[Geoserver-users] GeoServer 2.11 : Slow HTTP Denial of Service attack
Hi
I have recently started using GeoServer 2.11
As part of my organisation’s requirement I had run a security scan on the server and found Slow HTTP Denial of Service attack open.
I tried using DoS filter for jetty as below in webapps/geoserver/web.xml, however, the issue still persists and I could not find any other way to mitigate this risk on the geoserver.
Request if you could help me on the ASAP as my urgent release is on a hold in the absence of fixing this risk.
DoSFilter
org.eclipse.jetty.servlets.DoSFilter
maxRequestsPerSec
30
delayMs
0
maxRequestMs
10000
maxIdleTrackerMs
10000
true
DoSFilter
Regards
Himani Aggarwal
Other than setting the WMS interpolation default to “nearest neighbor”, I don’t see a way to do this. Within the area that contains data, I do want interpolation to occur. In the past, I’ve tried using a footprint shapefile, and that did not fix the problem.
I’m using GeoServer version 2.9.2. The data was created by using gdal_translate and gdalwarp to reproject the original file from Lambert Conformal Conic to EPSG:4326 and convert it to Byte type. The no-data value is 255.
It seems you can easily fix this using any number of servers (https://blog.qualys.com/securitylabs/2011/11/02/how-to-protect-against-slow-http-attacks) but not Jetty which isn’t really designed for critical production usage.
However if this is truly critical to your organization there are plenty of commercial support organisations (http://geoserver.org/support/) who may be able to help.
All the best
Ian
On 26 May 2017 at 13:25, Himani Aggarwal <Himani.Aggarwal@anonymised.com> wrote:
Hi
DoSFilter
maxRequestsPerSec
30
delayMs
0
maxRequestMs
10000
maxIdleTrackerMs
10000
true
DoSFilter
Regards
Himani Aggarwal
Disclaimer: This message and the information contained herein is proprietary and confidential and subject to the Tech Mahindra policy statement, you may review the policy at http://www.techmahindra.com/Disclaimer.html externally http://tim.techmahindra.com/tim/disclaimer.html internally within TechMahindra.
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Hi Devin,
for higher order interpolations we are still working on fixes. The good news is that they are basically done,
the bad one is that they are not in any release and not even in nightly builds yet.
We’ll have to:
  • release a new version of jai-ext
  • make geotools and geoserver depend on it (at this point they will be in nightly builds and, when the time comes, in releases)
  • you’ll have to enable jai-ext support in GeoServer (which is available, but still considered experimental, hopefully that will change in GeoServer 2.12, in September). See also http://docs.geoserver.org/stable/en/user/configuration/image_processing/index.html#jai-ext
    I believe in a matter of weeks it will be testable out of nightly builds, but I don’t know exactly when
On Fri, May 26, 2017 at 5:15 PM, Devin Eyre <Devin.Eyre@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
