Thank you Ben for that tip. Yes it does work for me too.
Have a good day,
Mike
________________________________________
Sent: Sunday, September 25, 2016 6:47 PM
To: Mike Sharp
Subject: Re: [Geoserver-users] GeoServer 2.8.5 WCS 2.0 exception
[Please keep discussions on-list for the benefit of the community]
Mike,
please try again with "service=WCS" (note uppercase "WCS"); this works
for me:
http://okmaps.org/geoserver/wcs?request=GetCapabilities&service=WCS&version=2.0.1
For OGC web service URLs, keys (like "service") are case-insensitive,
but values (like "WCS") are case sensitive. GeoServer is often
permissive, but apparently not in this case.
Kind regards,
Ben.
On 26/09/16 12:34, Mike Sharp wrote:
Ben,
The GetCapablilities request:
http://okmaps.org/geoserver/wcs?request=GetCapabilities&service=wcs&version=2.0.1
returns:
<ows:ExceptionReport version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/2.0 http://schemas.opengis.net/ows/2.0/owsExceptionReport.xsd"><ows:Exception exceptionCode="InvalidParameterValue" locator="wcs"><ows:ExceptionText>Error in service name, epected value: WCS
</ows:ExceptionText></ows:Exception></ows:ExceptionReport>
Extract from logs:
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/web/**'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/gwc/rest/web/**'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/j_spring_security_check'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/j_spring_security_check/'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/j_spring_security_logout'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/j_spring_security_logout/'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/rest/**'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/gwc/rest/**'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1'; against '/**'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2016-09-25 18:27:00,170 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wcs, QueryString: request=GetCapabilities&service=wcs&version=2.0.1 with /**
2016-09-25 18:27:00,170 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/wcs]
2016-09-25 18:27:00,170 DEBUG [ows.OWSHandlerMapping] - Mapping [/wcs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com.] and 1 interceptor
2016-09-25 18:27:00,170 INFO [geoserver.wcs] -
Request: getServiceInfo
2016-09-25 18:27:00,170 ERROR [geoserver.ows] -
org.geoserver.wcs2_0.exception.WCS20Exception: Error in service name, epected value: WCS
HTTPcode:400
at org.geoserver.wcs2_0.util.RequestUtils.checkService(RequestUtils.java:376)
at org.geoserver.wcs2_0.DefaultWebCoverageService20.getCapabilities(DefaultWebCoverageService20.java:86)
at sun.reflect.GeneratedMethodAccessor15454.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy64.getCapabilities(Unknown Source)
at sun.reflect.GeneratedMethodAccessor19949.invoke(Unknown Source)
Mike
Sent: Sunday, September 25, 2016 2:43 PM
To: Mike Sharp
Cc: GeoServer Mailing List
Mike,
WCS 2.0.1 is supported.
- What is the request (full URL please)?
- What is the content of the exception?
- Do you have the full stack trace and request from the logs?
Kind regards,
Ben.
On 26/09/16 04:58, Mike Sharp wrote:
I am running GeoServer 2.8.5 on Windows 2008 R2, Tomcat 8.5.4, JDK 1.8.0_102. On the Welcome screen WCS 2.0.1 is listed as one of the service capabilities. However when I run a GetCapabilities request on version 2.0 I get an exception. Is WCS 2.0 not supported or is there a problem with my GeoServer configuration?
Thanks for any assistance,
Mike Sharp
State Geographic Information Coordinator
Office of Geographic Information
OGI & Technical Services Director
Assistant Director AML Program
Oklahoma Conservation Commission
4545 N. Lincoln Blvd., Suite 11A
Oklahoma City, OK 73105
405-521-4813 Office
405-833-0648 Cell
405-522-4770 FAX
mike.sharp@anonymised.com<mailto:mike.sharp@anonymised.com>
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Director
New Zealand
