[Geoserver-users] GeoServer 2.16 and GDAL problems
I have a problem loading GDAL with GeoServer 2.16. When I start I get errors that it can’t find GDAL (see below). Can anyone provide any tips to what I may be doing wrong? Thanks!!!
Steps I took:
Downloaded the GeoServer 2.16 binary http://sourceforge.net/projects/geoserver/files/GeoServer/2.16-RC/geoserver-2.16-RC-bin.zip
Extracted GDAL plugins to WEB-INF/lib http://sourceforge.net/projects/geoserver/files/GeoServer/2.16-RC/extensions/geoserver-2.16-RC-gdal-plugin.zip
Set environment variables:
GDAL_DATA=D:\release-1900-gdal-2-4-2-mapserver-7-4-0\bin\gdal-data
GDAL_DRIVER_PATH=D:\release-1900-gdal-2-4-2-mapserver-7-4-0\bin\gdal\plugins
Path=*%PATH%;*D:\release-1900-gdal-2-4-2-mapserver-7-4-0\bin;D:\release-1900-gdal-2-4-2-mapserver-7-4-0\bin\gdal\java
Started GeoServer:
Welcome to GeoServer!
JAVA_HOME: C:\Program Files\Java\jdk1.8.0_201
The GEOSERVER_HOME environment variable is not defined.
Temporarily setting GEOSERVER_HOME to the following directory:
D:\geoserver-2.16-RC
The GEOSERVER_DATA_DIR environment variable is not defined correctly.
Temporarily setting GEOSERVER_DATA_DIR to the following directory:
D:\geoserver-2.16-RC\data_dir
Please wait while loading GeoServer…
2019-09-13 13:49:42.141:INFO::main: Logging initialized @2493ms to org.eclipse.jetty.util.log.StdErrLog
2019-09-13 13:49:42.396:WARN:oejx.XmlConfiguration:main: Property ‘jetty.port’ is deprecated, use ‘jetty.http.port’ instead
2019-09-13 13:49:42.396:WARN:oejx.XmlConfiguration:main: Property ‘http.timeout’ is deprecated, use ‘jetty.http.idleTimeout’ instead
2019-09-13 13:49:42.404:INFO:oejs.Server:main: jetty-9.4.18.v20190429; built: 2019-04-29T20:42:08.989Z; git: e1bc35120a6617ee3df052294e433f3a25ce7097; jvm 1.8.0_201-b09
2019-09-13 13:49:42.441:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///D:/geoserver-2.16-RC/webapps/] at interval 1
2019-09-13 13:50:13.222:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2019-09-13 13:50:13.692:INFO:oejs.session:main: DefaultSessionIdManager workerName=node0
2019-09-13 13:50:13.693:INFO:oejs.session:main: No SessionScavenger set, using defaults
2019-09-13 13:50:13.693:INFO:oejs.session:main: node0 Scavenging every 600000ms
2019-09-13 13:50:14.159:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///D:/geoserver-2.16-RC/webapps/geoserver/,UNAVAILABLE}{D:\geoserver-2.16-RC\webapps\geoserver}
java.util.ServiceConfigurationError: javax.imageio.spi.ImageWriterSpi: Provider it.geosolutions.imageio.plugins.jp2kakadu.JP2GDALKakaduImageWriterSpi could not be instantiated
at java.util.ServiceLoader.fail(ServiceLoader.java:232)
at java.util.ServiceLoader.access$100(ServiceLoader.java:185)
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:384)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210)
at javax.imageio.spi.IIORegistry.(IIORegistry.java:138)
at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159)
at javax.imageio.ImageIO.(ImageIO.java:66)
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:197)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:553)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:365)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:192)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:151)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:172)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:416)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:65)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:576)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:238)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:167)
at org.eclipse.jetty.server.Server.start(Server.java:418)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:119)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:490)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by:
java.lang.NoClassDefFoundError: org/gdal/gdal/gdal
at it.geosolutions.imageio.gdalframework.GDALUtilities.loadGDAL(GDALUtilities.java:634)
at it.geosolutions.imageio.gdalframework.GDALImageWriterSpi.(GDALImageWriterSpi.java:34)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380)
Caused by:
java.lang.ClassNotFoundException: org.gdal.gdal.gdal
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:555)
2019-09-13 13:50:14.205:INFO:oejs.AbstractConnector:main: Started ServerConnector@anonymised.com{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
2019-09-13 13:50:14.211:INFO:oejs.Server:main: Started @34562ms
Ashley Mort
Sr. Software Engineer
972-638-6317 office
814-571-3039 cell
Dear Ashley,
I think that the GeoServer GDAL plugin zip is missing the required jar. I’m going to fix the XML which produces that zip.
