Hi Jody,
I did some testing with different log4j2 options and came up with a configuration that might also be usefull to others. I downloaded DEFAULT_LOGGING.xml from the new Custom logging profiles documentation page and changed the RollingFileAppender to:
X:\logs\geoserver-%d{yyyy-MM-dd}.log
What this does is:
Directly write to a log file named after today’s date (f.e. geoserver-2022-05-06.log).
When switching to a new filename, all files older than 30 days that match the geoserver-*.log expression are deleted.
Be aware that when using the DirectWriteRolloverStrategy, the log path set in the Global Settings → Log Location is ignored (and maybe also the value set in GEOSERVER_LOG_LOCATION??), i.e. inside the FilePattern the full path to the output folder must be specified.
Regards
Daniel
Thanks for sharing, if you come up with a log4j 2 example please pass it along for the geoserver docs.
The log4j work is now merged and available as a nightly build, and more importantly the documentation is available online.
https://docs.geoserver.org/latest/en/user/configuration/globalsettings.html#logging-settings
https://docs.geoserver.org/latest/en/user/configuration/logging.html#logging
In the coming days I will work on making the release candidate (it takes some time as it is when we start the next geoserver release series with new branches and build jobs).
Jody
On Wed, May 4, 2022 at 2:25 AM Calliess Daniel Ing. <Daniel.Calliess@…8565…> wrote:
Hi Jody,
in my environment the size of the logfiles isn’t much of a problem. So I configured log4j to act in my personally prefered way, which is to create one file per day and additionally I’ve got a self-written service running that takes care of cleaning up old (log) files. This is my current configuration:
log4j.rootLogger=WARN, geoserverlogfile
log4j.appender.geoserverlogfile=org.apache.log4j.rolling.RollingFileAppender
log4j.appender.geoserverlogfile.RollingPolicy=org.apache.log4j.rolling.TimeBasedRollingPolicy
log4j.appender.geoserverlogfile.RollingPolicy.FileNamePattern=X:/logs/geoserver-%d{yyyy-MM-dd}.log
log4j.appender.geoserverlogfile.layout=org.apache.log4j.PatternLayout
log4j.appender.geoserverlogfile.layout.ConversionPattern=%d %p [%c{2}] - %m%n
For this to work I have to place the Apache Extras™ for Apache log4j™ (https://logging.apache.org/log4j/extras/) library into my WEB-INF\lib folder (when using log4j 1.2).
Regards
Daniel
Sent: Tuesday, May 3, 2022 8:52 AM
To: Calliess Daniel Ing. <Daniel.Calliess@…8499…>
Cc: GeoServer Users <geoserver-users@lists.sourceforge.net>
Subject: RE: [Geoserver-users] GeoServer 2.21-M0 milestone available for feedback.Thanks for your feedback, I have spent the day addressing this and other feedback made …
· Although log4j 1.2 is no longer used, the prior configuration files can be read (sadly this was not working as expected in 2.21-M0 but it is now fixed). I now let Log4J 2 properties configuration try and read the file, and if it is unsuccessful try the log4j 1.2 properties configuration second.
· I am going to change to renaming, rather than deleting prior properties configuration files (that way they can be recovered if you had a customization that was important to you).
I am still curious as the nature of your customization; presently the built-in configurations make 3 backups; but the log4j 2 standard is to compress prior backups (which I think is a good idea).
Jody Garnett
On Apr 28, 2022 at 5:21:52 AM, Calliess Daniel Ing. <Daniel.Calliess@…8565…> wrote:
Hi Jody,
personally I think that there’s no downside to writing out configuration settings to the logfile, but it may come in handy when resolving errors. So I switched the logging level to ‘config’ in my custom configuration file which works like expected.
I’m not quite sure why I would want to use an old “properties” configuration file if log4j 1.2 has been removed from GeoServer. But when renaming such a file and placing it in the /logs folder it shows up in the UI. After switching to such a profile I’m unable to see any logging taking place (which I also verified using Sysinternals Process Monitor).
