[Geoserver-users] GeoServer 2.21-M0 milestone available for feedback.
(Sorry previous email did not format correctly)
I have made GeoServer 2.21-M0 milestone “release” here
https://sourceforge.net/projects/geoserver/files/GeoServer/2.21-M0/
This release does not even come with an anouncement - only this email! The milestone release is shared to ask for feedback and testing on one feature only - changing to upgrading from log4j 1.2 to log4j 2 (see
http://geoserver.org/behind%20the%20scenes/2022/01/20/log4j-upgrade.html).
Testing priorites:
  • Your existing data directory will smoothly update from using log4j 1.2 property files to using log4j 2 xml files the first time you run.
  • Change between the logging profiles on global setting, please let us know if that works directly for you.
  • Download the user manual and read the docs on making a custom profile if you are keen. Log4j offers fun new capabilities like compressing old log files etc…
This is a milestone release, treat as a technology preview not suitable for production use!
Thanks to activity sponsors for your support:
And thanks to my employer geocat bv for the in-kind support in pursing this upgrade.
Jody Garnett
Installed this milestone release onto a test server.
The update to log4j 2 was smooth.
I encountered no issues switching logging profiles.
System:
Solaris, SunOS 5.11
Tomcat 9.0.53
Java 11.0.12+7-LTS
Graham H
Sent: Saturday, 23 April 2022 7:05 AM
To: GeoServer Users geoserver-users@lists.sourceforge.net
Subject: [Geoserver-users] GeoServer 2.21-M0 milestone available for feedback.
Testing priorites:
Jody Garnett
Thank you for testing, that makes me happy :slight_smile:
The test cases are showing one problem in a windows environment (the test cases is unable to clean up the geoserver.log file as it is still in use). I do not think this would be an issue for a normal user in production on windows.
Jody
Jody Garnett
