[Geoserver-users] geoserver 2.7.0 class not found exception
If I try to preview a layer i get the following exception:
java.lang.NoClassDefFoundError: Could not initialize class org.geotools.gce.imagemosaic.Utils
Details:
org.geoserver.platform.ServiceException: java.lang.NoClassDefFoundError: Could not initialize class org.geotools.gce.imagemosaic.Utils
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1655)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:290)
Yours Rüdiger
error.txt (10.8 KB)
On Thu, May 7, 2015 at 12:34 PM, Gubler, Ruediger <rgubler@anonymised.com>
wrote:
Details:
        at
        at
        at
Mosaics do display fine here, and that class exists... can you give us some
more information about your environment?
Java version, web container (or how you installed) and so on?
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I tested with
  • Windows 2008 R2 64bit
  • Java 1.7.0_45 64bit
  • Apache tomcat 8.0.9 (running as service and in a console window)
  • gdal support for mrsid added
Yours Rüdiger
Von: andrea.aime@…84… [mailto:andrea.aime@…84…] Im Auftrag von Andrea Aime
Gesendet: Donnerstag, 7. Mai 2015 12:56
An: Gubler, Ruediger
Betreff: Re: [Geoserver-users] geoserver 2.7.0 class not found exception
On Thu, May 7, 2015 at 12:34 PM, Gubler, Ruediger <rgubler@…5482…> wrote:
Details:
Mosaics do display fine here, and that class exists… can you give us some more information about your environment?
Ing. Andrea Aime
@geowolf
Technical Lead