As the Global Settings documentation states that “additional customized profiles can be added by editing the log4j file”, there might be other users that edited the config files without creating copies of the original files. So I think there should at least be a warning in the release notes that the logging configuration will require attention.
Best regards
Daniel
Sent: Tuesday, April 26, 2022 7:07 PM
Subject: [EXTERN!]: Re: [Geoserver-users] GeoServer 2.21-M0 milestone available for feedback.That is somewhat expected; they should be CONFIG level logging now. We can adjust CONFIG messages to be shown as part of DEFAULT_LOGGING if they are of interest to you.
If you wish to try that out, may a copy of DEFAULT_LOGGING.xml and adjust the geoserver loggers to “config” level.
The same approach works for your previous properties files - to preserve any customizations make a copy with a new name. You should still be able to use the log4j 1.2 properties files configurations with this upgrade (indeed it would be great if you could test this as it is a completely different configuration loader). I experimented with only replacing DEFAULT_LOGGING.properties → DEFAULT_LOGGING.xml if I could recognize that no customizations had been made, but this check was removed in favour of just upgrading based on feedback in GeoServer meeting.
Thanks for the useful feedback!
Jody
On Tue, Apr 26, 2022 at 2:49 AM Calliess Daniel Ing. <Daniel.Calliess@…8565…> wrote:
Hi Jody,
I updated my test server from 2.20 to 2.21-M0 using the Windows installer. Basically logging worked, but I’m seeing less logging entries now for the DEFAULT_LOGGING configuration. For example, I’m missing the
2022-04-26 13:46:57,820 INFO [org.geoserver] - Loaded data store ‘***’, enabled
2022-04-26 13:46:59,413 INFO [org.geoserver] - Loaded feature type ‘***’, enabled
2022-04-26 13:46:59,429 INFO [org.geoserver] - Loaded layer ‘***’
2022-04-26 13:47:00,070 INFO [org.geoserver] - Read catalog in 3.422 s
2022-04-26 13:47:00,148 INFO [org.geoserver] - Loaded service ‘WMTSInfoImpl–44f35506:159d0de9a1e:-7fff’, disabled
entries after restarting the service. Is this intentional behaviour?
Sending the log output to a location outside of the GeoServer installation directory did work as before.
My previous *.properties configuration files have been deleted by the installer, which I had changed to reflect my needs (which maybe I shouldn’t have done??)
Changing the new *.xml configuration files didn’t work because they are reset to default after restarting the service. But this isn’t a problem because I was able to recreate my previous configuration (simple RollingFile appender with TimeBasedTriggeringPolicy) in a new profile xml file.
Switching between profiles works seamlessly without the need to restart the service.
Best regards
Daniel
Sent: Friday, April 22, 2022 11:05 PM
To: GeoServer Users <geoserver-users@lists.sourceforge.net>
Subject: [EXTERN!]: [Geoserver-users] GeoServer 2.21-M0 milestone available for feedback.(Sorry previous email did not format correctly)
I have made GeoServer 2.21-M0 milestone “release” here
https://sourceforge.net/projects/geoserver/files/GeoServer/2.21-M0/
This release does not even come with an anouncement - only this email! The milestone release is shared to ask for feedback and testing on one feature only - changing to upgrading from log4j 1.2 to log4j 2 (see
http://geoserver.org/behind%20the%20scenes/2022/01/20/log4j-upgrade.html).
Testing priorites:
Your existing data directory will smoothly update from using log4j 1.2 property files to using log4j 2 xml files the first time you run.
Change between the logging profiles on global setting, please let us know if that works directly for you.
Download the user manual and read the docs on making a custom profile if you are keen. Log4j offers fun new capabilities like compressing old log files etc…
This is a milestone release, treat as a technology preview not suitable for production use!
Thanks to activity sponsors for your support:
And thanks to my employer geocat bv for the in-kind support in pursing this upgrade.
Jody Garnett
Jody Garnett
Jody Garnett
