[Geoserver-users] Geoserver 2.21 - Geoserver Layer Preview downloads a WMS file instead of showing preview in OpenLayers
Dear Users,
I am currently using Kubernetes with the repository: docker.io/kartoza/geoserver. Geoserver 2.21 which is running on Ubuntu 20-04. Recently I have noticed that when trying to perform a Layer preview, instead of getting a map, I get a WMS file that contains the following:-
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
java.lang.NullPointerException
I noticed that this first started happening after the ADMIN account seemed to not have the ability to do anything in the UI. Not sure why this happened but after updating the roles and users xml files and getting it to work again , the problem with the Layer previews started occurring. Interestingly enough, there was also a problem with a couple of modules that suddenly became unavailable, so I am wondering if these events are linked:-
Graphical user interface, application, table, Excel Description automatically generated
I did notice this in the Catalina log file:-
20-Dec-2022 11:54:05.622 INFO [http-nio-8080-exec-119] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
20-Dec-2022 11:54:06.181 WARNING [http-nio-8080-exec-119] it.geosolutions.imageio.plugins.turbojpeg.TurboJpegUtilities.loadTurboJpeg Failed to load the TurboJpeg native libs. This is not a problem, but the TurboJpeg encoder won’t be available: java.lang.UnsatisfiedLinkError: Native Library /opt/libjpeg-turbo/lib64/libturbojpeg.so.0.2.0 already loaded in another classloader
20-Dec-2022 11:54:06.204 WARNING [http-nio-8080-exec-119] it.geosolutions.imageio.gdalframework.GDALUtilities.loadGDAL Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
java.lang.UnsatisfiedLinkError: ‘void org.gdal.gdal.gdalJNI.AllRegister()’
Just wondered if anyone had come across something similar ?
Many Thanks
Fitzroy McCaulsky
The null pointer exception is a short hand for “information is missing” (but does not provided any clue as what information was missing).
The exception should of produced a stack trace in your logs (indicating where in the source code it was trying to access information; giving us a clue what it was trying to do). Can you look for a stack trace in your logs please?
There is also an global setting for verbose error messages (not to be used in production systems) to include stack traces in the exception report that is generated - which is useful for troubleshooting.
Jody Garnett
Hi Jody,
Thanks for your response. The output I provided was restricted because of the size of the email so I had to be brief.
The information I obtained after the “null pointer exception” was:-
at org.geoserver.wms.map.GetMapKvpRequestReader.getDefaultStyle(GetMapKvpRequestReader.java:949)
at org.geoserver.wms.map.GetMapKvpRequestReader.processLayersStyles(GetMapKvpRequestReader.java:571)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:400)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:100)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1511)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:684)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:261)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1043)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:655)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:764)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:357)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:176)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:167)
at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:144)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:54)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:360)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:399)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:890)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1787)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
The TRACE output I get is:-
29 045 10:45:44 TRACE [geoserver.platform] - Found Property override: ‘PROXY_BASE_URL’ to be unset
29 045 10:45:44 TRACE [geoserver.platform] - Found Java environment variable : ‘PROXY_BASE_URL’ to be unset
29 045 10:45:44 TRACE [geoserver.platform] - Found Servlet context parameter : ‘PROXY_BASE_URL’ to be unset
29 045 10:45:44 TRACE [geoserver.platform] - Found System environment variable : ‘PROXY_BASE_URL’ to be unset
29 045 10:45:44 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
29 045 10:45:48 TRACE [platform.resource] - polling contents of /opt/geoserver/data_dir/gwc-layers
29 045 10:45:48 TRACE [platform.resource] - delta computed in 1ms for /opt/geoserver/data_dir/gwc-layers
29 045 10:45:53 TRACE [platform.resource] - polling contents of /opt/geoserver/data_dir/gwc-layers
29 045 10:45:53 TRACE [platform.resource] - delta computed in 825us for /opt/geoserver/data_dir/gwc-layers
29 045 10:45:58 TRACE [platform.resource] - polling contents of /opt/geoserver/data_dir/gwc-layers
29 045 10:45:58 TRACE [platform.resource] - delta computed in 337us for /opt/geoserver/data_dir/gwc-layers
29 045 10:45:59 DEBUG [geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND [ completionTime Before 2022-12-29T10:40Z ]] AND [[ NOT [ lastUpdated IS NULL ] ] AND [ lastUpdated Before 2022-12-29T10:40Z ]]]
29 046 10:46:01 TRACE [geoserver.platform] - Found Property override: ‘geoserver.xframe.shouldSetPolicy’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Property override: ‘geoserver.xframe.policy’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Java environment variable : ‘geoserver.xframe.policy’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Servlet context parameter : ‘geoserver.xframe.policy’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found System environment variable : ‘geoserver.xframe.policy’ to be unset
29 046 10:46:01 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : ‘Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: filter=false’; against ‘/web/**’
29 046 10:46:01 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: filter=false with /web/**
