I just upgraded an instance from 2.18.2 to 2.20.0 and the paging in layer preview page has stopped working.
Is this a known issue?
Best,
Angelos
Angelos Tzotsos, PhD
President
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
paging in layer preview page works as expected in my 2.20.0 instance.
Stefan
Am 19.10.2021 um 10:46 schrieb Angelos Tzotsos:
Best,
Angelos
Dipl. Ing. Stefan Overkamp
Laakmannsbusch 44, 42555 Velbert
tel.: 0177 / 79 76 159
overkamp@anonymised.com
Paging looks fine here too
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
I am getting this 400 error:
13:01:33.575 XHRGEThttp://beta.geoportal.ypen.gr/geoserver/web/wicket/bookmarkable/org.geoserver.web.demo.MapPreviewPage?7-1.IBehaviorListener.0-table-filterForm-navigatorTop-navigator-navigation-1-pageLink&filter=false&_=1634637681731
[HTTP/1.1 400 26ms]
<!doctype html><html lang="en"><head><title>HTTP Status 400 – Bad Request</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 400 – Bad Request</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Message</b> Origin does not correspond to request</p><p><b>Description</b> The server cannot or will not process the request due to something that is perceived to be a client error (e.g., malformed request syntax, invalid request message framing, or deceptive request routing).</p><hr class="line" /><h3>Apache Tomcat/9.0.31 (Ubuntu)</h3></body></html>
On Tue, Oct 19, 2021 at 10:48 AM Angelos Tzotsos <gcpp.kalxas@anonymised.com>
wrote:
Best,
Angelos
President
Geoserver-users mailing list
Please make sure you read the following two resources before posting to
this list:
- Earning your support instead of buying it, but Ian Turton:
http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines:
http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
President
Issue solved, it was a reverse proxy configuration problem.
Thanks all!
[HTTP/1.1 400 26ms]
wrote:
Best,
Angelos
President
this list:
President
Hello!
Here the paging and the search field stopped working after updating to 2.20.2 without proxying.
Best regards
Uwe
Am Di., 19. Okt. 2021 um 14:20 Uhr schrieb Angelos Tzotsos <gcpp.kalxas@anonymised.com>:
Thanks all!
13:01:33.575
[HTTP/1.1 400 26ms]
<!doctype html>HTTP Status 400 – Bad
Requestbody
HTTP
Type Status
Report
Message Origin does not correspond to
request
Description The server cannot or will not process
Apache
wrote:
Best,
Angelos
President
this list:
President
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