In the meantime, if you downloaded release-1900-gdal-2-4-2-mapserver-7-4-0.zip, you should find the required gdal.jar file
in release-1900-gdal-2-4-2-mapserver-7-4-0.zip\bin\gdal\java\gdal.jar
Just copy that gdal.jar file to your webapps/geoserver/WEB-INF/lib folder (basically, the place where you have previously extracted the GeoServer GDAL plugin) and restart GeoServer.
Please, let us know if that solves the problem.
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Daniele, adding the gdal.jar to GeoServer worked for me! Only remaining
issue now is that I have some problems with certain .dll files loading. We
are especially interested in getting the FileGDB to work. Any tips there?
ERROR 1: Can't load requested DLL:
D:\release-1900-x64-gdal-2-4-2-mapserver-7-4-0\bin\gdal\plugins\gdal_GEOR.dll
126: The specified module could not be found.
D:\release-1900-x64-gdal-2-4-2-mapserver-7-4-0\bin\gdal\plugins\ogr_FileGDB.dll
D:\release-1900-x64-gdal-2-4-2-mapserver-7-4-0\bin\gdal\plugins\ogr_MSSQLSpatial.dll
D:\release-1900-x64-gdal-2-4-2-mapserver-7-4-0\bin\gdal\plugins\ogr_OCI.dll
Sep 16, 2019 8:46:54 AM it.geosolutions.imageio.gdalframework.GDALUtilities
loadGDAL
INFO: GDAL Native Library loaded (version: 2.4.2)
Daniele Romagnoli-3 wrote
Dear Ashley,
I'm
*release-1900-gdal-2-4-2-mapserver-7-4-0.zip*, you should find the
required
gdal.jar file
in *release-1900-gdal-2-4-2-mapserver-7-4-0.zip\bin\gdal\java\gdal.jar*
Just copy that *gdal.jar* file to your webapps/geoserver/WEB-INF/lib
folder
Daniele
On Fri, Sep 13, 2019 at 9:24 PM Ashley Mort <
Ashley_C_Mort@
to
Steps I took:
Path=*%PATH%;*
Started GeoServer:
Please wait while loading GeoServer...
'jetty.port' is deprecated, use 'jetty.http.port' instead
'http.timeout' is deprecated, use 'jetty.http.idleTimeout' instead
JSP
workerName=node0
using defaults
600000ms
Provider
could
not be instantiated
        at
        at
        at
<init>
        at
<clinit>
(ImageIO.java:66)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Caused by:
        at
        at
<clinit>
Method)
        at
        at
        at
        at
        at
        at
<init>
        at
<clinit>
(ImageIO.java:66)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Caused by:
        at
        at
        at
<clinit>
Method)
        at
        at
        at
        at
        at
        at
<init>
        at
<clinit>
(ImageIO.java:66)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Ashley Mort
972-638-6317 office
814-571-3039 cell
Geoserver-users mailing list
Please make sure you read the following two resources before posting to
this list:
- Earning your support instead of buying it, but Ian Turton:
http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines:
http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com
Daniele Romagnoli
this
please
this list:
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
note that GeoServer supports a reduced set of GDAL format, at the moment: they are listed in the GeoServer GDAL doc page:
https://docs.geoserver.org/stable/en/user/data/raster/gdal.html
The following image formats can be read by GeoServer using GDAL:
The FileGDB isn’t currently supported through GDAL plugins.
I see there is an importer-fgdb module in community modules but I don’t know the details of that.
If interested, you may want to ask some more info through the user mailing list with a new subject and I think that some devs will chime in with more feedbacks.
Daniele
Daniele Romagnoli
It is supported by the OGR store, but as a vector format. Not sure if FileGBD can also contain rasters?
It’s also vector based
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