29 046 10:46:01 TRACE [geoserver.monitor] - Testing /web/wicket/bookmarkable/org.geoserver.web.admin.LogPage for monitor filtering
29 046 10:46:01 DEBUG [geoserver.monitor] - /geoserver/web/wicket/bookmarkable/org.geoserver.web.admin.LogPage was filtered from monitoring
29 046 10:46:01 DEBUG [geoserver.ows] - Could not find a layer group named web
29 046 10:46:01 DEBUG [org.geoserver] - Thread 1496479 locking in mode READ
29 046 10:46:01 DEBUG [org.geoserver] - Thread 1496479 got the lock in mode READ
29 046 10:46:01 TRACE [geoserver.platform] - Found Property override: ‘wicket.configuration’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Java environment variable : ‘wicket.configuration’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Servlet context parameter : ‘wicket.configuration’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found System environment variable : ‘wicket.configuration’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Property override: ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Java environment variable : ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Servlet context parameter : ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found System environment variable : ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Property override: ‘PROXY_BASE_URL’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Java environment variable : ‘PROXY_BASE_URL’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found Servlet context parameter : ‘PROXY_BASE_URL’ to be unset
29 046 10:46:01 TRACE [geoserver.platform] - Found System environment variable : ‘PROXY_BASE_URL’ to be unset
29 046 10:46:01 DEBUG [org.geoserver] - Thread 1496479 releasing the lock in mode READ
29 046 10:46:01 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
29 046 10:46:01 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : ‘Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: 10&filter=false’; against ‘/web/**’
29 046 10:46:01 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: 10&filter=false with /web/**
29 046 10:46:03 TRACE [platform.resource] - polling contents of /opt/geoserver/data_dir/gwc-layers
29 046 10:46:03 TRACE [platform.resource] - delta computed in 875us for /opt/geoserver/data_dir/gwc-layers
29 046 10:46:06 TRACE [geoserver.platform] - Found Property override: ‘geoserver.xframe.shouldSetPolicy’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Property override: ‘geoserver.xframe.policy’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Java environment variable : ‘geoserver.xframe.policy’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Servlet context parameter : ‘geoserver.xframe.policy’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found System environment variable : ‘geoserver.xframe.policy’ to be unset
29 046 10:46:06 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : ‘Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: 10-1.IFormSubmitListener-form&filter=false’; against ‘/web/**’
29 046 10:46:06 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: 10-1.IFormSubmitListener-form&filter=false with /web/**
29 046 10:46:06 TRACE [geoserver.monitor] - Testing /web/wicket/bookmarkable/org.geoserver.web.admin.LogPage for monitor filtering
29 046 10:46:06 DEBUG [geoserver.monitor] - /geoserver/web/wicket/bookmarkable/org.geoserver.web.admin.LogPage was filtered from monitoring
29 046 10:46:06 DEBUG [geoserver.ows] - Could not find a layer group named web
29 046 10:46:06 DEBUG [org.geoserver] - Thread 1496812 locking in mode READ
29 046 10:46:06 DEBUG [org.geoserver] - Thread 1496812 got the lock in mode READ
29 046 10:46:06 TRACE [geoserver.platform] - Found Property override: ‘wicket.configuration’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Java environment variable : ‘wicket.configuration’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Servlet context parameter : ‘wicket.configuration’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found System environment variable : ‘wicket.configuration’ to be unset
29 046 10:46:06 DEBUG [org.geoserver] - Thread 1496812 releasing the lock in mode READ
29 046 10:46:06 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
29 046 10:46:06 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : ‘Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: lines=1000’; against ‘/web/**’
29 046 10:46:06 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.web.admin.logpage, QueryString: lines=1000 with /web/**
29 046 10:46:06 DEBUG [org.geoserver] - Thread 1496494 locking in mode READ
29 046 10:46:06 DEBUG [org.geoserver] - Thread 1496494 got the lock in mode READ
29 046 10:46:06 TRACE [geoserver.platform] - Found Property override: ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Java environment variable : ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Servlet context parameter : ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found System environment variable : ‘GEOSERVER_LOG_LOCATION’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Property override: ‘PROXY_BASE_URL’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Java environment variable : ‘PROXY_BASE_URL’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found Servlet context parameter : ‘PROXY_BASE_URL’ to be unset
29 046 10:46:06 TRACE [geoserver.platform] - Found System environment variable : ‘PROXY_BASE_URL’ to be unset
Regards
Fitzroy
Date: Saturday, 24 December 2022 at 09:13
To: McCaulsky, Fitzroy Fitzroy.McCaulsky@anonymised.com
Cc: geoserver-users@lists.sourceforge.net geoserver-users@anonymised.comsourceforge.net
Subject: Re: [Geoserver-users] Geoserver 2.21 - Geoserver Layer Preview downloads a WMS file instead of showing preview in OpenLayers
Jody Garnett
On Thu, Dec 22, 2022 at 1:06 AM McCaulsky, Fitzroy <Fitzroy.McCaulsky@anonymised.com> wrote:
Dear Users,
Many Thanks
Fitzroy McCaulsky
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are
addressed. If you have received this e-mail in error please notify the sender immediately and delete this e-mail from your system.
Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those
of Ricardo (save for reports and other documentation formally approved and signed for release to the intended recipient). Only Directors
are authorised to enter into legally binding obligations on behalf of Ricardo. Ricardo may monitor outgoing and incoming e-mails and
other telecommunications systems. By replying to this e-mail you give consent to such monitoring. The recipient should check e-mail and
any attachments for the presence of viruses. Ricardo accepts no liability for any damage caused by any virus transmitted by this e-mail.
“Ricardo” means Ricardo plc and its subsidiary companies.
Ricardo plc is a public limited company registered in England with registered number 00222915.
The registered office of Ricardo plc is Shoreham Technical Centre, Shoreham-by Sea, West Sussex, BN43 5FG.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
That line in the source code says :
https://github.com/geoserver/geoserver/blob/1c08e95550ae29d673ac7c0ca382eb1aa4dfa678/src/wms/src/main/java/org/geoserver/wms/map/GetMapKvpRequestReader.java#L948
private boolean isAllowedURL(URL styleUrl) {
String url = styleUrl.toString();
return wms.getAllowedURLsForAuthForwarding().stream().anyMatch(s → url.startsWith(s));
The functionality of forwarding authentication when asking for icons is new - and does not appear to check for empty or missing URLs.
Please review your style carefully for any external graphic references. Chances are one is empty and causing trouble.
This will be a relatively rare problem and you are the first to encounter it and being it to our attention. It would be helpful if you could report it to the issue tracker.
If you are comfortable with java development you could also add a null check to skip empty URLs above.
Jody
Jody Garnett
Hi Jody,
that line and the method name (getDefaultStyle) do not match… a code change intervened between the version reported by the user (2.21… something, we don’t know the last version bit)
and the one you’re looking at,
I’m guessing a 2.21.0 and looking at the source code I get something that’s making sense:
https://github.com/geoserver/geoserver/blob/2.21.0/src/wms/src/main/java/org/geoserver/wms/map/GetMapKvpRequestReader.java#L940
If that’s the case, the layer default style is lost, it’s dangling. If that’s the case, switch to the publishing tab, and set a new default style for the layer
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Hi Jody,
Thanks for your response to my last email.
I do not actually create and setup the maps that are put into Geoserver and will have to speak to the developer that has done this.
I am not familiar with reporting issues to the issue tracker, would you be able to point me in the right direction in order for me to be able to do this.
With regards to the Java procedure, I am not a Java developer so am not in a position to do this but I can speak to the developer to see if this can be incorporated in the tests he can do to get this working again.
This was working until the ADMIN account somehow lost privileges to the UI and could not do anything from there. I reset the account from using the geoserver-admin-user account to the user ADMIN, it seemed the problems started occurring after this,
Regards
Fitzroy
Date: Thursday, 29 December 2022 at 14:32
Jody
On Thu, Dec 29, 2022 at 2:54 AM McCaulsky, Fitzroy <Fitzroy.McCaulsky@anonymised.com0…> wrote:
Hi Jody,
Regards
Fitzroy
To: McCaulsky, Fitzroy <Fitzroy.McCaulsky@anonymised.com>
Cc: geoserver-users@anonymised.comurceforge.net <geoserver-users@anonymised.comt>
Jody Garnett
On Thu, Dec 22, 2022 at 1:06 AM McCaulsky, Fitzroy <Fitzroy.McCaulsky@anonymised.com11700…> wrote:
Dear Users,
Many Thanks
Fitzroy McCaulsky
Geoserver-users@anonymised.comet
https://lists.sourceforge.net/lists/listinfo/geoserve
Jody Garnett
