15, 3in cache: hit!
2014-07-10 11:55:06,824 INFO [org.geoserver.wms] -
Request: getMap
Bbox = ReferencedEnvelope[-4.709375 : -4.478, 55.4805 : 55.711875]
SRS = EPSG:4326
Format = image/png
FormatOptions = {}
Env = {}
ViewParams = {}
Height = 256
Sld = null
SldBody = null
SldVersion = null
Filters = null
Filter = null
CQLFilter = null
FeatureId = null
Transparent = false
Tiled = true
Buffer = 0
Palette = null
Width = 256
KMScore = 40
KMattr = true
Legend = false
Time = null
Elevation = NaN
RemoteOwsURL = null
MaxFeatures = null
StartIndex = null
Angle = 0.0
Get = true
Request = GetMap
Version = 1.1.1
RawKvp = {BBOX=-4.709375,55.4805,-4.478,55.711875, TILED=true, SERVICE=WMS, HEIGHT=256, REQUEST=GetMap, STYLES=, TILESORIGIN=-8.18,54.555, WIDTH=256, EXCEPTIONS=application/vnd.ogc.se_inimage, VERSION=1.1.1, FORMAT=image/png, LAYERS=icc_sa:ICC_SA_LAYER_DMA_COVERAGE, SRS=EPSG:4326}
2014-07-10 11:55:06,824 DEBUG [org.geoserver.wms.map] - Writing png image ...
2014-07-10 11:55:06,887 DEBUG [org.geoserver.wms.map] - Writing png image ... done!
2014-07-10 11:55:17,184 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/web/
2014-07-10 11:55:17,215 DEBUG [org.geoserver.filters] - filtering http://ip:80/geoserver/web/
Thanks & Regards,
Samyajit Talukdar
Privileged/Confidential information may be contained in this Email and any files transmitted with it. If you are not the intended recipient you should not retain, copy or use this Email for any purpose or disclose all or part of its contents to any person. If you have received this Email in error please notify the postmaster and sender immediately and delete this Email from your system.
Opinions, conclusions and other information in this message that do not relate to the official business of Scottish Water ("SW"), Scottish Water Solutions Ltd ("SWS") or Scottish Water Solutions 2 Ltd ("SWS2") shall be understood as neither given nor endorsed by them. The contents of Emails sent and received by SW, SWS and SWS2 are monitored.
WARNING: Although SW, SWS and SWS2 have taken reasonable precautions to ensure no viruses or other malicious software are present, SW, SWS and SWS2 cannot accept responsibility for any loss or damage arising from the use of this Email or attachments however caused. The recipient should therefore check this Email and any attachments for the presence of viruses or other malicious software.
Scottish Water
www.scottishwater.co.uk
www.scottishwatersolutions.co.uk
postmaster@anonymised.com
