[Geoserver-users] GeoServer 2.18.1 released
GeoServer 2.18.1 has been released, read about it in our blog post: http://geoserver.org/announcements/2020/11/23/geoserver-2-18-1-released.html
Best regards
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thank you Andrea!!
Is the geoscript community plugin available for the 2.18.x release?
On Mon, Nov 23, 2020 at 3:59 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Best regards
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
The geoscript modules are basically dead, due to lack of maintenance.
They have been kicked out of the packaging in 2018 during a JTS upgrade, and have not made
it back in yet.
I personally never used them, but think they are a nice addition to do small customizations without
the need to add a full blown Java plugin, but keep them in the data dir… oh well, the day we get
a maintainer for them I’ll be quite happy to bring them back in the build.
I was intrigued by the idea of writing WPS scripts without having to recompile and redeploy.
I have been trying the geoscript plugin built from source, but for some reason can’t pinpoint the correct jar dependencies.
The plugin works with the whole geoscript app jar, which is ~130MB in size.
On Mon, Nov 23, 2020 at 6:06 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Nov 23, 2020 at 12:24 PM Alexander Petkov <greenkov@anonymised.com> wrote:
Thank you Andrea!!
it back in yet.
